Activate GNSS while connected on lte-m or nb-iot on nrf9160
Hi there.
I am currently developing a simple asset tracker based on several examples using nrf9160 custom board.
So I am using several examples like mqtt_simple, gnss, and location. All of those locations are works on my custom boards because it is compiled as nrf9160dk.
So, the way I want this works are first it is getting a location, then publish the raw data location (gnss or cellular) to the mqtt. But after combining several those code, I got error that gnss couldn't works when LTE-M or/and NB-IOT Activated. So below is the result for rtt viewer from my firmware.
00> * Booting Zephyr OS build v3.2.99-ncs1 *
00> init fw`
00>
00> Configuring time
00> Configuring modem.
00> Enabling PSM
00> Disabling EDRX
00> LTE services init.
00> Connect to network
00> Connected to LTE
00> Connected to the network!
00>
00> Client init IPv4 Address found 3.228.54.173Broker : broker.emqx.io
00> Port : 1883
00> client_id = palmlab_thingy91--> success.
00> mqtt connect --> success.
00> fds init --> success.
00> Create poll fds --> success.
00> create mqtt live --> success.
00> create mqtt input MQTT client connectedSubscribing to: palmlab/pettracker/subscribe len 28
00> Waiting for current time
00> Sending ping message --> success.
00> Init location handler --> success.
00> Init sample --> success.
00> Gnss init and start --> success.
00> Tracking:  0 Using:  0 Unhealthy: 0
00> GNSS operation blocked by LTE
00> -----------------------------------
00> Seconds since last fix: 0
00> Searching [|]
00>
00> NMEA strings:
00>
00> Seconds since last fix: 1
00> Searching [/]
00>
00> NMEA strings:
00>
00> Seconds since last fix: 2
00> Searching [-]
00>
00> NMEA strings:
00>
00> Seconds since last fix: 3
00> Searching [\]
00>
00> NMEA strings:
00>
00> Seconds since last fix: 4
00> Searching [|]
00>
00> NMEA strings:
00>
00> Seconds since last fix: 5
00> Searching [/]
00>
00> NMEA strings:
00>
00> Seconds since last fix: 6
00> Searching [-]
00>
00> NMEA strings:
00>
00> Seconds since last fix: 7
00> Searching [\]
00>
00> NMEA strings:
00>
00> Searching [|]
00>
00> NMEA strings:
00>
00> $GPGGA,000045.77,,,,,0,,99.99,,M,,M,,*67
00>
00> $GPGLL,,,,,000045.77,V,N*4B
00>
00> $GPGSA,A,1,,,,,,,,,,,,,99.99,99.99,99.99,1*2D
00>
00> $GPGSV,1,1,0,,,,,,,,,,,,,,,,,1*54
00>
00> $GPRMC,000045.77,V,,,,,,,060180,,,N,V*09
00>
00> Seconds since last fix: 8
00> Searching [/]
00>
00> NMEA strings:
00>
00> $GPGGA,000046.77,,,,,0,,99.99,,M,,M,,*64
00>
00> $GPGLL,,,,,000046.77,V,N*48
00>
00>
00>
00> $GPRMC,000046.77,V,,,,,,,060180,,,N,V*0A
00>
00> Seconds since last fix: 9
00> Searching [-]
00>
00> NMEA strings:
00>
00> $GPGGA,000047.77,,,,,0,,99.99,,M,,M,,*65
00>
00> $GPGLL,,,,,000047.77,V,N*49
00>
00>
00>
00> $GPRMC,000047.77,V,,,,,,,060180,,,N,V*0B
00>
00> Seconds since last fix: 10
00> Searching [\]
00>
00> NMEA strings:
00>
00> $GPGGA,000048.77,,,,,0,,99.99,,M,,M,,*6A
00>
00> $GPGLL,,,,,000048.77,V,N*46
00>
00> ,1*2D
00>
00>
00>
00> Searching [\]
00>
00> NMEA strings:
00>
00>
00>
00> init fw
00> Pet Tracker Started
00>
00> Enabling PSM
00> Disabling EDRX
As you can see, at the first it is connecting to the network service. After that publishing ping message for indicate it is alive. But when it is trying to connect to the services, I got error like GNSS operation blocked by LTE or sometime Insufficient GNSS time windows.
I read some solution iin this forum like enable PSM configuration but I already did that and still same.
Anybody have experience or solution with this? Thank you very much and really appreciate if there is any suggestion for this, thanks again.
