Installing OTBR manually (Raspberry Pi) instructions fail
In
    https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.2.0/nrf/ug_thread_tools.html#installing-otbr-manually-raspberry-pi
bulding the "compatible" version 0895ad5 with:
INFRA_IF_NAME=eth0 ./script/setup
fails with:
+ sudo systemctl enable otbr-firewall
otbr-firewall.service is not a native service, redirecting to systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable otbr-firewall
+ sudo systemctl start otbr-firewall
Job for otbr-firewall.service failed because the control process exited with error code.
See "systemctl status otbr-firewall.service" and "journalctl -xe" for details.
+ die 'Failed to start firewall service!'
+ echo ' *** ERROR:  Failed to start firewall service!'
+ exit 1
Since 0895ad5 was explicitly suggested in the nordic link above, what now?
For more background, see:
https://github.com/openthread/ot-br-posix/issues/1687
    I will follow the guide you're using and see if I find error you're describing, but it will unfortunately have to wait until after new years as we're a bit short on staff during the Christmas holidays. In the mean while, could you state which version of the Raspberry Pi you're using?
    Andreas
  • Hi again,
    Following the OTBR install guide from https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/matter/openthread_border_router_pi.html leaves me with a working OTBR. I haven't yet verified if there are any complications by using version 0895ad5 from the guide you mention from the openthread-documentation so I will do that next. Have you attempted to build the router without checking out version 0895ad5?
    And also, if you've solved the issue since my last response, please let me know!
    Andreas
  • I've been using Pi 3 with the old raspios image specified in the OT codelab.  With some reboots... I think it is working now.
    Biggest problem as I see it is examples asking for specific versions of different operating systems -- OTBR will work only with  old raspio, and chip-tool will only work with ubuntu running on a rasperrypi 64 bit.
    Still working on getting the OTBR to work with matter.
    We're still not seeing any issues with RPi v3 and/or v4 with either  the master branch (git clone github.com/.../ot-br-posix.git --depth 1 ) or the verified and tested branch mentioned in the Open Thread OTBR guide (git checkout 0895ad5). 8095ad5 is the one we've tested the OTBR up against with our samples, which is why this is mentioned in the documentation.
    If you're still working on getting the OTBR to work with Matter and if you've not already seen this resource, I suggest you have a look at https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/ug_matter_gs_testing_thread_one_otbr.html. If you've already seen it, feel free to ask questions that might lead you to getting everything up and running
    Some of the requirements according to the above mentioned guide is
    One of the following:
    • 1x PC with Ubuntu (20.04 or newer)
    • 1x Raspberry Pi Model 3B+ or newer with Ubuntu (20.04 or newer) instead of Raspbian OS
    So you will have to use Ubuntu 20.04 or newer to get it to work with chip tool.
    Let me know you have additional questions related to this case or if we can close this case
    Andreas
  • Thank you for the additional link.
    The build finishes and status of system daemons appear acceptable.  After a while CHIP actions result in errors with a brtr-3.  I've no idea where the -3 is coming from -- the pi running OTBR has a name of brtr.  In OpenThread sites, I've not yet stumbled opon useful howto's of how to debug issues with OTBR, SRP, diagnose network issues, and etc.  IE, what to do and what to check when the build "recipes" appear to work but the result doesn't.
    Thank you for re-verifying.  I will suggest a reply as an answer and accept.
