FOTA update HTTP
I am trying to load an application update from a server into external flash, the download itself is working but mcuboot is not:
<err> dfu_target_mcuboot: boot_request_upgrade for image-0 error -14
<err> fota_download: dfu_target_done error: -14
I need to use the external flash because the application is already too big to fit into the internal one (with bootloader, primary & secondary partition).
External flash
	chosen {
		zephyr,flash = &flash0;
		zephyr,sram = &sram0_ns;
		zephyr,code-partition = &slot0_ns_partition;
		nordic,pm-ext-flash = &mx25r64;
flash_spi: &spi1 {
	status = "okay";
	pinctrl-0 = <&spi1_default_alt>;
	pinctrl-1 = <&spi1_sleep_alt>;
	cs-gpios = <&gpio0 25 GPIO_ACTIVE_LOW>;
	mx25r64: mx25r6435f@0 {
		compatible = "jedec,spi-nor";
		reg = <0>;
		spi-max-frequency = <80000000>;
		label = "MX25R64";
		jedec-id = [c2 28 17];
		size = <67108864>;        // 0x4000000
This seems to be working, if I exclude the external flash than build fails with the hint that the size is not sufficient.
Also test functions from the spi_flash example are principially working (but not contained in the main application).
MCUboot
prj.conf:
# Image manager
CONFIG_FLASH=y
CONFIG_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# FOTA library
CONFIG_FOTA_DOWNLOAD=y
# Download client
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
# DFU Target
CONFIG_DFU_TARGET=y
# Application Upgrade support
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_MCUBOOT_SHELL=y
child_image/mcuboot/prj.conf:
# MCUboot requires a large stack size, otherwise an MPU fault will occur
CONFIG_MAIN_STACK_SIZE=10240
CONFIG_DEBUG_OPTIMIZATIONS=y
# Enable flash operations
CONFIG_FLASH=y
# This must be increased to accommodate the bigger images.
CONFIG_BOOT_MAX_IMG_SECTORS=256
# Enable serial recovery
CONFIG_UART_CONSOLE=y
CONFIG_MCUBOOT_SERIAL=n
CONFIG_MCUBOOT_SERIAL_DIRECT_IMAGE_UPLOAD=n
MCUboot seems to be working:
*** Booting Zephyr OS build v3.1.99-ncs1-1  ***
Also the file build/zephyr/app_update.bin is generated.
From the mcuboot command shell I get the same error, although I am not sure if the operation is the same:
mcuboot request_upgrade
failed to request upgrade: -14
I have also tryd to use the application_update example without any modifications, but due to the filesize it is not working:
Requested file too big to fit in flash 577112 > 0x78000
Partitions
My main suspicion is that the partitions are not configured correctly, I have tried several configurations here, for example pm.yml:
 mcuboot_secondary:
  address: 0x0
  device: mx25r6435f
  end_address: 0xf0000
  placement:
    align:
      start: 0x000
  region: external_flash
which results in partitions.yml
mcuboot_primary_app:
  address: 0xc200
  end_address: 0xf2000
  orig_span: &id002
  - app
  - tfm
  region: flash_primary
  span: *id002
mcuboot_secondary:
  address: 0x0
  device: /soc/peripheral@40000000/spi@9000/mx25r6435f@0
  end_address: 0xe6000
  placement:
    align:
      start: 0x4
  share_size:
  - mcuboot_primary
I found this somewhere but actually it seems if I add nothing at all the result will be the same.
FOTA
The FOTA functions are already strongly reduced (since modem is already set up in main application):
static void update_sample_start(void)
	int err;
	err = fota_download_start(HTTPS_URL_FOTA, HTTPS_TARGET_FOTA, -1, 0, 0);   // HTTP
	if (err != 0) {
		printk("fota_download_start() failed, err %d\n", err);
static void update_sample_done(void)
	lte_lc_deinit();
static void fota_dl_handler(const struct fota_download_evt *evt)
	switch (evt->id) {
	case FOTA_DOWNLOAD_EVT_ERROR:
		printk("Received error from fota_download\n");
	case FOTA_DOWNLOAD_EVT_FINISHED:
		update_sample_done();
		printk("Press 'Reset' button or enter 'reset' to apply new firmware\n");
void application_update_main(void)
	int err;
	err = fota_download_init(fota_dl_handler);
	if(err != 0) {
		printk("fota_download_init() failed, err %d\n", err);
		return;
	update_sample_start();
I am grateful for every hint and wish you happy holidays!
Bernhard
