nRF9160 VSCode examples don't run properly
I am having a problem with all of my projects compiled with VSCode NCS 2.2.0:
I understand that one of the COM ports (I'm on Windows) should send output. When I flash the Asset Tracker sample to my Thingy:91, it works fine. There is terminal output, and I can send AT commands and see responses.
However, when I follow the instructions to import the AT_Client sample in VSCode, build for the thingy91_nRF9160_ns, and flash, there is no terminal output in LTE Link Monitor on any terminal. If I Debug, the debugger never gets to main(). If I pause it, it is usually here:
Does anyone know why this would happen? I have tried putting breakpoints in main(), but they are never hit.
I am debugging a Thingy91 with a SEGGER J-link Plus probe. The hello_world worked once, last week, before re-flashing with demo samples, and now no VSCode projects work properly.
I have erased with J-flash lite, nRF Connect Programmer, and VSCode, to no avail. There are no error messages in the build or debug session.
I can flash the .hex samples and they work fine.
The debugger runs and is running. It does not break at main(). If I click Pause, it is usually here:
It may be getting stuck in some sort of bootloader image validation. Sometimes if I pause, it is in checks in a function called main that is not my main:
This happens whether or not I have Debug Options checked in the build.
Any ideas?
  • Thank you for providing this information!
    Looking through your support information and comparing to mine I see that you do not have GNUARMEMB_TOOLCHAIN_PATH set.
    How did you install the SDK? Are you using the toolchain manager?
  • Yes, sorry I wasn't clearer before. I installed everything via nRF Connect for Desktop. First I installed nRF connect, then the "Toolchain Manager", then followed its link to install VSCode, while installing toolchain 2.2.0, then opened VSCode and everything looks as it should in the examples to add and build code.
    I didn't change or add anything custom. I have some older path entries (as you can see!) to other compilers, etc, but I followed the instructions exactly to set up the IDE and Toolchain.
    I will try adding that path entry. Is that the only thing I am missing? I expected your instructions to work, and have not modified my install process at all.
    As a second attempt, I tried the whole process over, installing nrf connect, toolchain, VSCode on another laptop, with a fresh install of Windows 10, and got a similar result: Debugger stuck in nrf_spu_flashregion_set().
  • Ok, I have now followed the instructions on the page you linked, and I have added to my System PATH:
    I get a similar result when debugging. This is where it was when I paused after 5 minutes of running a debug session:
    Gene sent me a new nRF9160DK and it seems to have the same issue.
    Can you please help me get to where I can write code for these things and have it work?
    I have now followed the instructions exactly on two separate computers, with a thingy91 and a nRF9160DK (that both work fine with the at_client pre-compiled examples), and neither works.
    Now I have followed your extra instructions, that I have never seen before, and it still doesn't work.
    I was under the assumption that following the instructions would work, at least on one computer.
    What am I missing? Can you please point me to more complete instructions, or a path to getting working on Windows 10?
    Here is my Generate Support Info output again:
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Pro",
        "osKernel": "10.0.19044",
        "vscode": "1.75.0",
        "electron": "19.1.9",
        "node": "v16.14.2"
      "system": {
        "date": "2023-02-09T15:56:10.414Z",
        "vscodeRoot": "c:\\Users\\Collin\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "00:00:50",
        "osUptime": "00:06:23",
        "cpu": {
          "model": "Intel(R) Core(TM) i7-2600K CPU @ 3.40GHz",
          "speed": "3411 MHz",
          "count": 4
        "memory": {
          "total": "7.97 GB",
          "free": "1.48 GB"
      "workspace": {
        "name": "Cellular-IoT-Fundamentals",
        "workspaceFile": null,
        "folders": [
          "c:\\C-IoT-Fund\\Cellular-IoT-Fundamentals"
      "extensions": {
        "internal": {
            "version": "2023.1.44",
            "path": "c:\\Users\\Collin\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.1.44-win32-x64",
            "isActive": true
            "version": "2022.11.29",
            "path": "c:\\Users\\Collin\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.11.29",
            "isActive": true
            "version": "2022.11.153",
            "path": "c:\\Users\\Collin\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2022.11.153",
            "isActive": true
            "version": "2022.11.50",
            "path": "c:\\Users\\Collin\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2022.11.50",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.6.10",
          "ms-vscode.cpptools": "1.13.9",
          "ms-vscode-remote.remote-wsl-recommender": "0.0.18",
          "ms-vscode.js-debug": "1.75.1",
          "ms-vscode.js-debug-companion": "1.0.18",
          "ms-vscode.vscode-js-profile-table": "1.0.3",
          "cschlosser.doxdocgen": "1.4.0",
          "jeff-hykin.better-cpp-syntax": "1.17.2",
          "mcu-debug.debug-tracker-vscode": "0.0.13",
          "mcu-debug.memory-view": "0.0.19",
          "mcu-debug.rtos-views": "0.0.4",
          "vsciot-vscode.vscode-arduino": "0.4.13"
      "tools": {
        "c:\\ncs\\toolchains\\v2.2.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.15.1",
        "C:\\Program Files (x86)\\SEGGER\\JLink\\JLink.exe": "7.66a",
        "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.15.4",
        "C:\\Users\\Collin\\AppData\\Local\\Programs\\Python\\Python38\\Scripts\\nrfutil.exe": null,
        "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\cmake.exe": "3.20.5",
        "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\Scripts\\west.exe": "0.14.0",
        "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\python.exe": "3.8.2",
        "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\ninja.exe": "1.9.0",
        "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\gperf.exe": "3.1",
        "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\dtc.exe": "1.4.7",
        "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\gn.exe": "2073",
        "c:\\ncs\\toolchains\\v2.2.0\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
        "gdbPath": "c:\\ncs\\toolchains\\v2.2.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
      "sdks": [
          "version": "2.2.0",
          "path": "c:\\ncs\\v2.2.0"
      "toolchains": [
          "version": "2.2.0",
          "path": "c:\\ncs\\toolchains\\v2.2.0"
      "connectedDevices": [],
      "deviceProviders": [
        "nrfjprog"
      "config": {
          "topdir": "${nrf-connect.sdk:2.2.0}",
          "toolchain": {
            "path": "${nrf-connect.toolchain:2.2.0}"
          "ozonePath": "",
          "applications": [
            "${workspaceFolder}\\lesson2\\cellfund_less2_exer2"
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig",
            "executeInDefaultShell": false
          "welcome": {
            "showOnStartup": true
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "enableTelemetry": false,
          "taskBindings": {},
          "debugging": {
            "backend": "nRF Debug",
            "flash": true,
            "bindings": {}
          "activeAppFollowActiveEditor": true
          "terminalMode": "character",
          "scrollBack": 1000
        "marus25.cortex-debug": {
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "enableTelemetry": true,
          "registerUseNaturalFormat": true,
          "variableUseNaturalFormat": true,
          "dbgServerLogfile": null,
          "showDevDebugOutput": "none"
      "environment": {
        "westExe": "west",
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOME": "C:\\Users\\Collin",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\Collin",
          "Path": "c:\\ncs\\toolchains\\v2.2.0\\mingw64\\bin;c:\\ncs\\toolchains\\v2.2.0\\mingw64\\libexec\\git-core;c:\\ncs\\toolchains\\v2.2.0\\opt\\bin;c:\\ncs\\toolchains\\v2.2.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\ncs\\toolchains\\v2.2.0\\arm-zephyr-eabi\\bin;c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\Scripts;C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\PuTTY\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\Git\\cmd;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files (x86)\\dotnet\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:/PersonalProjects/ESP8266/ESP8266_RTOS_SDK/tools;C:\\Program Files\\CMake\\bin;C:\\Users\\Collin\\AppData\\Roaming\\Python\\Python38\\Scripts;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\Program Files (x86)\\SEGGER\\JLink;C:\\Users\\Collin\\AppData\\Local\\Programs\\Python\\Python38\\Scripts\\;C:\\Users\\Collin\\AppData\\Local\\Programs\\Python\\Python38\\;C:\\Users\\Collin\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\FAHClient;C:\\Users\\Collin\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\Collin\\.dotnet\\tools;C:\\Program Files (x86)\\Nmap",
          "ZEPHYR_BASE": "c:\\ncs\\v2.2.0\\zephyr",
          "GNUARMEMB_TOOLCHAIN_PATH": "C:\\gnu_arm_embedded",
          "ZEPHYR_SDK_INSTALL_DIR": "c:\\ncs\\toolchains\\v2.2.0\\opt\\zephyr-sdk",
          "PYTHONPATH": "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin;c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\Lib;c:\\ncs\\toolchains\\v2.2.0\\opt\\bin\\Lib\\site-packages",
          "Python3_ROOT": "c:\\ncs\\toolchains\\v2.2.0\\opt\\bin"
        "inherited": {
          "HOMEDRIVE": "C:",
          "Path": "C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\PuTTY\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\Git\\cmd;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files (x86)\\dotnet\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:/PersonalProjects/ESP8266/ESP8266_RTOS_SDK/tools;C:\\Program Files\\CMake\\bin;C:\\Users\\Collin\\AppData\\Roaming\\Python\\Python38\\Scripts;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\Program Files (x86)\\SEGGER\\JLink;C:\\Users\\Collin\\AppData\\Local\\Programs\\Python\\Python38\\Scripts\\;C:\\Users\\Collin\\AppData\\Local\\Programs\\Python\\Python38\\;C:\\Users\\Collin\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\FAHClient;C:\\Users\\Collin\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\Collin\\.dotnet\\tools;C:\\Program Files (x86)\\Nmap",
          "PATH": "C:\\Program Files (x86)\\Common Files\\Oracle\\Java\\javapath;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\PuTTY\\;C:\\Program Files (x86)\\NVIDIA Corporation\\PhysX\\Common;C:\\Program Files\\Git\\cmd;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\TortoiseSVN\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files (x86)\\dotnet\\;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:/PersonalProjects/ESP8266/ESP8266_RTOS_SDK/tools;C:\\Program Files\\CMake\\bin;C:\\Users\\Collin\\AppData\\Roaming\\Python\\Python38\\Scripts;C:\\Program Files (x86)\\GnuWin32\\bin;C:\\Program Files (x86)\\SEGGER\\JLink;C:\\Users\\Collin\\AppData\\Local\\Programs\\Python\\Python38\\Scripts\\;C:\\Users\\Collin\\AppData\\Local\\Programs\\Python\\Python38\\;C:\\Users\\Collin\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Program Files (x86)\\FAHClient;C:\\Users\\Collin\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\Collin\\.dotnet\\tools;C:\\Program Files (x86)\\Nmap",
          "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb"
        "toolchainPath": "c:\\ncs\\toolchains\\v2.2.0",
        "toolchainBinPath": "c:\\ncs\\toolchains\\v2.2.0\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
        "toolchainVersion": "2.2.0"
      "terminal": {
        "shell": null,
        "defaultProfile": null
    [08:56:40] west build --build-dir c:\C-IoT-Fund\Cellular-IoT-Fundamentals\lesson2\cellfund_less2_exer2\build c:\C-IoT-Fund\Cellular-IoT-Fundamentals\lesson2\cellfund_less2_exer2 --pristine --board thingy91_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y
    [08:59:22] Success.
    [09:03:08] west flash -d c:\C-IoT-Fund\Cellular-IoT-Fundamentals\lesson2\cellfund_less2_exer2\build --skip-rebuild -r nrfjprog --dev-id 600106256
    [09:03:24] Success.
      "platform": {
        "os": "win32",
        "vscode": "1.75.0",
        "node": "v16.14.2"
      "system": {
        "date": "2023-02-09T16:16:53.374Z",
        "vscodeUptime": "00:21:32",
        "osUptime": "00:27:05",
        "cpu": {
          "count": 4
        "memory": {
          "total": "7.97 GB",
          "free": "1.78 GB"
      "workspace": {
        "folders": [
      "extensions": {
        "internal": {
            "isActive": true
            "isActive": true
            "isActive": true
            "isActive": true
        "external": {
      "tools": {
      "sdks": [
          "version": "2.2.0",
      "toolchains": [
          "version": "2.2.0",
          "serialNumber": "600106256"
        "nrfjprog"
      "config": {
          "toolchain": {
          "ozonePath": "",
          "applications": [
          "kconfig": {
          "welcome": {
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "taskBindings": {},
          "debugging": {
            "flash": true,
            "bindings": {}
          "scrollBack": 1000
          "gdbPath": null,
          "pyocdPath": null,
          "stutilPath": null,
          "stlinkPath": null,
      "environment": {
        "westExe": "west",
        "westEnv": {
          "HOMEDRIVE": "C:",
        "inherited": {
          "HOMEDRIVE": "C:",
      "terminal": {
        "shell": null,
    If you are using the Toolchain Manager it should fix everything for you. There should not be a reason to set the GNUARMEMB toolchain path.
    Is this your personal computer or business computer, i.e. are there any administrative rights needed? Did you install using VPN? Would it be possible to reinstall the nRF Connect SDK in the Toolchain Manager with Verbose Logging enabled under About:
    I'm really not seeing the reason for this either. What does your build configuration for the board look like?
    And what does the build command look like in VS code
    Here is mine
    west build --build-dir c:\Temp\Projects\at_client-210\build_292249 c:\Temp\Projects\at_client-210 --pristine --board nrf9160dk_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="c:/Temp/Projects/shell-2299;c:/Temp/Projects/cli_dongle210" -DCONF_FILE:STRING="c:/Temp/Projects/at_client-210/prj.conf"
    I want to you try one last thing. In the Toolchain manager open Bash or Command Prompt
    This will open an instance of CMD or Git Bash, with all settings configured by Toolchain Manager.
    From here navigate to at_client (or other samples) e.g. cd nrf\samples\nrf9160\at_client
    Here you could try to build the sample using west build
    west build -b thingy91_nrf9160_ns -d build_300534
    This is exactly what VS code does as well, but interesting to see if does change anything.
  • Hey, thanks for the reply!
    I only ever used toolchain manager. Both computers are my personal computer, on normal network, home router, no VPNs, with Administrator Windows 10 accounts.
    The toolchain takes a while to download, but I'll do that after I try what you suggested. I'll upload the verbose log in a bit.
    Right now, when I right-click Copy Build Configuration:
    west build --build-dir c:\C-IoT-Fund\Cellular-IoT-Fundamentals\lesson2\cellfund_less2_exer2\build c:\C-IoT-Fund\Cellular-IoT-Fundamentals\lesson2\cellfund_less2_exer2 --pristine --board thingy91_nrf9160_ns -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="c:/C-IoT-Fund/Cellular-IoT-Fundamentals/lesson2/cellfund_less2_exer2/prj.conf"
    I don't have a DBOARD_ROOT entry, or numbers after build, but other than that it looks pretty similar to me.
    Next, I tried Cleaning the Build config:
     *  Executing task: nRF Connect: Build [clean]: cellfund_less2_exer2/build (active)
    Building cellfund_less2_exer2
    west build -t clean --build-dir c:\C-IoT-Fund\Cellular-IoT-Fundamentals\lesson2\cellfund_less2_exer2\build
    -- west build: running target clean
    [1/2] Cleaning additional files...
    [2/2] Cleaning all built files...
    Cleaning... 6 files.
    Build looked successful, but the terminal lost the text from the beginning:
    Next I opened Command Prompt from the Toolchain Manager drop-down, cd into at_client and built it. here is the beginning:
     *  Executing task: nRF Connect: Generate config thingy91_nrf9160_ns for lesson2/cellfund_less2_exer2
    -- Application: C:/C-IoT-Fund/Cellular-IoT-Fundamentals/lesson2/cellfund_less2_exer2
    -- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v2.2.0/zephyr/.cache
    -- Zephyr version: 3.2.99 (C:/ncs/v2.2.0/zephyr)
    -- Board: thingy91_nrf9160_ns
    -- Found host-tools: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.1 (C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/v2.2.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns.dts
    -- Generated zephyr.dts: C:/C-IoT-Fund/Cellular-IoT-Fundamentals/lesson2/cellfund_less2_exer2/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/C-IoT-Fund/Cellular-IoT-Fundamentals/lesson2/cellfund_less2_exer2/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/C-IoT-Fund/Cellular-IoT-Fundamentals/lesson2/cellfund_less2_exer2/build/zephyr/dts.cmake
    Parsing C:/ncs/v2.2.0/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160_ns_defconfig'
    Merged configuration 'C:/C-IoT-Fund/Cellular-IoT-Fundamentals/lesson2/cellfund_less2_exer2/prj.conf'
    Merged configuration 'C:/C-IoT-Fund/Cellular-IoT-Fundamentals/lesson2/cellfund_less2_exer2/build/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'C:/C-IoT-Fund/Cellular-IoT-Fundamentals/lesson2/cellfund_less2_exer2/build/zephyr/.config'
    Kconfig header saved to 'C:/C-IoT-Fund/Cellular-IoT-Fundamentals/lesson2/cellfund_less2_exer2/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 12.1.0
    -- The CXX compiler identification is GNU 12.1.0
    -- Found assembler: C:/ncs/toolchains/v2.2.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Found Python3: C:/ncs/toolchains/v2.2.0/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    Changed board to secure thingy91_nrf9160 (NOT NS)
    === child image mcuboot -  begin ===
    loading initial cache file C:/C-IoT-Fund/Cellular-IoT-Fundamentals/lesson2/cellfund_less2_exer2/build/mcuboot/child_image_preload.cmake
    -- Application: C:/ncs/v2.2.0/bootloader/mcuboot/boot/zephyr
    -- Found BOARD.dts: C:/ncs/v2.2.0/nrf/boards/arm/thingy91_nrf9160/thingy91_nrf9160.dts
    -- Found devicetree overlay: C:/ncs/v2.2.0/bootloader/mcuboot/boot/zep
    and the end:
    ap_helper.S.obj
    [42/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [43/278] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [44/278] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [45/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [46/278] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [47/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [48/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
    [49/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [50/278] Linking C static library zephyr\arch\common\libarch__common.a
    [51/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
    [52/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [53/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
    [54/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [55/278] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [56/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [57/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [58/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [59/278] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [60/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [61/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [62/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [63/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [64/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [65/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [66/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [67/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [68/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [69/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [70/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [71/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [72/278] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [73/278] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
    [74/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/base64.c.obj
    [75/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [76/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [77/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [78/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [79/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [80/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [81/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [82/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [83/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
    [84/278] Linking C static library zephyr\kernel\libkernel.a
    [85/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [86/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [87/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [88/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [89/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [90/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [91/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [92/278] Generating ../../../include/generated/libc/minimal/strerror_table.h
    [93/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [94/278] Generating zephyr/autogen-pubkey.c
    [95/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [96/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [97/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [98/278] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [99/278] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [100/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
    [101/278] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [102/278] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [103/278] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [104/278] Building C object CMakeFiles/app.dir/os.c.obj
    [105/278] Building C object CMakeFiles/app.dir/keys.c.obj
    [106/278] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
    [107/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
    [108/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
    [109/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
    [110/278] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [111/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
    [112/278] Linking C static library zephyr\libzephyr.a
    [113/278] Building C object CMakeFiles/app.dir/main.c.obj
    [114/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
    [115/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
    [116/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
    [117/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
    [118/278] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
    [119/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
    [120/278] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
    [121/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
    [122/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
    [123/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
    [124/278] Building C object CMakeFiles/app.dir/arm_cleanup.c.obj
    [125/278] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [126/278] Building C object CMakeFiles/app.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
    [127/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
    [128/278] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [129/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
    [130/278] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [131/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
    [132/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
    [133/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
    [134/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
    [135/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
    [136/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
    [137/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
    [138/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
    [139/278] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
    [140/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
    [141/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
    [142/278] Linking C static library app\libapp.a
    [143/278] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [144/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
    [145/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
    [146/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
    [147/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
    [148/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
    [149/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
    [150/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
    [151/278] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
    [152/278] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
    [153/278] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [154/278] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [155/278] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [156/278] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [157/278] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [158/278] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
    [159/278] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [160/278] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
    [161/278] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [162/278] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
    [163/278] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
    [164/278] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [165/278] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [166/278] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    [167/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/zephyr_init.c.obj
    [168/278] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
    [169/278] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    [170/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/aria.c.obj
    [171/278] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
    [172/278] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
    [173/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/aesni.c.obj
    [174/278] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
    [175/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ccm.c.obj
    [176/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/asn1parse.c.obj
    [177/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/chacha20.c.obj
    [178/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/asn1write.c.obj
    [179/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/camellia.c.obj
    [180/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/cmac.c.obj
    [181/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/cipher_wrap.c.obj
    [182/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/base64.c.obj
    [183/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/cipher.c.obj
    [184/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/aes.c.obj
    [185/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/chachapoly.c.obj
    [186/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/des.c.obj
    [187/278] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/C_/ncs/v2.2.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
    [188/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ctr_drbg.c.obj
    [189/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/debug.c.obj
    [190/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ecdsa.c.obj
    [191/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/dhm.c.obj
    [192/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ecdh.c.obj
    [193/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/constant_time.c.obj
    [194/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/entropy_poll.c.obj
    [195/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ecp.c.obj
    [196/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ecp_curves.c.obj
    [197/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/entropy.c.obj
    [198/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/hkdf.c.obj
    [199/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ecjpake.c.obj
    [200/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/gcm.c.obj
    [201/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/error.c.obj
    [202/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/hmac_drbg.c.obj
    [203/278] Linking C static library modules\mcuboot\boot\bootutil\zephyr\libmcuboot_util.a
    [204/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/padlock.c.obj
    [205/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/md.c.obj
    [206/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/mps_reader.c.obj
    [207/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/mps_trace.c.obj
    [208/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
    [209/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/md5.c.obj
    [210/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/net_sockets.c.obj
    [211/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/nist_kw.c.obj
    [212/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pem.c.obj
    [213/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pkcs12.c.obj
    [214/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pkparse.c.obj
    [215/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pk.c.obj
    [216/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pk_wrap.c.obj
    [217/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pkcs5.c.obj
    [218/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/pkwrite.c.obj
    [219/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/oid.c.obj
    [220/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_aead.c.obj
    [221/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/platform.c.obj
    [222/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto.c.obj
    [223/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/poly1305.c.obj
    [224/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_ecp.c.obj
    [225/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/bignum.c.obj
    [226/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/platform_util.c.obj
    [227/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_cipher.c.obj
    [228/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_mac.c.obj
    [229/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_client.c.obj
    [230/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_hash.c.obj
    [231/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_driver_wrappers.c.obj
    [232/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_slot_management.c.obj
    [233/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_rsa.c.obj
    [234/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ripemd160.c.obj
    [235/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_se.c.obj
    [236/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_its_file.c.obj
    [237/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/psa_crypto_storage.c.obj
    [238/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/sha512.c.obj
    [239/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/sha1.c.obj
    [240/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj
    [241/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_ciphersuites.c.obj
    [242/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_debug_helpers_generated.c.obj
    [243/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_cache.c.obj
    [244/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/sha256.c.obj
    [245/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_cookie.c.obj
    [246/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_cli.c.obj
    [247/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_srv.c.obj
    [248/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_msg.c.obj
    [249/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_ticket.c.obj
    [250/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls13_client.c.obj
    [251/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls13_generic.c.obj
    [252/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls.c.obj
    [253/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls13_server.c.obj
    [254/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/ssl_tls13_keys.c.obj
    [255/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/version.c.obj
    [256/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/timing.c.obj
    [257/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/threading.c.obj
    [258/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/version_features.c.obj
    [259/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509_create.c.obj
    [260/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509_crt.c.obj
    [261/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/rsa.c.obj
    [262/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509.c.obj
    [263/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509write_crt.c.obj
    [264/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509_csr.c.obj
    [265/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509_crl.c.obj
    [266/278] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.2.0/modules/crypto/mbedtls/library/x509write_csr.c.obj
    [267/278] Linking C static library modules\mbedtls\libmodules__mbedtls.a
    [268/278] Linking C executable zephyr\zephyr_pre0.elf
    [269/278] Generating dev_handles.c
    [270/278] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
    [271/278] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [272/278] Linking C executable zephyr\zephyr_pre1.elf
    [273/278] Generating linker.cmd
    [274/278] Generating isr_tables.c, isrList.bin
    [275/278] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [276/278] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [277/278] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [278/278] Linking C executable zephyr\zephyr.elf
               FLASH:       40410 B        48 KB     82.21%
                 RAM:       28024 B     211736 B     13.24%
            IDT_LIST:          0 GB         2 KB      0.00%
    [61/290] Generating ../../tfm/CMakeCache.txt
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/C-IoT-Fund/Cellular-IoT-Fundamentals/lesson2/cellfund_less2_exer2/build/tfm
    [66/290] No configure step for 'tfm'
    [67/290] Performing build step for 'tfm'
    [1/2] Generating ../generated/secure_fw/spm/cmsis_func/tfm_spm_db_func.inc, ../generated/secure_fw/spm/cmsis_func/tfm_veneers.c, ../generated/interface/include/tfm_veneers.h, ../generated/tools/tfm_veneers_functions.txt, ../generated/secure_fw/spm/cmsis_func/tfm_secure_irq_handlers.inc, ../generated/interface/include/psa_manifest/sid.h, ../generated/interface/include/psa_manifest/pid.h, ../generated/interface/include/config_impl.h, ../generated/tools/config_impl.cmake
    [1/2] Re-running CMake...
    -- Configuring done
    -- Generating done
    [1/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/asn1write.o
    [2/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/base64.o
    [3/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/nist_kw.o
    [4/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/bignum.o
    [5/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/asn1parse.o
    [6/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/oid.o
    [7/171] Generating liboberon_mbedcrypto__psa_3.0.12.a
    [8/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcpy.o
    [9/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memmove.o
    [10/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_strnlen.o
    [11/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memcmp.o
    [12/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/crt_memset.o
    [13/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/service_api.o
    [14/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/platform/tfm_platform_secure_api.o
    [15/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_partition_metadata_indicator.o
    [16/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sprt_main.o
    [17/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [18/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/crypto/tfm_crypto_secure_api.o
    [19/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/sfn_common_thread.o
    [20/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/spm/cmsis_psa/psa_interface_cross.o
    [21/171] Building C object secure_fw/partitions/lib/sprt/CMakeFiles/tfm_sprt.dir/__/__/__/__/interface/src/tfm_psa_call_pack.o
    [22/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_mac.o
    [23/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_init.o
    [24/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_cipher.o
    [25/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_hash.o
    [26/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_alloc.o
    [27/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_asymmetric.o
    [28/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_derivation.o
    [29/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key_management.o
    [30/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_aead.o
    [31/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_key.o
    [32/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/generated/secure_fw/partitions/crypto/auto_generated/intermedia_tfm_crypto.o
    [33/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/spm/cmsis_psa/psa_interface_cross.o
    [34/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [35/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/crypto_rng.o
    [36/171] Building C object secure_fw/partitions/crypto/CMakeFiles/tfm_psa_rot_partition_crypto.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [37/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/memory_buffer_alloc.o
    [38/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_cipher.o
    [39/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_aead.o
    [40/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto.o
    [41/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_slot_management.o
    [42/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_client.o
    [43/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_hash.o
    [44/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_mac.o
    [45/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_rsa.o
    [46/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_ecp.o
    [47/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pkcs12.o
    [48/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/psa_crypto_driver_wrappers.o
    [49/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pem.o
    [50/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pkcs5.o
    [51/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pkparse.o
    [52/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/psa_crypto_storage.o
    [53/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/random_ext.o
    [54/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pk.o
    [55/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/cipher.o
    [56/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pkwrite.o
    [57/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/dhm.o
    [58/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/md.o
    [59/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/cipher_wrap.o
    [60/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/sha256.o
    [61/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ripemd160.o
    [62/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/sha1.o
    [63/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/pk_wrap.o
    [64/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/md5.o
    [65/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/sha512.o
    [66/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/chachapoly.o
    [67/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/camellia.o
    [68/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/aesni.o
    [69/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/aria.o
    [70/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/cmac.o
    [71/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ccm.o
    [72/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/des.o
    [73/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ecp.o
    [74/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/hkdf.o
    [75/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ecp_curves.o
    [76/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/gcm.o
    [77/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ecdsa.o
    [78/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/ecdh.o
    [79/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/rsa.o
    [80/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/ecjpake_oberon.o
    [81/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes_oberon.o
    [82/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/rsa_alt_helpers.o
    [83/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/legacy/aes.o
    [84/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/32c5e725ad2d99a575d2d970ed45513b/nordic_nrf/common/core/plat_test.o
    [85/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/crypto_service_mbedcrypto.dir/C_/ncs/v2.2.0/mbedtls/library/hmac_drbg.o
    [86/171] Building C object lib/fih/CMakeFiles/tfm_fih_implementation.dir/src/fih.o
    [87/171] Linking C static library lib\fih\libtfm_fih_implementation.a
    [88/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/tfm_psa_api_veneers.o
    [89/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [90/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [91/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/idle_partition/load_info_idle_sp.o
    [92/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [93/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/common/faults.o
    [94/171] Building ASM object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/nrf9160/gcc/startup_nrf9160_s.o
    [95/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/spm/cmsis_psa/psa_interface_cross.o
    [96/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/interface/src/tfm_psa_call_pack.o
    [97/171] Building C object secure_fw/CMakeFiles/tfm_s.dir/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [98/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/utilities.o
    [99/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_boot_data.o
    [100/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/tfm_core_utils.o
    [101/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch.o
    [102/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/main.o
    [103/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/static_load.o
    [104/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/psa_api.o
    [105/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_ipc.o
    [106/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/spm_cross_call.o
    [107/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_pools.o
    [108/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ns_client_ext/tfm_spm_ns_ctx.o
    [109/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/tfm_core_svcalls_ipc.o
    [110/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/interrupt.o
    [111/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/thread.o
    [112/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/ffm/backend_ipc.o
    [113/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/psa_interface_cross.o
    [114/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/idle_partition.o
    [115/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/cmsis_psa/arch/tfm_arch_v8m_main.o
    [116/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/interface/src/tfm_psa_call_pack.o
    [117/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/ns_agent_tz.o
    [118/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/crypto/auto_generated/load_info_tfm_crypto.o
    [119/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [120/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/ns_agent_tz/load_info_ns_agent_tz.o
    [121/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/partitions/idle_partition/load_info_idle_sp.o
    [122/171] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/generated/secure_fw/partitions/platform/auto_generated/load_info_tfm_platform.o
    [123/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/constant_time.o
    [124/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/platform.o
    [125/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/platform_util.o
    [126/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/padlock.o
    [127/171] Building C object secure_fw/partitions/crypto/mbedcrypto/nrf_security_src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.2.0/mbedtls/library/version.o
    [128/171] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libmbedcrypto_base.a
    [129/171] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/spm/cmsis_psa/psa_interface_cross.o
    [130/171] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/platform_sp.o
    [131/171] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/interface/src/tfm_psa_call_pack.o
    [132/171] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/generated/secure_fw/partitions/platform/auto_generated/intermedia_tfm_platform.o
    [133/171] Building C object secure_fw/partitions/platform/CMakeFiles/tfm_psa_rot_partition_platform.dir/__/__/__/platform/ext/target/nordic_nrf/common/core/plat_test.o
    [134/171] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.o
    [135/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/cmsis_drivers/Driver_Flash.o
    [136/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/nrfx_glue.o
    [137/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_platform_common.o
    [138/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/mpu_armv8m_drv.o
    [139/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/native_drivers/spu.o
    [140/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/tfm_hal_isolation.o
    [141/171] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_nvic.o
    [142/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/spm_hal.o
    [143/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/plat_test.o
    [144/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_platform_hal_ioctl.o
    [145/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/services/src/tfm_ioctl_core_s_api.o
    [146/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/target_cfg.o
    [147/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/core/hw_init.o
    [148/171] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/dummy_provisioning.o
    [149/171] Building C object platform/CMakeFiles/platform_s.dir/ext/target/nordic_nrf/common/nrf9160/tfm_interrupts.o
    [150/171] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/dummy_otp.o
    [151/171] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/tfm_hal_platform.o
    [152/171] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.o
    [153/171] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/common/attest_hal.o
    [154/171] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/src/tfm_platform_system.o
    [155/171] Building C object platform/CMakeFiles/platform_s.dir/C_/ncs/v2.2.0/nrf/modules/tfm/tfm/boards/src/tfm_ioctl_s_api.o
    [156/171] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_platform.o
    [157/171] Building C object platform/CMakeFiles/platform_s.dir/ext/common/tfm_hal_memory_symbols.o
    [158/171] Building C object platform/CMakeFiles/platform_s.dir/__/interface/src/tfm_psa_call_pack.o
    [159/171] Building C object platform/CMakeFiles/platform_s.dir/__/secure_fw/spm/cmsis_psa/psa_interface_cross.o
    [160/171] Linking C static library platform\libplatform_s.a
    [161/171] Linking C static library secure_fw\partitions\platform\libtfm_psa_rot_partition_platform.a
    [162/171] Linking C static library secure_fw\partitions\crypto\mbedcrypto\nrf_security_src\libcrypto_service_mbedcrypto.a
    [163/171] Linking C static library secure_fw\partitions\crypto\libtfm_psa_rot_partition_crypto.a
    [164/171] Linking C static library secure_fw\partitions\lib\sprt\libtfm_sprt.a
    [165/171] Linking C static library secure_fw\spm\libtfm_spm.a
    [166/171] Building C object platform/target/nrf9160/nrf_common/CMakeFiles/tfm_s_scatter.dir/gcc/nordic_nrf_s.ld
    [167/171] Linking C executable bin\tfm_s.axf
    [168/171] Generating ../bin/tfm_s.hex
    [169/171] Generating ../bin/tfm_s.bin
    [170/171] Linking C static library secure_fw\libtfm_s_veneers.a
    [171/171] Generating ../bin/tfm_s.elf
    [69/290] Completed 'mcuboot_subimage'
    [71/290] Performing install step for 'tfm'
    -- Install configuration: "Debug"
    [72/290] Generating zephyr/tfm_secure.hex
    [73/290] Completed 'tfm'
    [74/290] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
    [75/290] Generating include/generated/offsets.h
    [76/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/debug/thread_info.c.obj
    [77/290] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
    [78/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_msg.c.obj
    [79/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/backends/log_backend_uart.c.obj
    [80/290] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
    [81/290] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_secure.c.obj
    [82/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj
    [83/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_output.c.obj
    [84/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/utils/addr_utils.c.obj
    [85/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/getaddrinfo.c.obj
    [86/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_cache.c.obj
    [87/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/state.c.obj
    [88/290] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.2.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
    [89/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_mgmt.c.obj
    [90/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/policy.c.obj
    [91/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/pm/pm.c.obj
    [92/290] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.2.0/nrf/lib/adp536x/adp536x.c.obj
    [93/290] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
    [94/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
    [95/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/socket_offload.c.obj
    [96/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets_select.c.obj
    [97/290] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/zephyr/CMakeFiles/mbedtls_zephyr.dir/C_/ncs/v2.2.0/mbedtls/library/platform.c.obj
    [98/290] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
    [99/290] Generating linker_zephyr_pre0.cmd
    [100/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
    [101/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
    [102/290] Generating linker_zephyr_pre1.cmd
    [103/290] Linking C static library zephyr\arch\common\libisr_tables.a
    [104/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
    [105/290] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
    [106/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
    [107/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
    [108/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
    [109/290] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\zephyr\libmbedtls_zephyr.a
    [110/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
    [111/290] Building C object CMakeFiles/app.dir/src/main.c.obj
    [112/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
    [113/290] Linking C static library zephyr\arch\common\libarch__common.a
    [114/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/net/lib/sockets/sockets.c.obj
    [115/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
    [116/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
    [117/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
    [118/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
    [119/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
    [120/290] Linking C static library app\libapp.a
    [121/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
    [122/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
    [123/290] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
    [124/290] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
    [125/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
    [126/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
    [127/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
    [128/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
    [129/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
    [130/290] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/power.c.obj
    [131/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
    [132/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
    [133/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
    [134/290] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
    [135/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
    [136/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
    [137/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
    [138/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
    [139/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/mpsc_pbuf.c.obj
    [140/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
    [141/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
    [142/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
    [143/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
    [144/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/idle.c.obj
    [145/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
    [146/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
    [147/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mailbox.c.obj
    [148/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/queue.c.obj
    [149/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
    [150/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/stack.c.obj
    [151/290] Linking C static library zephyr\libzephyr.a
    [152/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sem.c.obj
    [153/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/msg_q.c.obj
    [154/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
    [155/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mutex.c.obj
    [156/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/work.c.obj
    [157/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
    [158/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/condvar.c.obj
    [159/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/system_work_q.c.obj
    [160/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
    [161/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
    [162/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
    [163/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
    [164/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/poll.c.obj
    [165/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
    [166/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
    [167/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/sched.c.obj
    [168/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
    [169/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
    [170/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
    [171/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
    [172/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
    [173/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
    [174/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
    [175/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
    [176/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
    [177/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
    [178/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
    [179/290] Linking C static library zephyr\kernel\libkernel.a
    [180/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
    [181/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
    [182/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
    [183/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
    [184/290] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
    [185/290] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
    [186/290] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
    [187/290] Building C object zephyr/lib/libc/newlib/CMakeFiles/lib__libc__newlib.dir/libc-hooks.c.obj
    [188/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
    [189/290] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
    [190/290] Building C object zephyr/boards/boards/arm/thingy91_nrf9160_ns/CMakeFiles/..__nrf__boards__arm__thingy91_nrf9160.dir/nrf52840_reset.c.obj
    [191/290] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_timeout.c.obj
    [192/290] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
    [193/290] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
    [194/290] Linking C static library zephyr\lib\libc\newlib\liblib__libc__newlib.a
    [195/290] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
    [196/290] Building C object zephyr/boards/boards/arm/thingy91_nrf9160_ns/CMakeFiles/..__nrf__boards__arm__thingy91_nrf9160.dir/adp5360_init.c.obj
    [197/290] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
    [198/290] Building C object zephyr/subsys/net/CMakeFiles/subsys__net.dir/buf.c.obj
    [199/290] Building C object zephyr/subsys/random/CMakeFiles/subsys__random.dir/rand32_entropy_device.c.obj
    [200/290] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
    [201/290] Linking C static library zephyr\boards\boards\arm\thingy91_nrf9160_ns\lib..__nrf__boards__arm__thingy91_nrf9160.a
    [202/290] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
    [203/290] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/utils.c.obj
    [204/290] Linking C static library zephyr\subsys\random\libsubsys__random.a
    [205/290] Linking C static library zephyr\subsys\net\libsubsys__net.a
    [206/290] Linking C static library zephyr\drivers\console\libdrivers__console.a
    [207/290] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
    [208/290] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_common.c.obj
    [209/290] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_if.c.obj
    [210/290] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
    [211/290] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
    [212/290] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
    [213/290] Building C object zephyr/subsys/net/ip/CMakeFiles/subsys__net__ip.dir/net_core.c.obj
    [214/290] Building C object zephyr/drivers/entropy/CMakeFiles/drivers__entropy.dir/C_/ncs/v2.2.0/nrf/drivers/entropy/entropy_cc3xx.c.obj
    [215/290] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
    [216/290] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
    [217/290] Building C object zephyr/drivers/i2c/CMakeFiles/drivers__i2c.dir/i2c_nrfx_twim.c.obj
    [218/290] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
    [219/290] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
    [220/290] Linking C static library zephyr\drivers\entropy\libdrivers__entropy.a
    [221/290] Linking C static library zephyr\subsys\net\ip\libsubsys__net__ip.a
    [222/290] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
    [223/290] Building C object zephyr/drivers/spi/CMakeFiles/drivers__spi.dir/spi_nrfx_spim.c.obj
    [224/290] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
    [225/290] Linking C static library zephyr\drivers\i2c\libdrivers__i2c.a
    [226/290] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
    [227/290] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/fault.c.obj
    [228/290] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_lib.c.obj
    [229/290] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf91_sockets.c.obj
    [230/290] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/nrf_modem_os.c.obj
    [231/290] Linking C static library zephyr\drivers\spi\libdrivers__spi.a
    [232/290] Building C object modules/nrf/lib/nrf_modem_lib/CMakeFiles/..__nrf__lib__nrf_modem_lib.dir/sanity.c.obj
    [233/290] Building C object modules/nrf/lib/at_cmd_parser/CMakeFiles/..__nrf__lib__at_cmd_parser.dir/at_params.c.obj
    [234/290] Building C object modules/nrf/lib/at_monitor/CMakeFiles/..__nrf__lib__at_monitor.dir/at_monitor.c.obj
    [235/290] Building C object modules/nrf/lib/at_cmd_parser/CMakeFiles/..__nrf__lib__at_cmd_parser.dir/at_cmd_parser.c.obj
    [236/290] Building C object modules/nrf/lib/dk_buttons_and_leds/CMakeFiles/..__nrf__lib__dk_buttons_and_leds.dir/dk_buttons_and_leds.c.obj
    [237/290] Building C object modules/nrf/lib/at_host/CMakeFiles/..__nrf__lib__at_host.dir/at_host.c.obj
    [238/290] Building C object modules/nrf/lib/lte_link_control/CMakeFiles/..__nrf__lib__lte_link_control.dir/lte_lc_modem_hooks.c.obj
    [239/290] Linking C static library modules\nrf\lib\nrf_modem_lib\lib..__nrf__lib__nrf_modem_lib.a
    [240/290] Linking C static library modules\nrf\lib\at_monitor\lib..__nrf__lib__at_monitor.a
    [241/290] Linking C static library modules\nrf\lib\at_cmd_parser\lib..__nrf__lib__at_cmd_parser.a
    [242/290] Building C object modules/nrf/lib/modem_antenna/CMakeFiles/..__nrf__lib__modem_antenna.dir/modem_antenna.c.obj
    [243/290] Linking C static library modules\nrf\lib\dk_buttons_and_leds\lib..__nrf__lib__dk_buttons_and_leds.a
    [244/290] Linking C static library modules\nrf\lib\at_host\lib..__nrf__lib__at_host.a
    [245/290] Building C object modules/nrf/modules/tfm/zephyr/CMakeFiles/tfm_api_nrf.dir/__/tfm/boards/src/tfm_ioctl_ns_api.c.obj
    [246/290] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_platform_ipc_api.c.obj
    [247/290] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
    [248/290] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/src/zephyr_tfm_log.c.obj
    [249/290] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_psa_ns_api.c.obj
    [250/290] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/interface/interface.c.obj
    [251/290] Linking C static library modules\nrf\lib\modem_antenna\lib..__nrf__lib__modem_antenna.a
    [252/290] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_ioctl_core_ns_api.c.obj
    [253/290] Linking C static library modules\nrf\modules\tfm\zephyr\libtfm_api_nrf.a
    [254/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/mdk/system_nrf9160.c.obj
    [255/290] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
    [256/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
    [257/290] Building C object modules/trusted-firmware-m/CMakeFiles/tfm_api.dir/__/__/tfm/install/interface/src/tfm_crypto_ipc_api.c.obj
    [258/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
    [259/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_ipc.c.obj
    [260/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
    [261/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
    [262/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twi_twim.c.obj
    [263/290] Linking C static library modules\trusted-firmware-m\libtfm_api.a
    [264/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_spim.c.obj
    [265/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
    [266/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.2.0/modules/hal/nordic/nrfx/drivers/src/nrfx_twim.c.obj
    [267/290] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
    [268/290] Building C object modules/nrf/lib/lte_link_control/CMakeFiles/..__nrf__lib__lte_link_control.dir/lte_lc_helpers.c.obj
    [269/290] Building C object modules/nrf/lib/lte_link_control/CMakeFiles/..__nrf__lib__lte_link_control.dir/lte_lc.c.obj
    [270/290] Linking C static library modules\nrf\lib\lte_link_control\lib..__nrf__lib__lte_link_control.a
    [271/290] Linking C executable zephyr\zephyr_pre0.elf
    [272/290] Generating dev_handles.c
    [273/290] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
    [274/290] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
    [275/290] Linking C executable zephyr\zephyr_pre1.elf
    [276/290] Generating linker.cmd
    [277/290] Generating isr_tables.c, isrList.bin
    [278/290] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
    [279/290] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
    [280/290] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
    [281/290] Linking C executable zephyr\zephyr.elf
               FLASH:      112588 B     380416 B     29.60%
                 RAM:       24424 B     211736 B     11.54%
    [282/290] Generating zephyr/tfm_nonsecure.hex
    [283/290] Generating zephyr/mcuboot_primary_app.hex
    [284/290] Generating zephyr/mcuboot_primary.hex
    [285/290] Generating ../../zephyr/app_update.bin
    sign the payload
    [286/290] Generating ../../zephyr/dfu_application.zip
    [287/290] Generating ../../zephyr/app_signed.hex
    sign the payload
    [288/290] Generating ../../zephyr/app_test_update.hex
    sign the payload
    [289/290] Generating ../../zephyr/app_moved_test_update.hex
    [290/290] Generating zephyr/merged.hex
    I'll post the re-install log when I get it.
