Question about Over the Air update in NCS_V2
Does the NCS V2 .x support OTA updates ? I used OTA update with encryption in older SDK and i was looking to migrate that to the new SDK. Is there some example or  guide to how to do the exact same implementation in NCS ? I know NCS uses mcuboot but does that mean that DFU and OTA is no longer supported in NCS ?
Thank you.
  • From your choice of words, it seems that you just want NSIB to be the immutable bootloader, and don't really need a second stage bootloader. Is that right?
    While I research this use case, can I ask why you would like to use NSIB as the immutable bootloader and not MCUboot?
    Right. I do NOT want a second stage bootloader.. As I told, my end goal is over-the-air firmware update using NRF Secure Immutable bootloader. I will take anything to help me get this. That is all.
    But as I understand from the docs, OTA cannot be done with NRF Secure Immutable bootloader. Or am I understanding it wrong ?
    My updates does not involve updating the bootloader. It only updates my application. And from this page, I believe that in this case, first stage immutable bootloader is what I want. Again, if I am wrong in my understanding, please correct me. The whole information is a lot and is vague in my mind.
    Thank you
  • OTA DFU can theoretically be done with either NSIB or MCUboot as the first stage (and immutable) bootloader.
    I should have phrased my question better. Is there a reason you choose NSIB over MCUboot as the first stage bootloader?
    Using MCUboot as the only bootloader, there are various built-in toolchain and libraries support to make enabling OTA DFU easy.
    Using NSIB as the only bootloader, I have not found any such support. I am asking our internal teams to see if I may be missing anything here.
  • Is there a reason you choose NSIB over MCUboot as the first stage bootloader?
    There is no specific reason for this choice.
    So, from what I understand now, OTA DFU is easily done if my first stage immutable bootloader is MCUboot. right ? In that case, would I have to go for a second stage bootloader ?
    That's right. OTA DFU is relatively easily done if your first stage immutable bootloader is MCUboot (and if you use a NSIB - MCUboot chain, like you previously discovered).
    Also, to answer your previous question 4, here are a few relevant reference sources:
    I need to double check a few things before I can be sure of the answers your previous question 2 and 3. I should be back with those answers before next week.
    Please feel free to comment here if you have anymore questions in the mean time though.
