nRF9160 flashing error: Failed to read device memories.
Hi, I'm trying to flash the nrf9160 through Visual Studio Code and I'm getting an error. I'll describe the error and what I tried to fix it below.
1 - First I tried to flash the chip:
nrfjprog --program /home/user/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/zephyr/merged.hex --chiperase --verify -f NRF91 --snr 801036474 --log
[error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[error] [  nRF91] - Failed when checking readback protect status.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
this is the log.log:
[2022-Dec-20 10:16:26] [debug] --------------------------------------------------------------------------------
[2022-Dec-20 10:16:26] [debug] nrfjprog --program /home/user/ncs/v2.1.0/nrf/applications/asset_tracker_v2/build_actinius_icarus_ns/zephyr/merged.hex --chiperase --verify -f NRF91 --snr 801036474 --log
[2022-Dec-20 10:16:26] [debug] nrfjprog version 10.18.1 external
[2022-Dec-20 10:16:26] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
[2022-Dec-20 10:16:26] [ info] Library loaded, loading member functions.
[2022-Dec-20 10:16:26] [ info] Member functions succesfully loaded.
[2022-Dec-20 10:16:26] [debug] [ Client] - open
[2022-Dec-20 10:16:26] [debug] [ Client] - start
[2022-Dec-20 10:16:26] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 061767e5-bb0a-40f7-ab8c-d9bdb30ed869.
[2022-Dec-20 10:16:26] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2022-Dec-20 10:16:26] [debug] [  JLink] - Logger sink registered in JLink logger
[2022-Dec-20 10:16:26] [debug] [  nRF91] - open
[2022-Dec-20 10:16:26] [debug] [  nRF91] - just_check_family
[2022-Dec-20 10:16:26] [debug] [SeggerBackend] - open_dll
[2022-Dec-20 10:16:26] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2022-Dec-20 10:16:26] [trace] [ Client] - Command open executed for 3 milliseconds with result 0
[2022-Dec-20 10:16:26] [debug] [ Client] - config
[2022-Dec-20 10:16:26] [trace] [ Client] - Command config executed for 2 milliseconds with result 0
[2022-Dec-20 10:16:26] [debug] [ Client] - enum_emu_snr
[2022-Dec-20 10:16:26] [ info] [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.7.
[2022-Dec-20 10:16:26] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2022-Dec-20 10:16:26] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2022-Dec-20 10:16:26] [debug] [SeggerBackend] - Set batch mode
[2022-Dec-20 10:16:26] [debug] [SeggerBackend] - dll_version
[2022-Dec-20 10:16:26] [ info] [SeggerBackend] - Segger dll version 7.66.a loaded.
[2022-Dec-20 10:16:26] [trace] [ Worker] - Command open executed for 2 milliseconds with result 0
[2022-Dec-20 10:16:26] [debug] [  nRF91] - config
[2022-Dec-20 10:16:26] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
[2022-Dec-20 10:16:26] [debug] [  nRF91] - enum_emu_con_info
[2022-Dec-20 10:16:26] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Dec-20 10:16:26] [debug] [SeggerBackend] - enum_emu_con_info
[2022-Dec-20 10:16:27] [trace] [ Client] - Command enum_emu_con_info executed for 245 milliseconds with result 0
[2022-Dec-20 10:16:27] [debug] [ Client] - connect_to_emu_with_snr
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Dec-20 10:16:27] [trace] [ Worker] - Command enum_emu_con_info executed for 245 milliseconds with result 0
[2022-Dec-20 10:16:27] [debug] [  nRF91] - connect_to_emu_with_snr
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - ---just_get_num_emus
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - Segger logging enabled.
[2022-Dec-20 10:16:27] [trace] [  JLink] - Firmware: J-Link EDU Mini V1 compiled Sep 22 2022 14:55:40
[2022-Dec-20 10:16:27] [trace] [ Client] - Command connect_to_emu_with_snr executed for 695 milliseconds with result 0
[2022-Dec-20 10:16:27] [debug] [ Client] - read_connected_emu_snr
[2022-Dec-20 10:16:27] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2022-Dec-20 10:16:27] [debug] [ Client] - read_device_info
[2022-Dec-20 10:16:27] [trace] [  JLink] - Hardware: V1.00
[2022-Dec-20 10:16:27] [trace] [  JLink] - S/N: 801036474
[2022-Dec-20 10:16:27] [trace] [  JLink] - OEM: SEGGER
[2022-Dec-20 10:16:27] [trace] [  JLink] - Feature(s): FlashBP, GDB
[2022-Dec-20 10:16:27] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
[2022-Dec-20 10:16:27] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2022-Dec-20 10:16:27] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2022-Dec-20 10:16:27] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 15.609ms returns "O.K."
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_HasError()
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_Lock()
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.003ms returns 0x01
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.001ms returns 0x00
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.002ms returns 0x00
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.006ms returns 0
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.655ms returns 0x00
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_GetSpeedInfo()
[2022-Dec-20 10:16:27] [trace] [  JLink] - 96000000 Hz / n, n >= 24
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.007ms
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 4000kHz
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.142ms
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_GetSpeed()
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.003ms returns 2000
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_GetSN()
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.003ms returns 801036474
[2022-Dec-20 10:16:27] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 695 milliseconds with result 0
[2022-Dec-20 10:16:27] [debug] [  nRF91] - read_connected_emu_snr
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_IsOpen()
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.004ms returns 0x01
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - read_connected_emu_snr
[2022-Dec-20 10:16:27] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2022-Dec-20 10:16:27] [debug] [  nRF91] - read_device_info
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.006ms returns 0x01
[2022-Dec-20 10:16:27] [debug] [  nRF91] - Just_read_device_version
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - read_access_port_register
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - ---just_read_access_port_register
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - coresight_configure
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.151ms returns 0
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 100.481ms returns 0
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - read_debug_port_idr
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - read_debug_port_register
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.482ms returns -1
[2022-Dec-20 10:16:27] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.484ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.468ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.475ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.476ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.463ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.471ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.485ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.470ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.472ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.469ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.461ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.562ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.506ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.519ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.465ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.494ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.574ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.491ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.457ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.503ms returns -1
[2022-Dec-20 10:16:27] [trace] [ Client] - Command read_device_info executed for 115 milliseconds with result -102
[2022-Dec-20 10:16:27] [warning] Failed to read device info. Attempting to complete command anyways.
[2022-Dec-20 10:16:27] [debug] [ Client] - read_memory_descriptors
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.453ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.022ms
[2022-Dec-20 10:16:27] [trace] [ Worker] - Command read_device_info executed for 115 milliseconds with result -102
[2022-Dec-20 10:16:27] [debug] [  nRF91] - read_memory_descriptors
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.012ms returns 0x01
[2022-Dec-20 10:16:27] [debug] [  nRF91] - Just_read_memory_descriptors
[2022-Dec-20 10:16:27] [debug] [  nRF91] - Just_readback_status
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.450ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.466ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.460ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.451ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.467ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.462ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.454ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.509ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.456ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.497ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.511ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.495ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.535ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.532ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.540ms returns -1
[2022-Dec-20 10:16:27] [trace] [ Client] - Command read_memory_descriptors executed for 15 milliseconds with result -102
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.455ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.487ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.443ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.507ms returns -1
[2022-Dec-20 10:16:27] [error] [  nRF91] - Failed when checking readback protect status.
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.019ms
[2022-Dec-20 10:16:27] [trace] [ Worker] - Command read_memory_descriptors executed for 15 milliseconds with result -102
[2022-Dec-20 10:16:27] [debug] [  nRF91] - close
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - is_connected_to_device
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.008ms returns 0x01
[2022-Dec-20 10:16:27] [trace] [  JLink] - JLINK_IsConnected()
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.004ms returns FALSE
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - close
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - disconnect_from_emu
[2022-Dec-20 10:16:27] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.522ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.556ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.498ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.493ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.492ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.499ms returns -1
[2022-Dec-20 10:16:27] [trace] [  JLink] - - 0.480ms returns -1
Here I've got the error Failed to read device memories.
2 - To fix this error I tried to recover the chip, that also gives error:
nrfjprog --recover -f NRF91
Recovering device. This operation might take 30s.
[error] [  nRF91] - Failed while checking eraseprotect status.
ERROR: Recover failed. Please make sure that the correct device family is given
ERROR: and try again.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
Here is the log.log:
[2022-Dec-20 10:21:15] [debug] --------------------------------------------------------------------------------
[2022-Dec-20 10:21:15] [debug] nrfjprog --recover -f NRF91 --log
[2022-Dec-20 10:21:15] [debug] nrfjprog version 10.18.1 external
[2022-Dec-20 10:21:15] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
[2022-Dec-20 10:21:15] [ info] Library loaded, loading member functions.
[2022-Dec-20 10:21:15] [ info] Member functions succesfully loaded.
[2022-Dec-20 10:21:15] [debug] [ Client] - open
[2022-Dec-20 10:21:15] [debug] [ Client] - start
[2022-Dec-20 10:21:15] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 9bb8fc43-f018-43b0-9bbe-82ee9bfbb20d.
[2022-Dec-20 10:21:15] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2022-Dec-20 10:21:15] [debug] [  JLink] - Logger sink registered in JLink logger
[2022-Dec-20 10:21:15] [debug] [  nRF91] - open
[2022-Dec-20 10:21:15] [debug] [  nRF91] - just_check_family
[2022-Dec-20 10:21:15] [debug] [SeggerBackend] - open_dll
[2022-Dec-20 10:21:15] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2022-Dec-20 10:21:15] [trace] [ Client] - Command open executed for 3 milliseconds with result 0
[2022-Dec-20 10:21:15] [debug] [ Client] - config
[2022-Dec-20 10:21:15] [trace] [ Client] - Command config executed for 1 milliseconds with result 0
[2022-Dec-20 10:21:15] [debug] [ Client] - enum_emu_snr
[2022-Dec-20 10:21:15] [ info] [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.7.
[2022-Dec-20 10:21:15] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2022-Dec-20 10:21:15] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2022-Dec-20 10:21:15] [debug] [SeggerBackend] - Set batch mode
[2022-Dec-20 10:21:15] [debug] [SeggerBackend] - dll_version
[2022-Dec-20 10:21:15] [ info] [SeggerBackend] - Segger dll version 7.66.a loaded.
[2022-Dec-20 10:21:15] [trace] [ Worker] - Command open executed for 1 milliseconds with result 0
[2022-Dec-20 10:21:15] [debug] [  nRF91] - config
[2022-Dec-20 10:21:15] [trace] [ Worker] - Command config executed for 1 milliseconds with result 0
[2022-Dec-20 10:21:15] [debug] [  nRF91] - enum_emu_con_info
[2022-Dec-20 10:21:15] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Dec-20 10:21:15] [debug] [SeggerBackend] - enum_emu_con_info
[2022-Dec-20 10:21:15] [trace] [ Client] - Command enum_emu_con_info executed for 233 milliseconds with result 0
[2022-Dec-20 10:21:15] [debug] [ Client] - connect_to_emu_with_snr
[2022-Dec-20 10:21:15] [trace] [ Worker] - Command enum_emu_con_info executed for 233 milliseconds with result 0
[2022-Dec-20 10:21:15] [debug] [  nRF91] - connect_to_emu_with_snr
[2022-Dec-20 10:21:15] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2022-Dec-20 10:21:15] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2022-Dec-20 10:21:15] [debug] [SeggerBackend] - ---just_get_num_emus
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - Segger logging enabled.
[2022-Dec-20 10:21:16] [trace] [  JLink] - Firmware: J-Link EDU Mini V1 compiled Sep 22 2022 14:55:40
[2022-Dec-20 10:21:16] [trace] [ Client] - Command connect_to_emu_with_snr executed for 717 milliseconds with result 0
[2022-Dec-20 10:21:16] [debug] [ Client] - read_connected_emu_snr
[2022-Dec-20 10:21:16] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2022-Dec-20 10:21:16] [debug] [ Client] - recover
[2022-Dec-20 10:21:16] [trace] [  JLink] - Hardware: V1.00
[2022-Dec-20 10:21:16] [trace] [  JLink] - S/N: 801036474
[2022-Dec-20 10:21:16] [trace] [  JLink] - OEM: SEGGER
[2022-Dec-20 10:21:16] [trace] [  JLink] - Feature(s): FlashBP, GDB
[2022-Dec-20 10:21:16] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
[2022-Dec-20 10:21:16] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2022-Dec-20 10:21:16] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2022-Dec-20 10:21:16] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 22.746ms returns "O.K."
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_HasError()
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_Lock()
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.003ms returns 0x01
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.002ms returns 0x00
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.006ms returns 0
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 1.644ms returns 0x00
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_GetSpeedInfo()
[2022-Dec-20 10:21:16] [trace] [  JLink] - 96000000 Hz / n, n >= 24
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.007ms
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 4000kHz
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.035ms
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_GetSpeed()
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.003ms returns 2000
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_GetSN()
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.003ms returns 801036474
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.004ms
[2022-Dec-20 10:21:16] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 716 milliseconds with result 0
[2022-Dec-20 10:21:16] [debug] [  nRF91] - read_connected_emu_snr
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_IsOpen()
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.004ms returns 0x01
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - read_connected_emu_snr
[2022-Dec-20 10:21:16] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2022-Dec-20 10:21:16] [debug] [  nRF91] - recover
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.005ms returns 0x01
[2022-Dec-20 10:21:16] [debug] [  nRF91] - Just_recover
[2022-Dec-20 10:21:16] [debug] [  nRF91] - Just_enable_coprocessor
[2022-Dec-20 10:21:16] [debug] [  nRF91] - Just_is_eraseprotect_enabled
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - read_access_port_register
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - ---just_read_access_port_register
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - coresight_configure
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.084ms returns 0
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 99.818ms returns 0
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - read_debug_port_idr
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - read_debug_port_register
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.555ms returns -1
[2022-Dec-20 10:21:16] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.545ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.548ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.546ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.551ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.573ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.550ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.512ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.507ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.490ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.508ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.532ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.498ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.506ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.509ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.462ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.500ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.469ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.481ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.505ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.499ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.496ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.660ms returns -1
[2022-Dec-20 10:21:16] [trace] [ Client] - Command recover executed for 115 milliseconds with result -21
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.484ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.486ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.488ms returns -1
[2022-Dec-20 10:21:16] [error] [  nRF91] - Failed while checking eraseprotect status.
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.031ms
[2022-Dec-20 10:21:16] [trace] [ Worker] - Command recover executed for 115 milliseconds with result -21
[2022-Dec-20 10:21:16] [debug] [  nRF91] - close
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - is_connected_to_device
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.013ms returns 0x01
[2022-Dec-20 10:21:16] [trace] [  JLink] - JLINK_IsConnected()
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.010ms returns FALSE
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.010ms returns 0x01
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - close
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - disconnect_from_emu
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.011ms returns FALSE
[2022-Dec-20 10:21:16] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.531ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.513ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.491ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.517ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.515ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.483ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.477ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.529ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.521ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.568ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.497ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.511ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.501ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.465ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.461ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.562ms returns -1
[2022-Dec-20 10:21:16] [trace] [  JLink] - - 0.537ms returns -1
3 - I also tried to erase all, but it didn´t work:
 nrfjprog --eraseall --log
\[error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
log.log:
[2022-Dec-20 10:59:39] [debug] --------------------------------------------------------------------------------
[2022-Dec-20 10:59:39] [debug] nrfjprog --eraseall --log
[2022-Dec-20 10:59:39] [debug] nrfjprog version 10.18.1 external
[2022-Dec-20 10:59:39] [ info] Load library at /opt/nrf-command-line-tools/lib/libnrfjprogdll.so.
[2022-Dec-20 10:59:39] [ info] Library loaded, loading member functions.
[2022-Dec-20 10:59:39] [ info] Member functions succesfully loaded.
[2022-Dec-20 10:59:39] [debug] [ Client] - open
[2022-Dec-20 10:59:39] [debug] [ Client] - start
[2022-Dec-20 10:59:39] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 67e84b67-c5a1-43fe-85b4-dc6e8805bb2f.
[2022-Dec-20 10:59:39] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
[2022-Dec-20 10:59:39] [debug] [  JLink] - Logger sink registered in JLink logger
[2022-Dec-20 10:59:39] [debug] [  nRFXX] - open
[2022-Dec-20 10:59:39] [debug] [  nRFXX] - just_check_family
[2022-Dec-20 10:59:39] [debug] [SeggerBackend] - open_dll
[2022-Dec-20 10:59:39] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
[2022-Dec-20 10:59:39] [trace] [ Client] - Command open executed for 6 milliseconds with result 0
[2022-Dec-20 10:59:39] [debug] [ Client] - config
[2022-Dec-20 10:59:39] [trace] [ Client] - Command config executed for 2 milliseconds with result 0
[2022-Dec-20 10:59:39] [debug] [ Client] - enum_emu_snr
[2022-Dec-20 10:59:39] [ info] [SeggerBackend] - Load library at /opt/SEGGER/JLink/libjlinkarm.so.7.
[2022-Dec-20 10:59:39] [ info] [SeggerBackend] - Library loaded, loading member functions.
[2022-Dec-20 10:59:39] [ info] [SeggerBackend] - Member functions succesfully loaded.
[2022-Dec-20 10:59:39] [debug] [SeggerBackend] - Set batch mode
[2022-Dec-20 10:59:39] [debug] [SeggerBackend] - dll_version
[2022-Dec-20 10:59:39] [ info] [SeggerBackend] - Segger dll version 7.66.a loaded.
[2022-Dec-20 10:59:39] [trace] [ Worker] - Command open executed for 4 milliseconds with result 0
[2022-Dec-20 10:59:39] [debug] [  nRFXX] - config
[2022-Dec-20 10:59:39] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
[2022-Dec-20 10:59:39] [debug] [  nRFXX] - enum_emu_con_info
[2022-Dec-20 10:59:39] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Dec-20 10:59:39] [debug] [SeggerBackend] - enum_emu_con_info
[2022-Dec-20 10:59:40] [trace] [ Client] - Command enum_emu_con_info executed for 234 milliseconds with result 0
[2022-Dec-20 10:59:40] [debug] [ Client] - connect_to_emu_with_snr
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - is_connected_to_emu
[2022-Dec-20 10:59:40] [trace] [ Worker] - Command enum_emu_con_info executed for 234 milliseconds with result 0
[2022-Dec-20 10:59:40] [debug] [  nRFXX] - connect_to_emu_with_snr
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - connect_to_emu_with_snr
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - ---just_enum_emu_snr
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - ---just_get_num_emus
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - Segger logging enabled.
[2022-Dec-20 10:59:40] [trace] [  JLink] - Firmware: J-Link EDU Mini V1 compiled Sep 22 2022 14:55:40
[2022-Dec-20 10:59:40] [trace] [  JLink] - Hardware: V1.00
[2022-Dec-20 10:59:40] [trace] [  JLink] - S/N: 801036474
[2022-Dec-20 10:59:40] [trace] [  JLink] - OEM: SEGGER
[2022-Dec-20 10:59:40] [trace] [  JLink] - Feature(s): FlashBP, GDB
[2022-Dec-20 10:59:40] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
[2022-Dec-20 10:59:40] [trace] [  JLink] - TELNET listener socket opened on port 19021
[2022-Dec-20 10:59:40] [trace] [ Client] - Command connect_to_emu_with_snr executed for 649 milliseconds with result 0
[2022-Dec-20 10:59:40] [debug] [ Client] - read_connected_emu_snr
[2022-Dec-20 10:59:40] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2022-Dec-20 10:59:40] [debug] [ Client] - read_device_family
[2022-Dec-20 10:59:40] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
[2022-Dec-20 10:59:40] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 24.938ms returns "O.K."
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_HasError()
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_Lock()
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.017ms returns 0x01
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.012ms returns 0x00
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.046ms returns 0
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 1.380ms returns 0x00
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_GetSpeedInfo()
[2022-Dec-20 10:59:40] [trace] [  JLink] - 96000000 Hz / n, n >= 24
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.050ms
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 4000kHz
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_SetSpeed(2000)
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.346ms
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_GetSpeed()
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.025ms returns 2000
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - SWD clock set to 2000kHz
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_GetSN()
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.025ms returns 801036474
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.026ms
[2022-Dec-20 10:59:40] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 649 milliseconds with result 0
[2022-Dec-20 10:59:40] [debug] [  nRFXX] - read_connected_emu_snr
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_IsOpen()
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.028ms returns 0x01
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - read_connected_emu_snr
[2022-Dec-20 10:59:40] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
[2022-Dec-20 10:59:40] [debug] [  nRFXX] - read_device_family
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.027ms returns 0x01
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - read_debug_port_idr
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - read_debug_port_register
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - ---just_read_debug_port_register
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - coresight_configure
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_GetHWStatus(...)
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.428ms returns 0
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 99.984ms returns 0
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - ---just_select_debug_port_register
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.651ms returns -1
[2022-Dec-20 10:59:40] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - ---just_abort_debug_action
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.635ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.593ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.643ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.612ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.617ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.595ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.587ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.620ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.577ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.654ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.628ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.667ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.660ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.675ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.665ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.606ms returns -1
[2022-Dec-20 10:59:40] [trace] [ Client] - Command read_device_family executed for 121 milliseconds with result -102
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.652ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.704ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.598ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.568ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.630ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.061ms
[2022-Dec-20 10:59:40] [trace] [ Worker] - Command read_device_family executed for 121 milliseconds with result -102
[2022-Dec-20 10:59:40] [debug] [  nRFXX] - close
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.039ms returns 0x01
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - close
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - disconnect_from_emu
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - ---just_disconnect_from_emu
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - is_connected_to_device
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_IsConnected()
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.055ms returns FALSE
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - ---just_is_debug_region_powered
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.581ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.604ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.564ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.597ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.601ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.580ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.552ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.527ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.561ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.550ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.547ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.508ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.498ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.502ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.541ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.582ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.531ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.545ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.495ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.480ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.486ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.488ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.497ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.586ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.507ms returns -1
[2022-Dec-20 10:59:40] [trace] [  JLink] - - 0.030ms
[2022-Dec-20 10:59:40] [trace] [  JLink] - JLINK_Close()
[2022-Dec-20 10:59:40] [debug] [SeggerBackend] - Segger Backend closed.
[2022-Dec-20 10:59:40] [debug] [  nRFXX] - nRF family DLL closed
[2022-Dec-20 10:59:40] [trace] [ Client] - Command close executed for 44 milliseconds with result 0
[2022-Dec-20 10:59:40] [debug] [ Client] - terminate
[2022-Dec-20 10:59:40] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
Is there anything else I can do to try to recover the chip?
Thanks
Additional information
- I tried to flash this chip using Ubuntu 22.04 and Windows 10 with same results.
- nrfjprog version is 10.18.1 external
- I'm using the actinius icarus iot board.
  • Hi
    What device are you using to program/communicate with the nRF91 board? We've seen something like this in the past, and that time it was due to the programmer used not being supported by our software tools. We do not support the Flasher series devices from SEGGER for example, as they are production programming oriented, but there's no reason why the Flasher series should not work specifically. My guess is that the device is not powered with the correct voltage. What voltage is the Icarus board power with, and what power does the programmer support?
    We also have a whitepaper on nRF9160 Production programming available here that might be useful as well if you're in fact using a production programmer.
    Simon
    I'm using the J-LINK EDU mini v1.0 programmer. The icarus board is powered through the USB plug, but I also tried to powered it with a 3.7 V  LIPO battery (measured 3.9 V with multimeter). The results are the same with either of the two sources.
    I forgot to say earlier that I was able to flash this same firmware in another icarus IoT board using the same programmer and method.
    Thanks
  • Then there must be an issue with the current Icarus board you're using. Are there perhaps any components missing on the misbehaving Icarus board? Can you check the voltages in on VDD on the nRF91 on this board if they look correct with your multimeter perhaps? Most likely there is a voltage mismatch somewhere, causing there JLink errors.
    Simon
