bluetooth samples central_nfc_pairing and peripheral_nfc_pairing run fail
I run the ncs v2.2.0 nfc samples central_nfc_pairing(nRF5340 with nfc reader) and peripheral_nfc_pairing(nRF52832 with nfc tag), but pairing failed.
I attached the log files, can you tell me how to fix it?
*** Booting Zephyr OS build v3.2.99-ncs1 ***
Starting NFC Central Pairing example
I: 2 Sectors of 4096 bytes
I: alloc wra: 0, fd0
I: data wra: 0, 1c
I: No ID address. App must call settings_load()
Bluetooth initialized
Generating new pairing keys.
NFC field on.
Anticollision: 0x44 Platform: 0x0.
Tag info, type: 1.
Type 4 Tag.
NFC T4T selected.
NFC T4T app select err 1.
I: R-APDU status: 9000
I: R-APDU no data field present.
NFC T4T NDEF Application selected.
I: Capability Container Select Procedure
NFC T4T Capability Container file selected.
I: R-APDU data:
I: R_APDU data:
I: 00 0f 20 00 f8 00 f8 04 |.. .....
I: 06 e1 04 04 00 00 00    |.......
NFC T4T Capability Container file read.
NFC T4T NDEF file selected.
I: R-APDU daa:
I: R_APDU data:
I: 00 bc                   |..
I: R-APDU data:
I: R_APDU data:
I: 81 02 00 00 00 0d 48 73 |......Hs
I: 15 c1 02 00 00 00 04 61 |.......a
I: 63 01 01 30 00 0a 20 00 |c..0.. .
I: 00 00 5d 01 61 70 70 6c |..].appl
I: 69 63 61 74 69 6f 6e 2f |ication/
I: 76 6e 64 2e 62 6c 75 65 |vnd.blue
I: 74 6f 6f 74 68 2e 6c 65 |tooth.le
I: 2e 6f 6f 62 30 08 1b fc |.oob0...
I: cb 90 8a 69 c1 01 02 1c |...i....
I: 00 11 10 70 5e d3 7a c3 |...p^.z.
I: 93 de 09 8b 42 d1 8d 7c |....B..|
I: 9b a7 bd 11 22 87 70 e9 |....".p.
I: c8 f6 e1 73 88 cc d1 e4 |...s....
I: 54 67 74 e5 51 11 23 73 |Tgt.Q.#s
I: 1d 90 44 50 07 8c 66 ec |..DP..f.
I: 3b b0 e3 25 40 0e 72 03 |;..%@.r.
I: 19 00 00 02 01 04 13 09 |........
I: 4e 6f 72 64 69 63 5f 4e |Nordic_N
I: 46 43 5f 70 61 69 72 69 |FC_pairi
I: 6e 67 41 02 00 00 00 1a |ngA.....
I: 54 70 10 13 75 72 6e 3a |Tp..urn:
I: 6e 66 63 3a 73 6e 3a 68 |nfc:sn:h
I: 61 6e 64 6f 76 65 72 00 |andover.
I: 2c 02 04 00             |,...
NDEF file read, id: 0xe104.
I: Capability Container File content:
I: CCLEN: 15
I: Mapping Version: 2.0
I: MLe: 248
I: MLc: 248
I: Capability Container File contains 1 File Control TLV block(s).
I: 0 file Control TLV
I: Type: NDEF File Control (0x04)
I: Length (in bytes): 6
I: File Identifier: 0xE104
I: Maximum file size: 1024
I: Read access condition: 0x00
I: Write access condition: 0x00
I: NDEF file content present. Length: 190
I: NDEF file content:
I: 00 bc 81 02 00 00 00 0d |........
I: 48 73 15 c1 02 00 00 00 |Hs......
I: 04 61 63 01 01 30 00 0a |.ac..0..
I: 20 00 00 00 5d 01 61 70 | ...].ap
I: 70 6c 69 63 61 74 69 6f |plicatio
I: 6e 2f 76 6e 64 2e 62 6c |n/vnd.bl
I: 75 65 74 6f 6f 74 68 2e |uetooth.
I: 6c 65 2e 6f 6f 62 30 08 |le.oob0.
I: 1b fc cb 90 8a 69 c1 01 |.....i..
I: 02 1c 00 11 10 70 5e d3 |.....p^.
I: 7a c3 93 de 09 8b 42 d1 |z.....B.
I: 8d 7c 9b a7 bd 11 22 87 |.|....".
I: 70 e9 c8 f6 e1 73 88 cc |p....s..
I: d1 e4 54 67 74 e5 51 11 |..Tgt.Q.
I: 23 73 1d 90 44 50 07 8c |#s..DP..
I: 66 ec 3b b0 e3 25 40 0e |f.;..%@.
I: 72 03 19 00 00 02 01 04 |r.......
I: 13 09 4e 6f 72 64 69 63 |..Nordic
I: 5f 4e 46 43 5f 70 61 69 |_NFC_pai
I: 72 69 6e 67 41 02 00 00 |ringA...
I: 00 1a 54 70 10 13 75 72 |..Tp..ur
I: 6e 3a 6e 66 63 3a 73 6e |n:nfc:sn
I: 3a 68 61 6e 64 6f 76 65 |:handove
I: 72 00 2c 02 04 00       |r.,...
TNEP Service count: 1
TNEP Connection Handover service found.
NFC T4T NDEF file contains the TNEP Initial Message selected.
TNEP error: 1.
I: R-APDU data:
I: R_APDU data:
I: 00 09                   |..
I: R-APDU data:
I: R_APDU data:
I: c1 02 00 00 00 01 54 65 |......Te
I: 00                      |.
TNEP error: 1.
I: R-APDU data:
I: R_APDU data:
I: 03 fe                   |..
I: R-APDU data:
I: R_APDU data:
I: 00 00 00 00 00 00 00 00 |........
I: R-APDU data:
I: R_APDU data:
I: 00 00 00 00 00 00 |........
NFC Type 4 Tag HL data received error: -12.
Starting Bluetooth NFC Pairing Reference example
I: 6 Sectors of 4096 bytes
I: data wra: 0, 1c
I: SoftDevice Controller build revision:
I: 6d 90 41 2a 38 e8 ad 17 |m.A*8...
I: 29 a5 03 38 39 27 d7 85 |)..89'..
I: 1f 85 d8 e1             |....
NFC configuration done
Regular advertising started
No Alternative Carrier Record for OOB LE carrier
