It seems like there are lots of questions regarding simple GPIOs and devicetree, but I can't quite find something that describes my problem:
I am using the nrf52840dk, and I successfully created an overlay file to read/write to an I2C device, but I am having trouble adding a simple GPIO pin to my overlay file.
First, I tried adding the following to my overlay file:
columnswitchint: column_switch_input { compatible = "gpio-keys"; gpios = <&gpio0 2 GPIO_ACTIVE_LOW>; label = "Column Switch Input Signal"; };When I try to build, I get the error "Property not mentioned in "/" ".
Next, I tried declaring the pin like the 'buttons' definition in the .dts file for the blinky example:
This results in the error "Node column_switch_input should have "compatible" property".
Finally, I tried moving the compatible property down into the node:
And this results in the error "Property not mentioned in "gpio-keys". Obviously 'gpios' is one of the only two properties declared in gpio-keys, so I'm stuck.
What am I missing here?
