nRF9160 VSCode examples don't run properly
I am having a problem with all of my projects compiled with VSCode NCS 2.2.0:
I understand that one of the COM ports (I'm on Windows) should send output. When I flash the Asset Tracker sample to my Thingy:91, it works fine. There is terminal output, and I can send AT commands and see responses.
However, when I follow the instructions to import the AT_Client sample in VSCode, build for the thingy91_nRF9160_ns, and flash, there is no terminal output in LTE Link Monitor on any terminal. If I Debug, the debugger never gets to main(). If I pause it, it is usually here:
Does anyone know why this would happen? I have tried putting breakpoints in main(), but they are never hit.
I am debugging a Thingy91 with a SEGGER J-link Plus probe. The hello_world worked once, last week, before re-flashing with demo samples, and now no VSCode projects work properly.
I have erased with J-flash lite, nRF Connect Programmer, and VSCode, to no avail. There are no error messages in the build or debug session.
I can flash the .hex samples and they work fine.
The debugger runs and is running. It does not break at main(). If I click Pause, it is usually here:
It may be getting stuck in some sort of bootloader image validation. Sometimes if I pause, it is in checks in a function called main that is not my main:
This happens whether or not I have Debug Options checked in the build.
Any ideas?
  • Collin Moore said:
    Next I opened Command Prompt from the Toolchain Manager drop-down, cd into at_client and built it. here is the beginning:
    Sorry, forgot to specify but did you test this version as well? You can run west flash afterwards
    Did you follow my last steps on building in command prompt? From the output log that you have it seems to be the same as VS Code.
    Here is the output from my build in the command prompt
    C:\NordicSemi\v2.2.0\nrf\samples\nrf9160\at_client>west build -b thingy91_nrf9160_ns -d build_300534
    -- Application: C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client
    -- Using NCS Toolchain 2.2.0 for building. (C:/NordicSemi/toolchains/v2.2.0/cmake)
    -- Found Python3: C:/NordicSemi/toolchains/v2.2.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: C:/NordicSemi/v2.2.0/zephyr/.cache
    -- Zephyr version: 3.2.99 (C:/NordicSemi/v2.2.0/zephyr)
    -- Board: thingy91_nrf9160_ns
    -- Found host-tools: zephyr 0.15.1 (C:/NordicSemi/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.1 (C:/NordicSemi/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found Dtc: C:/NordicSemi/toolchains/v2.2.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/NordicSemi/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns.dts
    -- Generated zephyr.dts: C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/zephyr/dts.cmake
    Parsing C:/NordicSemi/v2.2.0/zephyr/Kconfig
    Loaded configuration 'C:/NordicSemi/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns_defconfig'
    Merged configuration 'C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/prj.conf'
    Configuration saved to 'C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/zephyr/.config'
    Kconfig header saved to 'C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 12.1.0
    -- The CXX compiler identification is GNU 12.1.0
    -- Found assembler: C:/NordicSemi/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Found Python3: C:/NordicSemi/toolchains/v2.2.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    Changed board to secure thingy91_nrf9160 (NOT NS)
    === child image mcuboot -  begin ===
    loading initial cache file C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/child_image_preload.cmake
    -- Application: C:/NordicSemi/v2.2.0/bootloader/mcuboot/boot/zephyr
    -- Found BOARD.dts: C:/NordicSemi/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160.dts
    -- Found devicetree overlay: C:/NordicSemi/v2.2.0/bootloader/mcuboot/boot/zephyr/dts.overlay
    -- Generated zephyr.dts: C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/zephyr/dts.cmake
    Parsing C:/NordicSemi/v2.2.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/NordicSemi/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_defconfig'
    Merged configuration 'C:/NordicSemi/v2.2.0/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration 'C:/NordicSemi/v2.2.0/bootloader/mcuboot/boot/zephyr/boards/thingy91_nrf9160.conf'
    Merged configuration 'C:/NordicSemi/v2.2.0/nrf/modules/mcuboot/tfm.conf'
    Merged configuration 'C:/NordicSemi/v2.2.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration 'C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/zephyr/include/generated/autoconf.h'
    MCUBoot bootloader key file: C:/NordicSemi/v2.2.0/bootloader/mcuboot/root-rsa-2048.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot
    === child image mcuboot -  end ===
    CMake Warning at C:/NordicSemi/v2.2.0/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
              --- WARNING: Using default MCUBoot key, it should not ---
              --- be used for production.                           ---
    CMake Warning at C:/NordicSemi/v2.2.0/zephyr/CMakeLists.txt:1833 (message):
    -- Found partition manager static configuration: C:/NordicSemi/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_pm_static.yml
    Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
    Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
    Partition 'nonsecure_storage' is not included in the dynamic resolving since it is statically defined.
    Partition 'tfm_secure' is not included in the dynamic resolving since it is statically defined.
    Partition 'tfm_nonsecure' is not included in the dynamic resolving since it is statically defined.
    Partition 'tfm' is not included in the dynamic resolving since it is statically defined.
    Dropping partition 'nrf_modem_lib_trace' since its size is 0.
    -- Configuring done
    -- Generating done
    [45/273] Generating include/generated/version.h
    -- Zephyr version: 3.2.99 (C:/NordicSemi/v2.2.0/zephyr), build: v3.2.99-ncs1
    [52/273] Performing build step for 'mcuboot_subimage'
    [1/278] Generating include/generated/version.h
    [268/278] Linking C executable zephyr\zephyr_pre0.elf
    [272/278] Linking C executable zephyr\zephyr_pre1.elf
    [278/278] Linking C executable zephyr\zephyr.elf
               FLASH:       40410 B        48 KB     82.21%
                 RAM:       28024 B     211736 B     13.24%
            IDT_LIST:          0 GB         2 KB      0.00%
    [57/273] Generating ../../tfm/CMakeCache.txt
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/NordicSemi/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/tfm
    [67/273] Performing build step for 'tfm'
    [1/2] Re-running CMake...
    -- Configuring done
    -- Generating done
    [171/171] Generating ../bin/tfm_s.bin
    [72/273] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    [254/273] Linking C executable zephyr\zephyr_pre0.elf
    [258/273] Linking C executable zephyr\zephyr_pre1.elf
    [264/273] Linking C executable zephyr\zephyr.elf
               FLASH:       68508 B     380416 B     18.01%
                 RAM:       32848 B     211736 B     15.51%
    [268/273] Generating ../../zephyr/app_update.bin
    sign the payload
    [269/273] Generating ../../zephyr/app_signed.hex
    sign the payload
    [271/273] Generating ../../zephyr/app_test_update.hex
    sign the payload
    [273/273] Generating zephyr/merged.hex
  • Sorry, what I posted, with the beginning and end fragments, was from VSCode.
    I forgot to post the command prompt build output, here is that:
    I ran west clean, rmdir /s /q build, rmdir /s /q build_300534, then west build -b thingy91_nrf9160_ns -d build_300534 again:
    C:\ncs\v2.2.0\nrf\samples\nrf9160\at_client>rmdir /s /q build
    C:\ncs\v2.2.0\nrf\samples\nrf9160\at_client>rmdir /s /q build_300534
    C:\ncs\v2.2.0\nrf\samples\nrf9160\at_client>west clean
    usage: west [-h] [-z ZEPHYR_BASE] [-v] [-V] <command> ...
    west: error: argument <command>: invalid choice: 'clean' (choose from 'init', 'update', 'list', 'manifest', 'diff', 'status', 'forall', 'help', 'config', 'topdir', 'selfupdate', 'ncs-loot', 'ncs-compare', 'ncs-upmerger', 'ncs-sbom', 'completion', 'boards', 'build', 'sign', 'flash', 'debug', 'debugserver', 'attach', 'zephyr-export', 'spdx', 'blobs')
    C:\ncs\v2.2.0\nrf\samples\nrf9160\at_client>west build -b thingy91_nrf9160_ns -d build_300534
    -- Application: C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client
    -- Using NCS Toolchain 2.2.0 for building. (C:/ncs/toolchains/v2.2.0/cmake)
    -- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v2.2.0/zephyr/.cache
    -- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr)
    -- Found host-tools: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/v2.2.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns.dts
    -- Generated zephyr.dts: C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/zephyr/dts.cmake
    Parsing C:/ncs/v2.2.0/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns_defconfig'
    Merged configuration 'C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/prj.conf'
    Configuration saved to 'C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/zephyr/.config'
    Kconfig header saved to 'C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/zephyr/include/generated/autoconf.h'
    -- Found assembler: C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    loading initial cache file C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/child_image_preload.cmake
    -- Application: C:/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr
    -- Found BOARD.dts: C:/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160.dts
    -- Found devicetree overlay: C:/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/dts.overlay
    -- Generated zephyr.dts: C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/zephyr/dts.cmake
    Parsing C:/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_defconfig'
    Merged configuration 'C:/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/prj.conf'
    Merged configuration 'C:/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr/boards/thingy91_nrf9160.conf'
    Merged configuration 'C:/ncs/v2.2.0/nrf/modules/mcuboot/tfm.conf'
    Merged configuration 'C:/ncs/v2.2.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration 'C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/zephyr/.config'
    Kconfig header saved to 'C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot/zephyr/include/generated/autoconf.h'
    MCUBoot bootloader key file: C:/ncs/v2.2.0/bootloader/mcuboot/root-rsa-2048.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/mcuboot
    CMake Warning at C:/ncs/v2.2.0/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
    CMake Warning at C:/ncs/v2.2.0/zephyr/CMakeLists.txt:1833 (message):
    -- Found partition manager static configuration: C:/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_pm_static.yml
    -- Configuring done
    -- Generating done
    [4/273] Generating include/generated/version.h
    -- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr), build: v3.2.99-ncs1
    [54/273] Performing build step for 'mcuboot_subimage'
    [61/273] Generating ../../tfm/CMakeCache.txt
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/ncs/v2.2.0/nrf/samples/nrf9160/at_client/build_300534/tfm
    -- Configuring done
    -- Generating done
    sign the payload
    sign the payload
    sign the payload
    I took my output, changed the text ncs/ to NordicSemi/, diffed the two, and they are exactly the same except these lines:
    I then ran C:\ncs\v2.2.0\nrf\samples\nrf9160\at_client>west flash -d build_300534
    I don't get any interaction from the thingy91 in LTE Link Monitor, so I don't think it's working.
    When I flash the precompiled .hex at_client2, I get responses and it works great.
    Attached is my verbose log when re-installing toolchain v2.2.0 (what I have been using this whole time).
    2023-02-09T19_58_22.761Z-log.txt
  • Any progress on this?
    I am still unable to run any custom projects on either computer. I was hoping to be using the Modem library and sending SMS by now, but I'm stuck on toolchain stuff, even though I followed all the default instructions.
  • Sorry, I was trying to follow up internally and see if I could find a solution. What version of the Connectivity Bridge are you running on the Thingy:91? Did you try to update this with the version found in the latest precompiled package?
  • Yes, if I understand correctly, the bridge should connect the nrf91 UART to the 52840, then use the 52840 as a USB to UART adapter.
    If I erase it, no examples work. I flashed "...\thingy91_fw_2022_12_08_188a1603\img_app_bl\thingy91_nrf52_connectivity_bridge_2022-12-08_188a1603.hex"
    Then the pre-compiled AT client sample works, and I can send and receive AT commands.
    My problem is in Debugging the nrf9160 MCU in VSCode. I can't get any project to get to main().
    So I can flash the pre-compiled examples, and the bridge works fine, still just the debugging issue.
    Is there any chance we could do a video call or something, so that you could see what is going on in my computer? I would have blamed my setup, except that I get the exact same results on a fresh install of Win10 on another laptop!
    I have been developing on nRF52832 with those SDKs and GCC since 2016, and have never had this many issues. I understand that this is much more compilicated, with the Zephyr RTOS and the Crypto stuff, (which I don't yet know if it's on or off), but I just want to read pin states and send SMS, and I can't get the example project to compile and debug, or run.
    I don't need any of the crypto/security stuff for my code. If there is anything I can turn off to make it work, please let me know!
