Can't enable mcuboot if external flash partition is selected in devicetree
Hi -- I am having an issue with partition manager when I have mcuboot enabled and an external flash partition selected in devicetree. I've attached a very minimal project to demonstrate on nrf5340dk_nrf5340_cpuapp:
mcuboot-littlefs-ext-flash.zip
but in short, my prj.conf is:
CONFIG_BOOTLOADER_MCUBOOT=y
and boards/nrf5340dk_nrf5340_cpuapp.overlay is:
    chosen {
        nordic,pm-ext-flash = &mx25r64;
and I get the following error when building:
Building mcuboot-littlefs-ext-flash
west build --build-dir /home/lab/mcuboot-littlefs-ext-flash/build /home/lab/mcuboot-littlefs-ext-flash --pristine --board nrf5340dk_nrf5340_cpuapp -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="/home/lab/implant-fw;/home/lab/littlefs;/home/lab/mcuboot-littlefs-ext-flash" -DDTC_OVERLAY_FILE:STRING="/home/lab/mcuboot-littlefs-ext-flash/boards/nrf5340dk_nrf5340_cpuapp.overlay" -DCONF_FILE:STRING="/home/lab/mcuboot-littlefs-ext-flash/prj.conf"
-- Application: /home/lab/mcuboot-littlefs-ext-flash
-- Found Python3: /usr/bin/python3.10 (found suitable exact version "3.10.6") found components: Interpreter
-- Cache files will be written to: /home/lab/.cache/zephyr
-- Zephyr version: 3.1.99 (/home/lab/ncs-2.1.0/zephyr)
-- Board: nrf5340dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.14.2 (/home/lab/zephyr-sdk-0.14.2)
-- Found dtc: /home/lab/zephyr-sdk-0.14.2/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.2 (/home/lab/zephyr-sdk-0.14.2)
-- Found BOARD.dts: /home/lab/ncs-2.1.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
-- Found devicetree overlay: /home/lab/mcuboot-littlefs-ext-flash/boards/nrf5340dk_nrf5340_cpuapp.overlay
-- Generated zephyr.dts: /home/lab/mcuboot-littlefs-ext-flash/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/lab/mcuboot-littlefs-ext-flash/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /home/lab/mcuboot-littlefs-ext-flash/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /home/lab/mcuboot-littlefs-ext-flash/build/zephyr/dts.cmake
Parsing /home/lab/ncs-2.1.0/zephyr/Kconfig
Loaded configuration '/home/lab/ncs-2.1.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
Merged configuration '/home/lab/mcuboot-littlefs-ext-flash/prj.conf'
Configuration saved to '/home/lab/mcuboot-littlefs-ext-flash/build/zephyr/.config'
Kconfig header saved to '/home/lab/mcuboot-littlefs-ext-flash/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 10.3.0
-- The CXX compiler identification is GNU 10.3.0
-- Found assembler: /home/lab/zephyr-sdk-0.14.2/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
-- Found Python3: /usr/bin/python3.10 (found version "3.10.6") found components: Interpreter
=== child image mcuboot -  begin ===
loading initial cache file /home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/child_image_preload.cmake
-- Application: /home/lab/ncs-2.1.0/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: /home/lab/ncs-2.1.0/nrf/modules/mcuboot/flash_sim.overlay
-- Found devicetree overlay: /home/lab/ncs-2.1.0/nrf/modules/mcuboot/usb.overlay
-- Found devicetree overlay: /home/lab/ncs-2.1.0/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: /home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: /home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: /home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: /home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr/dts.cmake
Parsing /home/lab/ncs-2.1.0/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration '/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration '/home/lab/ncs-2.1.0/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
Merged configuration '/home/lab/ncs-2.1.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration '/home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to '/home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr/.config'
Kconfig header saved to '/home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr/include/generated/autoconf.h'
MCUBoot bootloader key file: /home/lab/ncs-2.1.0/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: /home/lab/mcuboot-littlefs-ext-flash/build/mcuboot
=== child image mcuboot -  end ===
CMake Warning at /home/lab/ncs-2.1.0/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
          --- WARNING: Using default MCUBoot key, it should not ---
          --- be used for production.                           ---
-- Configuring done
-- Generating done
[1/190] Preparing syscall dependency handling
[2/190] Creating directories for 'mcuboot_subimage'
[3/190] No download step for 'mcuboot_subimage'
[4/190] Generating include/generated/version.h
-- Zephyr version: 3.1.99 (/home/lab/ncs-2.1.0/zephyr), build: v3.1.99-ncs1
[5/190] No update step for 'mcuboot_subimage'
[6/190] No patch step for 'mcuboot_subimage'
[7/190] No configure step for 'mcuboot_subimage'
[7/190] Performing build step for 'mcuboot_subimage'
[1/288] Preparing syscall dependency handling
[2/288] Generating include/generated/version.h
[3/288] Generating misc/generated/syscalls_subdirs.trigger
[4/288] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[5/288] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[6/288] Generating include/generated/driver-validation.h
[7/288] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[8/288] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[9/288] Generating include/generated/offsets.h
[10/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[11/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[12/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[13/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[14/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[15/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[16/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[17/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[18/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[19/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[20/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[21/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[22/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[23/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[24/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[25/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[26/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[27/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[28/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[29/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
[30/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[31/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[32/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[33/288] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[34/288] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[35/288] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf53/soc.c.obj
[36/288] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[37/288] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[38/288] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[39/288] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[40/288] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/stats/stats.c.obj
[41/288] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[42/288] Building C object zephyr/CMakeFiles/zephyr.dir/home/lab/ncs-2.1.0/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[43/288] Building C object zephyr/CMakeFiles/zephyr.dir/home/lab/ncs-2.1.0/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
[44/288] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[45/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[46/288] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[47/288] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[48/288] Building C object zephyr/CMakeFiles/zephyr.dir/home/lab/ncs-2.1.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[49/288] Generating linker_zephyr_pre1.cmd
[50/288] Generating linker_zephyr_pre0.cmd
[51/288] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[52/288] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[53/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/entropy.c.obj
[54/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/entropy_poll.c.obj
[55/288] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[56/288] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[57/288] Linking C static library zephyr/arch/common/libisr_tables.a
[58/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[59/288] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[60/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[61/288] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[62/288] Linking C static library zephyr/libzephyr.a
[63/288] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[64/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[65/288] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[66/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[67/288] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[68/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[69/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[70/288] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[71/288] Linking C static library zephyr/arch/common/libarch__common.a
[72/288] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[73/288] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[74/288] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[75/288] Generating zephyr/autogen-pubkey.c
[76/288] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[77/288] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[78/288] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[79/288] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
[80/288] Generating ../../../include/generated/libc/minimal/strerror_table.h
[81/288] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[82/288] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[83/288] Linking C static library zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a
[84/288] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[85/288] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[86/288] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[87/288] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[88/288] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a
[89/288] Building C object CMakeFiles/app.dir/main.c.obj
[90/288] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
[91/288] Building C object CMakeFiles/app.dir/os.c.obj
[92/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
[93/288] Building C object CMakeFiles/app.dir/keys.c.obj
[94/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
[95/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
[96/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
[97/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
[98/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
[99/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
[100/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
[101/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
[102/288] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
[103/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
[104/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
[105/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
[106/288] Building C object CMakeFiles/app.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
[107/288] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
[108/288] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[109/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[110/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[111/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[112/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[113/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[114/288] Linking C static library zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a
[115/288] Linking C static library zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a
[116/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[117/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[118/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[119/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[120/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[121/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[122/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[123/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[124/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[125/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[126/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[127/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[128/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[129/288] Linking C static library app/libapp.a
[130/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[131/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[132/288] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[133/288] Linking C static library zephyr/lib/posix/liblib__posix.a
[134/288] Linking C static library zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a
[135/288] Linking C static library zephyr/drivers/clock_control/libdrivers__clock_control.a
[136/288] Linking C static library zephyr/drivers/console/libdrivers__console.a
[137/288] Linking C static library zephyr/drivers/gpio/libdrivers__gpio.a
[138/288] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/nrf_qspi_nor.c.obj
[139/288] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_simulator.c.obj
[140/288] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
[141/288] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[142/288] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[143/288] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[144/288] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[145/288] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[146/288] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[147/288] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[148/288] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
[149/288] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[150/288] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[151/288] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/home/lab/ncs-2.1.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
[152/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/aes.c.obj
[153/288] Linking C static library zephyr/lib/libc/minimal/liblib__libc__minimal.a
[154/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/zephyr_init.c.obj
[155/288] Linking C static library zephyr/drivers/serial/libdrivers__serial.a
[156/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/aesni.c.obj
[157/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/aria.c.obj
[158/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/asn1parse.c.obj
[159/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/asn1write.c.obj
[160/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/base64.c.obj
[161/288] Linking C static library zephyr/drivers/flash/libdrivers__flash.a
[162/288] Linking C static library zephyr/drivers/pinctrl/libdrivers__pinctrl.a
[163/288] Linking C static library modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a
[164/288] Linking C static library modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a
[165/288] Linking C static library modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a
[166/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/camellia.c.obj
[167/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ccm.c.obj
[168/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/chacha20.c.obj
[169/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/cipher.c.obj
[170/288] Linking C static library modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a
[171/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/bignum.c.obj
[172/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/cipher_wrap.c.obj
[173/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/cmac.c.obj
[174/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/constant_time.c.obj
[175/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ctr_drbg.c.obj
[176/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/debug.c.obj
[177/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/des.c.obj
[178/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/dhm.c.obj
[179/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ecdh.c.obj
[180/288] Linking C static library zephyr/drivers/timer/libdrivers__timer.a
[181/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/chachapoly.c.obj
[182/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ecdsa.c.obj
[183/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ecjpake.c.obj
[184/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ecp.c.obj
[185/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ecp_curves.c.obj
[186/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/error.c.obj
[187/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/gcm.c.obj
[188/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/hkdf.c.obj
[189/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/hmac_drbg.c.obj
[190/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/md5.c.obj
[191/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/md.c.obj
[192/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
[193/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/mps_reader.c.obj
[194/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/mps_trace.c.obj
[195/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/net_sockets.c.obj
[196/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/nist_kw.c.obj
[197/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/oid.c.obj
[198/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/padlock.c.obj
[199/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/pem.c.obj
[200/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/pk_wrap.c.obj
[201/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/pkcs12.c.obj
[202/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/pkcs5.c.obj
[203/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/pkparse.c.obj
[204/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/pkwrite.c.obj
[205/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/platform.c.obj
[206/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/poly1305.c.obj
[207/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/pk.c.obj
[208/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/platform_util.c.obj
[209/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_crypto.c.obj
[210/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_crypto_aead.c.obj
[211/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_crypto_cipher.c.obj
[212/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_crypto_client.c.obj
[213/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_crypto_driver_wrappers.c.obj
[214/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_crypto_ecp.c.obj
[215/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_crypto_hash.c.obj
[216/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_crypto_mac.c.obj
[217/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_crypto_rsa.c.obj
[218/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_crypto_se.c.obj
[219/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_crypto_slot_management.c.obj
[220/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_crypto_storage.c.obj
[221/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/psa_its_file.c.obj
[222/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ripemd160.c.obj
[223/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj
[224/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/sha1.c.obj
[225/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_cache.c.obj
[226/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/rsa.c.obj
[227/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/sha256.c.obj
[228/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/sha512.c.obj
[229/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_ciphersuites.c.obj
[230/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_cli.c.obj
[231/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_cookie.c.obj
[232/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_debug_helpers_generated.c.obj
[233/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_msg.c.obj
[234/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_ticket.c.obj
[235/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_srv.c.obj
[236/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_tls.c.obj
[237/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_tls13_client.c.obj
[238/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_tls13_generic.c.obj
[239/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_tls13_keys.c.obj
[240/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/ssl_tls13_server.c.obj
[241/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/threading.c.obj
[242/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/timing.c.obj
[243/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/version.c.obj
[244/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/version_features.c.obj
[245/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/x509.c.obj
[246/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/x509_create.c.obj
[247/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/x509_crl.c.obj
[248/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/x509_crt.c.obj
[249/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/x509_csr.c.obj
[250/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/x509write_crt.c.obj
[251/288] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/home/lab/ncs-2.1.0/modules/crypto/mbedtls/library/x509write_csr.c.obj
[252/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/lab/ncs-2.1.0/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.c.obj
[253/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[254/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/lab/ncs-2.1.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[255/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/lab/ncs-2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[256/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/lab/ncs-2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[257/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/lab/ncs-2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[258/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/lab/ncs-2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_qspi.c.obj
[259/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/lab/ncs-2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[260/288] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/home/lab/ncs-2.1.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
[261/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[262/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[263/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[264/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[265/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[266/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[267/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[268/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[269/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[270/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[271/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[272/288] Linking C static library modules/mbedtls/libmodules__mbedtls.a
[273/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[274/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[275/288] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[276/288] Linking C static library modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a
[277/288] Linking C static library zephyr/kernel/libkernel.a
[278/288] Linking C executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr/zephyr_pre0.map
: && ccache /home/lab/zephyr-sdk-0.14.2/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc   zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf  zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj  -fuse-ld=bfd  -Wl,-T  zephyr/linker_zephyr_pre0.cmd  -Wl,-Map=/home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr/zephyr_pre0.map  -Wl,--whole-archive  app/libapp.a  zephyr/libzephyr.a  zephyr/arch/common/libarch__common.a  zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a  zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a  zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a  zephyr/lib/libc/minimal/liblib__libc__minimal.a  zephyr/lib/posix/liblib__posix.a  zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a  zephyr/drivers/clock_control/libdrivers__clock_control.a  zephyr/drivers/console/libdrivers__console.a  zephyr/drivers/gpio/libdrivers__gpio.a  zephyr/drivers/flash/libdrivers__flash.a  zephyr/drivers/serial/libdrivers__serial.a  zephyr/drivers/timer/libdrivers__timer.a  zephyr/drivers/pinctrl/libdrivers__pinctrl.a  modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a  modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a  modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a  modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a  modules/mbedtls/libmodules__mbedtls.a  modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a  -Wl,--no-whole-archive  zephyr/kernel/libkernel.a  -L"/home/lab/zephyr-sdk-0.14.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/thumb/v8-m.main/nofp"  -L/home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr  -lgcc  zephyr/arch/common/libisr_tables.a  -no-pie  -mcpu=cortex-m33  -mthumb  -mabi=aapcs  -mfp16-format=ieee  -Wl,--gc-sections  -Wl,--build-id=none  -Wl,--sort-common=descending  -Wl,--sort-section=alignment  -Wl,-u,_OffsetAbsSyms  -Wl,-u,_ConfigAbsSyms  -nostdlib  -static  -Wl,-X  -Wl,-N  -Wl,--orphan-handling=warn  /home/lab/ncs-2.1.0/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.15.a && cd /home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr && /usr/local/bin/cmake -E echo
/home/lab/zephyr-sdk-0.14.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: zephyr/zephyr_pre0.elf section `rodata' will not fit in region `FLASH'
/home/lab/zephyr-sdk-0.14.2/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/10.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd: region `FLASH' overflowed by 4640 bytes
collect2: error: ld returned 1 exit status
[169/190] Linking C executable zephyr/zephyr_pre0.elf
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf /home/lab/mcuboot-littlefs-ext-flash/build/modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build /home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr/zephyr.hex /home/lab/mcuboot-littlefs-ext-flash/build/mcuboot/zephyr/zephyr.elf
cd /home/lab/mcuboot-littlefs-ext-flash/build/mcuboot && /usr/local/bin/cmake --build . --
[171/190] Generating dev_handles.c
FATAL ERROR: command exited with status 1: /usr/local/bin/cmake --build /home/lab/mcuboot-littlefs-ext-flash/build
I found a workaround by creating a pm_static.yml file. Is there a better way? How can I set the mcuboot partition size in prj.conf?
mcuboot:
    address: 0x0
    end_address: 0x10000
    placement:
      before:
      - mcuboot_primary
    region: flash_primary
