Hello!
Im trying to print some logs via RTT but I cant. I tried this but its not working when I flash the .hex and connect the RTT Viewer.
I attach here my project in case you need verify something.
Hello!
Please share the SDK version and board you are trying with. I will look into your Project.
Kind Regards,
Abhijith
Im working with nrf52840DK and nrf connect sdk 2.1.2
Can you try using VS Code with out nRF Connect for VS Code extension and connect to RTT there as described in Connected Devices View?
I also see that you have set the maximum log level to 1, so you will only get error logs. If you want to get info level logs you will need to set the log level to 3.
Marte
