Multiple ADC reading - NCS
Hello everyone!
I'm trying to read 4 channels of ADC, and for future production, I'd have to read all 8.
There is two channels example, yet it isn't scalable. I'm thinking about building a dynamic setup based on the example, but it doesn't go so well due to the limits of specific macros in the given example code.
  • I updated the code, and now it's compiling well, but when trying to see the nRF Terminal, I'm getting the following logs.
    *** Booting Zephyr OS build v2.7.99-ncs1-1  ***
    Device binded to ADC_0
    [00:00:00.257,568] <err> os: ***** MPU FAULT *****
    [00:00:00.257,568] <err> os:   Instruction Access Violation
    [00:00:00.257,568] <err> os: r0/a1:  0x00000000  r1/a2:  0x20001958  r2/a3:  0x54f7fab5
    [00:00:00.257,568] <err> os: r3/a4:  0x20001958 r12/ip:  0x00000000 r14/lr:  0x00000407
    [00:00:00.257,598] <err> os:  xpsr:  0x61000000
    [00:00:00.257,598] <err> os: Faulting instruction address (r15/pc): 0x54f7fab4
    [00:00:00.257,598] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0
    [00:00:00.257,629] <err> os: Current thread: 0x20000420 (main)
    [00:00:01.207,336] <err> fatal_error: Resetting system
    The code now:
    adc_4_v3.zip
  • Hi
    The MPU fault is caused by the way you assign the device pointer.
    If you want to provide a pointer back to the caller of the function you should pass a pointer to the pointer to the function. In your code you will simply assign the ADC device pointer to the local dev variable in the function, adc_dev will not be updated.
    Also, on an error you return the ret variable, which is unassigned. This is also incorrect (but not the problem here).
    The code snippet below corrects these issues:
    static int adc_setup_meh(const struct device **dev)
        //ADC0 setup
        *dev = device_get_binding(ADC_DEVICE_NAME);
    	if (!dev) {
            printk("device_get_binding ADC_0 (=%s) failed\n", ADC_DEVICE_NAME);
            return -1;
        return 0;
    And then you need to call the function like this:
    err = adc_setup_meh(&adc_dev);
    Best regards
    Torbjørn
  • I'm not sure what happened, but I've upgraded my SDK to v2.2.0 and used the format from the ADC sample, which is now working. Thanks for your help :)
  • You welcome, good to hear you figured it out Slight smile
