Question about Over the Air update in NCS_V2
Does the NCS V2 .x support OTA updates ? I used OTA update with encryption in older SDK and i was looking to migrate that to the new SDK. Is there some example or  guide to how to do the exact same implementation in NCS ? I know NCS uses mcuboot but does that mean that DFU and OTA is no longer supported in NCS ?
Thank you.
  • I could get the whole encryption and OTA functionality working, thanks to your guidance. However, there is also one slight problem. My application image is a bit too much and so, during the swapping, it fails.
    I am aware that I have an option to move the second image to an external flash. But the thing is, changing the whole layout to accommodate an external flash is not a really feasible idea. I could get this working by disabling the logging module CONFig_LOG=n and I saved almost 40kb. But it would suit the application to have the logger enabled.
    Is there any other way I can get the application image reduced or get the image swap to be successful ? My application is built on the peripheral_uart sample.
    Edit : Also, I noticed that once I upload an image successfully and the swapping is all done, the SMP service will no longer be active until I reboot the device. The SMP service will be listed in the NRF Connect android application but in the NRF Device manager application, the device wont show up until there the device is rebooted. Is that a normal response for an invalid image ?
    Thank you.
    This happens when your application is too large and swapping is not possible because of that. I am confused because image update won't happen if this error persist.
    Could you please create new ticket mentioning this as the problem because this is deviating from your parent question. This also helps the other users and to keep the Devzone clean.
    Kind Regards,
    Abhijith
  • Okay. Got it. I will open a new ticket. Thanks for the inputs so far. Upvoting helpful answer and closing the case.
