Reducing power consumption for ble mesh sensor server node using LPN mode
I am using nrf mesh sdk v5.0.0 and am using sensor server model example to build our own application on top of it. SOC we are using is  nRF52832.  I have enabled the LPN mode in the example and I am also able to establish friendship with a nearby friend node. And am also receiving messages intended to the LPN node when the LPN node polls its friend node. The purpose for LPN node is to reduce battery consumption by disabling the scanner. But the device is consuming a solid 5 - 8 mA after establishing friendship. Is it possible to reduce the battery consumption in the micro amperes range. Any guidance on how to achieve it would be really great. I am also interfacing an LED, I2C sensor and a switch with the SOC. Before and after establishing friendship, I am seeing same amount of current being consumed.
  • Hi Hung Bui,
    I tried the LPN example and the current consumption was in the range 150ua. And it was working as expected. After publishing, it went back to the low power state.
    I tried disabling all the peripherals in my own application which I written over sensor_server example with LPN mode enabled and logging enabled using NRF_LOG_INFO, I observed the same behavior as LPN example. Only when I enable the peripherals, the current consumption is going to 3ma constant.
    Peripherals used in my application: SAADC, I2C.
    I am enabling the peripherals only in the callback which is called periodically to publish sensor data and disabling them immediately once data is published. But the peripherals are not disabled properly as my current consumption was a constant 3ma and above. Please guide me to correct sequence which I am using to enable and disable the peripherals, if its wrong.
    Sequence for i2c:
    //1. Code used to initialize and enable the i2c peripheral during startup
        err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
        nrf_delay_ms(20);
        NRF_LOG_INFO("Initializatiion completed!!!");
        nrf_drv_twi_enable(&m_twi);
    //2. I am disabling the i2c peripheral once firendship is established.
            nrf_drv_twi_disable(&m_twi);
    //3. Code used in periodic callback to read data from i2c sensor
        // Read sensor data
    If the current consumption stuck at 3-4mA constant, it's more likely the CPU was not put to sleep.
    Please try run in debug mode and check if the CPU would stuck in the callback ?
    Could you post the whole source code ? where you access the SAADC and I2C.
  • Yeah sure. Disabling and deinitializing the i2c peripheral does not reduce the current consumption? Because the reason I am saying this is.....I am testing the application by enabling and disabling individual peripheral and what I observed is that, with i2c alone enabled in the application, After friendship is established, current consumption goes as low as 400ua and after publishing data too, it is returning to the same low power state (i.e., 400ua). So this means that CPU was put to sleep right? Only the I2C peripheral is not deinitialized properly. The sequence I am following for I2C is:
    1. Initialize and enable the i2c peripheral
    2. Read data from i2c sensor
    3. Disable and de-initialize the i2c peripheral (Doing steps 1 to 3 in the periodic callback itself)
    I have attached the initializing, deinitializing i2c code and the code used to get data from i2c sensor in the callback. I2C peripheral is successfully getting initialized and deinitialized because I am able to read data from i2c sensor successfully.
    //I2C initialization code
    void twi_init (void)
        ret_code_t err_code;
        NRF_LOG_INFO("Initializing I2C!!!\r");
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, twi_handler, NULL);
        nrf_delay_ms(20);
        NRF_LOG_INFO("Initialized I2C!!!\r");
        NRF_LOG_INFO("Enabling I2C!!!\r");
        NRF_LOG_INFO("Enabled I2C!!!\r\n");
    //I2C deinitialization code
    void twi_deinit(void)
        NRF_LOG_INFO("Disabling I2C!!!\r");
        NRF_LOG_INFO("Disabled I2C!!!\r");
        NRF_LOG_INFO("Deinitializing I2C!!!\r");
        nrf_drv_twi_uninit(&m_twi);
        NRF_LOG_INFO("Deinitialized I2C!!!\r\n");
    //Code to read data from i2c sensor in the callback
    #if ENABLE_I2C || ENABLE_ALL
            twi_init();
            m_tx_done = false;
            m_rx_done = false;
            uint16_t t_ticks, h_ticks;
            uint16_t temp;
            /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
            uint8_t reg[1] = {0xFD};
            err_code = nrf_drv_twi_tx(&m_twi, 0x44, reg, sizeof(reg), false);
            while (m_tx_done == false);
            nrf_delay_ms(10);
            uint8_t rxData[6] = {0};
            err_code = nrf_drv_twi_rx(&m_twi, 0x44, rxData, sizeof(rxData));
            while(m_rx_done==false);
            nrf_delay_ms(10);
            t_ticks = rxData[0] * 256 + rxData[1];
            h_ticks = rxData[3] * 256 + rxData[4];
            temp = (175 * t_ticks / 65535) - 45;
            humidity = (125 * h_ticks / 65535) - 6;
            temp *= 10;
            p_out[0] = temp >> 8;
            p_out[1] = temp & 0xFF;
            NRF_LOG_INFO("Temp - %d | Hum - %d\n\n",temp, humidity);
            twi_deinit();
            required_out_bytes = 2;
  • Hi again,
    What I'm suspecting is that the CPU is stuck in a dead loop somewhere in the code. Besides high current consumption everything works ?
    Even at 400uA , it's high current consumption in my opinion. I don't know how you configure the node, have you checked if 400uA is the idle current or it's the average current ?
    Could you try doing I2C communication in the main loop (set a flag in the callback and execute the I2C activity in the main loop and go to sleep after that) and check if it make it high current consumption ?
    Could you provide the minimal code (for example modify the LPN example) so that we can test here ?
    Yes. Besides higher current consumption, everything else is working as expected.
    Yes, it is a higher current consumption. Can you please tell me which node configuration you are referring to? When the CPU goes to sleep after friendship is established, the current goes down to around 400ua. When publishing it goes to upto 600-700ua and then back to 400. I am using multimeter to measure current consumed.
    So you are suggesting me to do the i2c read in main loop instead of in the callback itself without deinitializing and reinitializing it?
    Sure. Will provide one tomorrow. Its past 9 in the eve here.
