nRF Connect SDK Linux Installation & Compiling Failure
I installed nRF Connect SDK manually by following the instruction in this page. I had 2 problems but I did a trick and it seems it solved for now. However I need to know for the future.
OS: Ubuntu 22.04
ncs: In home directory and the structure is lie below.
ncs
 |___ .west
 |___ bootloader
 |___ modules
 |___ nrf
 |___ nrfxlib
 |___ zephyr
 |___ ...
SDK: In home directory with the name like zephyr-sdk-0.14.1 and also isntalled 0.15.1 at the same time. However VSCode has given an error that v2.2.0 requires zephyr-sdk-0.15.1. It couldn't detect automatically. I have checked the $PATH env. var. There is no toolchain variable in it, but I don't understand how VScode can find 0.14.1. Anyway I renamed folders 0.14.1 to 0.15.1 and 0.15.1 to 0.14.1. Now VSCode doesn't give any error and it accepts. It seems that this problem has been solved temporarily.
The setting VSCode extention:
nRF Connect SDK: 2.2.0 (/home/soz/ncs)        => as detected
nRF Connect Toolchain: PATH (Zephyr SDK: /home/soz/zephyr-sdk-0.14.1)     => as detected. 0.15.1 couldn't detected so as mentioned above renamed folder.
Output of PATH env.
soz@salihonur-lnx:~/ncs/zephyr$ echo $PATH
/home/soz/ncs/zephyr/scripts:/home/soz/.local/bin:/home/soz/gn:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/snap/bin:/home/soz/nRF52/gcc-arm/bin
Output of ZEPHYR_BASE variable:
soz@salihonur-lnx:~$ echo $ZEPHYR_BASE
soz@salihonur-lnx:~$ cd ncs/zephyr/
soz@salihonur-lnx:~/ncs/zephyr$ source zephyr-env.sh
soz@salihonur-lnx:~/ncs/zephyr$ echo $ZEPHYR_BASE
soz@salihonur-lnx:~/ncs/zephyr$ echo $BOARD
soz@salihonur-lnx:~/ncs/zephyr$ echo $CONF_FILE
soz@salihonur-lnx:~/ncs/zephyr$ echo $DTS_OVERLAY_FILE
Error of compling "blinky" example in VSCode:
Building blinky
west build --build-dir /home/soz/ELEKTRONIK/Test/blinky/build_1 /home/soz/ELEKTRONIK/Test/blinky --pristine --board nrf52840dongle_nrf52840 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="/home/soz/ELEKTRONIK/Test/blinky/prj.conf"
STATUS,XXXXX:
-- Application: /home/soz/ELEKTRONIK/Test/blinky
-- Found Python3: /usr/bin/python3.10 (found suitable exact version "3.10.6") found components: Interpreter
-- Cache files will be written to: /home/soz/.cache/zephyr
-- Zephyr version: 3.2.99 (/home/soz/ncs/zephyr)
-- Board: nrf52840dongle_nrf52840
-- Found host-tools: zephyr 0.15.1 (/home/soz/zephyr-sdk-0.14.1)
-- Found toolchain: zephyr 0.15.1 (/home/soz/zephyr-sdk-0.14.1)
-- Found Dtc: /home/soz/zephyr-sdk-0.14.1/sysroots/x86_64-pokysdk-linux/usr/bin/dtc (Required is at least version "1.4.6")
-- Found BOARD.dts: /home/soz/ncs/zephyr/boards/arm/nrf52840dongle_nrf52840/nrf52840dongle_nrf52840.dts
-- Generated zephyr.dts: /home/soz/ELEKTRONIK/Test/blinky/build_1/zephyr/zephyr.dts
-- Generated devicetree_generated.h: /home/soz/ELEKTRONIK/Test/blinky/build_1/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: /home/soz/ELEKTRONIK/Test/blinky/build_1/zephyr/dts.cmake
CMake Error at /home/soz/ncs/zephyr/cmake/modules/dts.cmake:308 (message):
  command failed with return code: No such file or directory
  /home/soz/ncs/zephyr/cmake/modules/zephyr_default.cmake:108 (include)
  /home/soz/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:67 (include)
  /home/soz/ncs/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:93 (include_boilerplate)
  CMakeLists.txt:4 (find_package)
FATAL ERROR: command exited with status 1: /home/soz/.local/bin/cmake -DWEST_PYTHON=/usr/bin/python3 -B/home/soz/ELEKTRONIK/Test/blinky/build_1 -GNinja -DBOARD=nrf52840dongle_nrf52840 -DNCS_TOOLCHAIN_VERSION:STRING=NONE -DCONF_FILE:STRING=/home/soz/ELEKTRONIK/Test/blinky/prj.conf -S/home/soz/ELEKTRONIK/Test/blinky
Questions:
  1. I guess the compiler can't find PATH variables. Only ZEPHYR_BASE variable comes if "source zephyr-env.sh" is executed. What are the default location of these variables below? I can define them manually.
    BOARD
    CONF_FILE
    SHIELD
    ZEPHYR_BASE
    ZEPHYR_EXTRA_MODULES
    ZEPHYR_MODULES
    ZEPHYR_BOARD_ALIASES
    ZEPHYR_SDK_INSTALL_DIR
    ZEPHYR_TOOLCHAIN_VARIANT
    {TOOLCHAIN}_TOOLCHAIN_PATH
  2. Where can I change the toolchain path?
  • Salih Onur ZORLU said:
    I will try another installation on a virtual machine and I will record it. I can upload it to Youtube and share the link as well.
    This would be very useful indeed!
    If you intend to use a virtual machine to do this, maybe do one for using our Automatic install instead of the manual install also?
    The Toolchain Manager should be quite fast, and it would be interesting to see if it works.
    Happy new year!
    Sigurd Hellesvik
  • Hi Sigurd,
    I already installed it with automatic tool. Unfortunately it didn't work and then I tried to fix it manually.
    I recorded 2 videos and saw that teh problem is caused by the automatic installation. I don't know if I did something wrong. Please check it.
    In fact, there is a missing point in the manual installation guide that VSCode gives an error about missing nrfjprog even if nRF Command Line Tools is already installed (with deb file in Ubuntu 22.04). Segger JLink support has to be installed seperately.
    I re-installed Ubuntu OS on my computer and did nRF manual installation. It works properly now.
    PS: The videos can only be accessed via the link. It is unlisted on Youtube.
    Automatic installation:
    Manual installation:
    I will have a look at these videos at Wednesday.
    Sigurd Hellesvik
    To use the command line from the Toolchain Manager, it is easier to open a terminal from the Toolchain Manager, to get all the environment variables set correctly:
    For Linux this should say "Open Terminal" instead I think.
    Here. I think you should start by installing JLink from the J-Link Software and Documentation Pack.
    I agree that this should be better documented. But if you got time, give it a try and see if it works.
    If you are still missing nrfjprog after, you can install it from https://www.nordicsemi.com/Products/Development-tools/nrf-command-line-tools
    From the Manual Installation, it seems like things are working fine, except for the jlink and nrfjprog error. Right?
    For information: JLink and nrfjprog are used to flash and debug the device.
    You will be able to build project withouth these, just not flash them to the device.
    Sigurd Hellesvik
  • Hi Sigurd,
    I would like to split cases for the clear information. By the way, I re-installed Ubuntu OS and SDK manually for the frash installation including Jlink and Command Line Tools. Now I have no problem anymore.
    Case #1: Manual installation at first time
    All works fine (of course Jlink and Command Line Tools should be install for the programming)
    Projects can be compiled if it is in any level sub-folders in the SDK root folder (here it is ${HOME}/ncs
    If you want to work in different workspace for example ${HOME}/My Projects, then you need to add these environment variables into ~/.bashrc file like below. Otherwise you get west build command not found error.
    export ZEPHYR_TOOLCHAIN_VARIANT=zephyr
    export ZEPHYR_BASE=${HOME}/ncs/zephyr
    I tried all thing in direct access console, not from Toolchain Manager (Open Command Prompt or similar). Enviroment variables might be set automatically, sorry I have no experience about that.
    Case #2: Automatic installation
    Nothing works. An error occurs like the video. Somtimes VSCode can't find the SDK root.
    Case #3: Manual installation to fix after automatic installation
    Nothing works. Only good thing is that VSCode can find the SDK root itself however still the project can not be compiled even if I follow step exactly described in manual installation.
    Note: The problem about automatic installation might be caused about the OS language or date/time format or number format. I have seen such kind of inconsistency in different platforms. For example I get an error with an MS Excel add-in because of number format (in Windows). The add-in supports the decimal and thousands point like "1,000.00" but in Turkish it is used like "1.000,00". Please consider it.
