nRF52-DK Suddenly stopped flashing
I got a new nRF52DK, started working with it. After Blinky example, I tried UART example.
UART program is working fine. But Now i can't reprogram DK.
I tried to recovery, bit still failed.
$ nrfjprog --recover
Recovering device. This operation might take 30s.
[error] [ nRF52] - Access protection is enabled, can't read device version.
ERROR: Recover failed. Please make sure that the correct device family is given
ERROR: and try again.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
Please let me know the solution.
  • Log file --
    [2022-Dec-30 16:25:03] [debug] --------------------------------------------------------------------------------
    [2022-Dec-30 16:25:03] [debug] nrfjprog --log --family nrf52 --recover
    [2022-Dec-30 16:25:03] [debug] nrfjprog version 10.18.1 external
    [2022-Dec-30 16:25:03] [ info] Load library at C:\Program Files (x86)\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2022-Dec-30 16:25:03] [ info] Library loaded, loading member functions.
    [2022-Dec-30 16:25:03] [ info] Member functions succesfully loaded.
    [2022-Dec-30 16:25:03] [debug] [ Client] - open
    [2022-Dec-30 16:25:03] [debug] [ Client] - start
    [2022-Dec-30 16:25:03] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 2f2b34f9-7191-42eb-9936-f3a3a7fe3483.
    [2022-Dec-30 16:25:03] [trace] [ Client] - Command open executed for 65 milliseconds with result 0
    [2022-Dec-30 16:25:03] [debug] [ Client] - config
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2022-Dec-30 16:25:03] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
    [2022-Dec-30 16:25:03] [debug] [ JLink] - Logger sink registered in JLink logger
    [2022-Dec-30 16:25:03] [debug] [ Client] - enum_emu_snr
    [2022-Dec-30 16:25:03] [debug] [ nRF52] - open
    [2022-Dec-30 16:25:03] [debug] [ nRF52] - just_check_family
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - open_dll
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2022-Dec-30 16:25:03] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink\JLinkARM.dll.
    [2022-Dec-30 16:25:03] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2022-Dec-30 16:25:03] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - Set batch mode
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - dll_version
    [2022-Dec-30 16:25:03] [ info] [SeggerBackend] - Segger dll version 7.82.f loaded.
    [2022-Dec-30 16:25:03] [trace] [ Worker] - Command open executed for 10 milliseconds with result 0
    [2022-Dec-30 16:25:03] [debug] [ nRF52] - config
    [2022-Dec-30 16:25:03] [trace] [ Worker] - Command config executed for 7 milliseconds with result 0
    [2022-Dec-30 16:25:03] [trace] [ Client] - Command enum_emu_con_info executed for 16 milliseconds with result 0
    [2022-Dec-30 16:25:03] [debug] [ Client] - connect_to_emu_with_snr
    [2022-Dec-30 16:25:03] [debug] [ nRF52] - enum_emu_con_info
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - is_connected_to_emu
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - enum_emu_con_info
    [2022-Dec-30 16:25:03] [trace] [ Worker] - Command enum_emu_con_info executed for 4 milliseconds with result 0
    [2022-Dec-30 16:25:03] [debug] [ nRF52] - connect_to_emu_with_snr
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - ---just_get_num_emus
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2022-Dec-30 16:25:03] [debug] [SeggerBackend] - Segger logging enabled.
    [2022-Dec-30 16:25:04] [trace] [ JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Nov 7 2022 16:22:01
    [2022-Dec-30 16:25:04] [trace] [ Client] - Command connect_to_emu_with_snr executed for 331 milliseconds with result 0
    [2022-Dec-30 16:25:04] [trace] [ JLink] - Hardware: V1.00
    [2022-Dec-30 16:25:04] [trace] [ JLink] - S/N: 1050302422
    [2022-Dec-30 16:25:04] [debug] [ Client] - read_connected_emu_snr
    [2022-Dec-30 16:25:04] [trace] [ JLink] - OEM: SEGGER
    [2022-Dec-30 16:25:04] [trace] [ JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2022-Dec-30 16:25:04] [trace] [ JLink] - USB speed mode: Full speed (12 MBit/s)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - TELNET listener socket opened on port 19021
    [2022-Dec-30 16:25:04] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - WEBSRV Failed to put socket into listener state (port 19080)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - WEBSRV Webserver running on local port 19081
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 305.622ms returns "O.K."
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_Lock()
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.004ms returns 0x01
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.005ms returns 0x00
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.022ms returns 0
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 2.275ms returns 0x00
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_GetSpeedInfo()
    [2022-Dec-30 16:25:04] [trace] [ JLink] - 128000000 Hz / n, n >= 64
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.018ms
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_SetSpeed(2000)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.127ms
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_GetSpeed()
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.009ms returns 2000
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_GetSN()
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.008ms returns 1050302422
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.010ms
    [2022-Dec-30 16:25:04] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 326 milliseconds with result 0
    [2022-Dec-30 16:25:04] [trace] [ Client] - Command read_connected_emu_snr executed for 15 milliseconds with result 0
    [2022-Dec-30 16:25:04] [debug] [ Client] - recover
    [2022-Dec-30 16:25:04] [debug] [ nRF52] - read_connected_emu_snr
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - is_connected_to_emu
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_IsOpen()
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.011ms returns 0x01
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - read_connected_emu_snr
    [2022-Dec-30 16:25:04] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2022-Dec-30 16:25:04] [debug] [ nRF52] - recover
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.018ms returns 0x01
    [2022-Dec-30 16:25:04] [debug] [ nRF52] - Just_recover
    [2022-Dec-30 16:25:04] [debug] [ nRF52] - Just_is_ctrl_ap_available
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - coresight_configure
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_GetHWStatus(...)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.238ms returns 0
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.657ms returns 0
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - read_debug_port_idr
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - read_debug_port_register
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.286ms returns 0
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - Value=0x2BA01477
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.293ms returns 0
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - Value=0xF0000040
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.306ms returns 0
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.279ms returns 0
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - Value=0x02880000
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 1.164ms returns 0
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.330ms returns 0
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 1.152ms returns 0
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.387ms returns 0
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - write_access_port_register
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2022-Dec-30 16:25:04] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.289ms returns 0
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.660ms returns 0
    [2022-Dec-30 16:25:04] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:04] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:04] [trace] [ JLink] - - 0.977ms returns 0
    [2022-Dec-30 16:25:05] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:05] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:05] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:05] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:05] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:05] [trace] [ JLink] - - 0.903ms returns 0
    [2022-Dec-30 16:25:05] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:05] [trace] [ JLink] - - 0.806ms returns 0
    [2022-Dec-30 16:25:06] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:06] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:06] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:06] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:06] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:06] [trace] [ JLink] - - 1.088ms returns 0
    [2022-Dec-30 16:25:06] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:06] [trace] [ JLink] - - 0.547ms returns 0
    [2022-Dec-30 16:25:07] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:07] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:07] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:07] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:07] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:07] [trace] [ JLink] - - 0.818ms returns 0
    [2022-Dec-30 16:25:07] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:07] [trace] [ JLink] - - 1.059ms returns 0
    [2022-Dec-30 16:25:08] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:08] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:08] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:08] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:08] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:08] [trace] [ JLink] - - 0.978ms returns 0
    [2022-Dec-30 16:25:08] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:08] [trace] [ JLink] - - 0.857ms returns 0
    [2022-Dec-30 16:25:09] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:09] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:09] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:09] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:09] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:09] [trace] [ JLink] - - 0.907ms returns 0
    [2022-Dec-30 16:25:09] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:09] [trace] [ JLink] - - 1.125ms returns 0
    [2022-Dec-30 16:25:10] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:10] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:10] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:10] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:10] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:10] [trace] [ JLink] - - 0.821ms returns 0
    [2022-Dec-30 16:25:10] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:10] [trace] [ JLink] - - 0.845ms returns 0
    [2022-Dec-30 16:25:11] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:11] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:11] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:11] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:11] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:11] [trace] [ JLink] - - 1.185ms returns 0
    [2022-Dec-30 16:25:11] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:11] [trace] [ JLink] - - 0.999ms returns 0
    [2022-Dec-30 16:25:12] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:12] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:12] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:12] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:12] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:12] [trace] [ JLink] - - 0.579ms returns 0
    [2022-Dec-30 16:25:12] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:12] [trace] [ JLink] - - 0.539ms returns 0
    [2022-Dec-30 16:25:13] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:13] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:13] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:13] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:13] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:13] [trace] [ JLink] - - 1.032ms returns 0
    [2022-Dec-30 16:25:13] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:13] [trace] [ JLink] - - 1.315ms returns 0
    [2022-Dec-30 16:25:14] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:14] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:14] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:14] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:14] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 1.032ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:14] [debug] [ nRF52] - Just_debug_reset
    [2022-Dec-30 16:25:14] [debug] [ nRF52] - Just_is_ctrl_ap_available
    [2022-Dec-30 16:25:14] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2022-Dec-30 16:25:14] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.301ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2022-Dec-30 16:25:14] [trace] [ JLink] - Value=0x02880000
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.548ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.383ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.976ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.555ms returns 0
    [2022-Dec-30 16:25:14] [debug] [SeggerBackend] - write_access_port_register
    [2022-Dec-30 16:25:14] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2022-Dec-30 16:25:14] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.292ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.734ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 1.401ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.479ms returns 0
    [2022-Dec-30 16:25:14] [debug] [ nRF52] - Just_readback_status
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 1.029ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.817ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 1.120ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.980ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.401ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.273ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - Value=0x00000000
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.686ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.559ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 1.023ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.792ms returns 0
    [2022-Dec-30 16:25:14] [ info] [ nRF52] - Protection status read as APPROTECT -> ALL
    [2022-Dec-30 16:25:14] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 1.099ms returns 0
    [2022-Dec-30 16:25:14] [trace] [ JLink] - - 0.645ms returns 0
    [2022-Dec-30 16:25:15] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:15] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:15] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:15] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:15] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:15] [trace] [ JLink] - - 0.945ms returns 0
    [2022-Dec-30 16:25:15] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:15] [trace] [ JLink] - - 0.529ms returns 0
    [2022-Dec-30 16:25:16] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:16] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:16] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:16] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:16] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:16] [trace] [ JLink] - - 1.056ms returns 0
    [2022-Dec-30 16:25:16] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:16] [trace] [ JLink] - - 0.961ms returns 0
    [2022-Dec-30 16:25:17] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:17] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:17] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:17] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:17] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:17] [trace] [ JLink] - - 0.872ms returns 0
    [2022-Dec-30 16:25:17] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:17] [trace] [ JLink] - - 0.748ms returns 0
    [2022-Dec-30 16:25:18] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:18] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:18] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:18] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:18] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:18] [trace] [ JLink] - - 1.115ms returns 0
    [2022-Dec-30 16:25:18] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:18] [trace] [ JLink] - - 0.903ms returns 0
    [2022-Dec-30 16:25:19] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:19] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:19] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:19] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:19] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:19] [trace] [ JLink] - - 1.362ms returns 0
    [2022-Dec-30 16:25:19] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:19] [trace] [ JLink] - - 1.075ms returns 0
    [2022-Dec-30 16:25:20] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:20] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:20] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:20] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:20] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:20] [trace] [ JLink] - - 1.078ms returns 0
    [2022-Dec-30 16:25:20] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:20] [trace] [ JLink] - - 0.632ms returns 0
    [2022-Dec-30 16:25:21] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:21] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:21] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:21] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:21] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:21] [trace] [ JLink] - - 1.244ms returns 0
    [2022-Dec-30 16:25:21] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:21] [trace] [ JLink] - - 1.043ms returns 0
    [2022-Dec-30 16:25:22] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:22] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:22] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:22] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:22] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:22] [trace] [ JLink] - - 1.328ms returns 0
    [2022-Dec-30 16:25:22] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:22] [trace] [ JLink] - - 0.853ms returns 0
    [2022-Dec-30 16:25:23] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:23] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:23] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:23] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:23] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:23] [trace] [ JLink] - - 1.208ms returns 0
    [2022-Dec-30 16:25:23] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:23] [trace] [ JLink] - - 1.041ms returns 0
    [2022-Dec-30 16:25:24] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:24] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:24] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:24] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:24] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.744ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:24] [debug] [ nRF52] - Just_debug_reset
    [2022-Dec-30 16:25:24] [debug] [ nRF52] - Just_is_ctrl_ap_available
    [2022-Dec-30 16:25:24] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2022-Dec-30 16:25:24] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.277ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2022-Dec-30 16:25:24] [trace] [ JLink] - Value=0x02880000
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.810ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.391ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.552ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.407ms returns 0
    [2022-Dec-30 16:25:24] [debug] [SeggerBackend] - write_access_port_register
    [2022-Dec-30 16:25:24] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2022-Dec-30 16:25:24] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.268ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.264ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.462ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.286ms returns 0
    [2022-Dec-30 16:25:24] [debug] [ nRF52] - Just_readback_status
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 1.014ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.562ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.691ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 1.087ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.559ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.926ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - Value=0x00000000
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.537ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.993ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 1.149ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 1.128ms returns 0
    [2022-Dec-30 16:25:24] [ info] [ nRF52] - Protection status read as APPROTECT -> ALL
    [2022-Dec-30 16:25:24] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 0.425ms returns 0
    [2022-Dec-30 16:25:24] [trace] [ JLink] - - 1.180ms returns 0
    [2022-Dec-30 16:25:25] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:25] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:25] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:25] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:25] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:25] [trace] [ JLink] - - 1.314ms returns 0
    [2022-Dec-30 16:25:25] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:25] [trace] [ JLink] - - 0.656ms returns 0
    [2022-Dec-30 16:25:26] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:26] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:26] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:26] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:26] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:26] [trace] [ JLink] - - 0.465ms returns 0
    [2022-Dec-30 16:25:26] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:26] [trace] [ JLink] - - 0.477ms returns 0
    [2022-Dec-30 16:25:27] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:27] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:27] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:27] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:27] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:27] [trace] [ JLink] - - 0.573ms returns 0
    [2022-Dec-30 16:25:27] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:27] [trace] [ JLink] - - 0.799ms returns 0
    [2022-Dec-30 16:25:28] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:28] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:28] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:28] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:28] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:28] [trace] [ JLink] - - 0.787ms returns 0
    [2022-Dec-30 16:25:28] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:28] [trace] [ JLink] - - 0.533ms returns 0
    [2022-Dec-30 16:25:29] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:29] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:29] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:29] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:29] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:29] [trace] [ JLink] - - 1.304ms returns 0
    [2022-Dec-30 16:25:29] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:29] [trace] [ JLink] - - 0.499ms returns 0
    [2022-Dec-30 16:25:30] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:30] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:30] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:30] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:30] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:30] [trace] [ JLink] - - 0.831ms returns 0
    [2022-Dec-30 16:25:30] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:30] [trace] [ JLink] - - 0.518ms returns 0
    [2022-Dec-30 16:25:31] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:31] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:31] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:31] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:31] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:31] [trace] [ JLink] - - 1.320ms returns 0
    [2022-Dec-30 16:25:31] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:31] [trace] [ JLink] - - 1.190ms returns 0
    [2022-Dec-30 16:25:32] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:32] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:32] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:32] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:32] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:32] [trace] [ JLink] - - 1.263ms returns 0
    [2022-Dec-30 16:25:32] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:32] [trace] [ JLink] - - 0.745ms returns 0
    [2022-Dec-30 16:25:33] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:33] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:33] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:33] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:33] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:33] [trace] [ JLink] - - 0.449ms returns 0
    [2022-Dec-30 16:25:33] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:33] [trace] [ JLink] - - 0.483ms returns 0
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:25:34] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.891ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:25:34] [debug] [ nRF52] - Just_debug_reset
    [2022-Dec-30 16:25:34] [debug] [ nRF52] - Just_is_ctrl_ap_available
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.292ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2022-Dec-30 16:25:34] [trace] [ JLink] - Value=0x02880000
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.630ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.834ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 1.127ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.978ms returns 0
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - write_access_port_register
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.525ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.371ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.754ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.576ms returns 0
    [2022-Dec-30 16:25:34] [debug] [ nRF52] - Just_readback_status
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.759ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.572ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.990ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.827ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 1.120ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ Client] - Command recover executed for 30206 milliseconds with result -21
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.809ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - Value=0x00000000
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 1.122ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.399ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.559ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.603ms returns 0
    [2022-Dec-30 16:25:34] [ info] [ nRF52] - Protection status read as APPROTECT -> ALL
    [2022-Dec-30 16:25:34] [debug] [ nRF52] - Just_read_device_version
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.446ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.994ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.388ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.609ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.917ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.838ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 1.132ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.425ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.554ms returns 0
    [2022-Dec-30 16:25:34] [error] [ nRF52] - Access protection is enabled, can't read device version.
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.018ms
    [2022-Dec-30 16:25:34] [trace] [ Worker] - Command recover executed for 30197 milliseconds with result -21
    [2022-Dec-30 16:25:34] [debug] [ nRF52] - close
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - is_connected_to_emu
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_IsOpen()
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.015ms returns 0x01
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_Lock()
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - close
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - disconnect_from_emu
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - is_connected_to_device
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_IsConnected()
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.012ms returns FALSE
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.779ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2022-Dec-30 16:25:34] [trace] [ JLink] - Value=0xF0000040
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.317ms returns 0
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - unpower_debug_and_system_regions
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - ---just_write_debug_port_register
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x01, 0x00000000)
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.363ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - Value=0x00000040
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.337ms returns 0
    [2022-Dec-30 16:25:34] [trace] [ JLink] - - 0.041ms
    [2022-Dec-30 16:25:34] [trace] [ JLink] - JLINK_Close()
    [2022-Dec-30 16:25:34] [debug] [SeggerBackend] - Segger Backend closed.
    [2022-Dec-30 16:25:34] [trace] [ Client] - Command close executed for 31 milliseconds with result 0
    [2022-Dec-30 16:25:34] [debug] [ Client] - terminate
    [2022-Dec-30 16:25:34] [debug] [ nRF52] - nRF family DLL closed
    [2022-Dec-30 16:25:34] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2022-Dec-30 16:25:34] [trace] [ Worker] - Command close executed for 30 milliseconds with result 0
    [2022-Dec-30 16:25:34] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2022-Dec-30 16:25:34] [trace] [ Worker] - Executed 8 commands for 30574 milliseconds
    [2022-Dec-30 16:25:34] [debug] [ Client] - Worker process exited with code: 0
    [2022-Dec-30 16:25:34] [debug] [ Client] - Child process terminated with result 0
    [2022-Dec-30 16:25:34] [trace] [ Client] - Executed 8 commands for 30679 milliseconds
    [2022-Dec-30 16:30:32] [debug] --------------------------------------------------------------------------------
    [2022-Dec-30 16:30:32] [debug] nrfjprog --log --family nrf52 --recover
    [2022-Dec-30 16:30:32] [debug] nrfjprog version 10.18.1 external
    [2022-Dec-30 16:30:32] [ info] Load library at C:\Program Files (x86)\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2022-Dec-30 16:30:32] [ info] Library loaded, loading member functions.
    [2022-Dec-30 16:30:32] [ info] Member functions succesfully loaded.
    [2022-Dec-30 16:30:32] [debug] [ Client] - open
    [2022-Dec-30 16:30:32] [debug] [ Client] - start
    [2022-Dec-30 16:30:32] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 32681502-205a-4edf-baa3-f3b9ef4b43a9.
    [2022-Dec-30 16:30:32] [trace] [ Client] - Command open executed for 76 milliseconds with result 0
    [2022-Dec-30 16:30:32] [debug] [ Client] - config
    [2022-Dec-30 16:30:32] [trace] [ Client] - Command config executed for 15 milliseconds with result 0
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2022-Dec-30 16:30:32] [debug] [ JLink] - Logger sink registered in JLink logger
    [2022-Dec-30 16:30:32] [debug] [ nRF52] - open
    [2022-Dec-30 16:30:32] [debug] [ Client] - enum_emu_snr
    [2022-Dec-30 16:30:32] [debug] [ nRF52] - just_check_family
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - open_dll
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2022-Dec-30 16:30:32] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink\JLinkARM.dll.
    [2022-Dec-30 16:30:32] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2022-Dec-30 16:30:32] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - Set batch mode
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - dll_version
    [2022-Dec-30 16:30:32] [ info] [SeggerBackend] - Segger dll version 7.82.f loaded.
    [2022-Dec-30 16:30:32] [trace] [ Worker] - Command open executed for 9 milliseconds with result 0
    [2022-Dec-30 16:30:32] [debug] [ nRF52] - config
    [2022-Dec-30 16:30:32] [trace] [ Worker] - Command config executed for 7 milliseconds with result 0
    [2022-Dec-30 16:30:32] [trace] [ Client] - Command enum_emu_con_info executed for 15 milliseconds with result 0
    [2022-Dec-30 16:30:32] [debug] [ Client] - connect_to_emu_with_snr
    [2022-Dec-30 16:30:32] [debug] [ nRF52] - enum_emu_con_info
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - is_connected_to_emu
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - enum_emu_con_info
    [2022-Dec-30 16:30:32] [trace] [ Worker] - Command enum_emu_con_info executed for 6 milliseconds with result 0
    [2022-Dec-30 16:30:32] [debug] [ nRF52] - connect_to_emu_with_snr
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - ---just_get_num_emus
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2022-Dec-30 16:30:32] [debug] [SeggerBackend] - Segger logging enabled.
    [2022-Dec-30 16:30:33] [trace] [ JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Nov 7 2022 16:22:01
    [2022-Dec-30 16:30:33] [trace] [ JLink] - Hardware: V1.00
    [2022-Dec-30 16:30:33] [trace] [ JLink] - S/N: 1050302422
    [2022-Dec-30 16:30:33] [trace] [ JLink] - OEM: SEGGER
    [2022-Dec-30 16:30:33] [trace] [ JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2022-Dec-30 16:30:33] [trace] [ JLink] - USB speed mode: Full speed (12 MBit/s)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - TELNET listener socket opened on port 19021
    [2022-Dec-30 16:30:33] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - WEBSRV Failed to put socket into listener state (port 19080)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - WEBSRV Webserver running on local port 19081
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 311.768ms returns "O.K."
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_Lock()
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.005ms returns 0x01
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.006ms returns 0x00
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.027ms returns 0
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 1.797ms returns 0x00
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_GetSpeedInfo()
    [2022-Dec-30 16:30:33] [trace] [ JLink] - 128000000 Hz / n, n >= 64
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.025ms
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_SetSpeed(2000)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.120ms
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_GetSpeed()
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.009ms returns 2000
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_GetSN()
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.010ms returns 1050302422
    [2022-Dec-30 16:30:33] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 334 milliseconds with result 0
    [2022-Dec-30 16:30:33] [trace] [ Client] - Command connect_to_emu_with_snr executed for 346 milliseconds with result 0
    [2022-Dec-30 16:30:33] [debug] [ Client] - read_connected_emu_snr
    [2022-Dec-30 16:30:33] [trace] [ Client] - Command read_connected_emu_snr executed for 15 milliseconds with result 0
    [2022-Dec-30 16:30:33] [debug] [ Client] - recover
    [2022-Dec-30 16:30:33] [debug] [ nRF52] - read_connected_emu_snr
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - is_connected_to_emu
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_IsOpen()
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.016ms returns 0x01
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - read_connected_emu_snr
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.011ms
    [2022-Dec-30 16:30:33] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2022-Dec-30 16:30:33] [debug] [ nRF52] - recover
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.020ms returns 0x01
    [2022-Dec-30 16:30:33] [debug] [ nRF52] - Just_recover
    [2022-Dec-30 16:30:33] [debug] [ nRF52] - Just_is_ctrl_ap_available
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - coresight_configure
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_GetHWStatus(...)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.815ms returns 0
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 1.126ms returns 0
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - read_debug_port_idr
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - read_debug_port_register
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.288ms returns 0
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - Value=0x2BA01477
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.295ms returns 0
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - Value=0xF0000000
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.314ms returns 0
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.271ms returns 0
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - Value=0x02880000
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.733ms returns 0
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.329ms returns 0
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.544ms returns 0
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.403ms returns 0
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - write_access_port_register
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2022-Dec-30 16:30:33] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.281ms returns 0
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 0.664ms returns 0
    [2022-Dec-30 16:30:33] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:33] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:33] [trace] [ JLink] - - 1.059ms returns 0
    [2022-Dec-30 16:30:34] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:34] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:34] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:34] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:34] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:34] [trace] [ JLink] - - 0.369ms returns 0
    [2022-Dec-30 16:30:34] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:34] [trace] [ JLink] - - 1.389ms returns 0
    [2022-Dec-30 16:30:35] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:35] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:35] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:35] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:35] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:35] [trace] [ JLink] - - 0.879ms returns 0
    [2022-Dec-30 16:30:35] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:35] [trace] [ JLink] - - 0.880ms returns 0
    [2022-Dec-30 16:30:36] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:36] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:36] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:36] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:36] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:36] [trace] [ JLink] - - 0.968ms returns 0
    [2022-Dec-30 16:30:36] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:36] [trace] [ JLink] - - 0.741ms returns 0
    [2022-Dec-30 16:30:37] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:37] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:37] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:37] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:37] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:37] [trace] [ JLink] - - 0.937ms returns 0
    [2022-Dec-30 16:30:37] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:37] [trace] [ JLink] - - 0.354ms returns 0
    [2022-Dec-30 16:30:38] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:38] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:38] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:38] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:38] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:38] [trace] [ JLink] - - 0.354ms returns 0
    [2022-Dec-30 16:30:38] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:38] [trace] [ JLink] - - 1.039ms returns 0
    [2022-Dec-30 16:30:39] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:39] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:39] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:39] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:39] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:39] [trace] [ JLink] - - 0.376ms returns 0
    [2022-Dec-30 16:30:39] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:39] [trace] [ JLink] - - 0.783ms returns 0
    [2022-Dec-30 16:30:40] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:40] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:40] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:40] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:40] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:40] [trace] [ JLink] - - 0.461ms returns 0
    [2022-Dec-30 16:30:40] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:40] [trace] [ JLink] - - 1.049ms returns 0
    [2022-Dec-30 16:30:41] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:41] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:41] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:41] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:41] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:41] [trace] [ JLink] - - 1.074ms returns 0
    [2022-Dec-30 16:30:41] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:41] [trace] [ JLink] - - 0.967ms returns 0
    [2022-Dec-30 16:30:42] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:42] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:42] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:42] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:42] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:42] [trace] [ JLink] - - 0.904ms returns 0
    [2022-Dec-30 16:30:42] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:42] [trace] [ JLink] - - 1.236ms returns 0
    [2022-Dec-30 16:30:43] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:43] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:43] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:43] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:43] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 1.046ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:43] [debug] [ nRF52] - Just_debug_reset
    [2022-Dec-30 16:30:43] [debug] [ nRF52] - Just_is_ctrl_ap_available
    [2022-Dec-30 16:30:43] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2022-Dec-30 16:30:43] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 1.022ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2022-Dec-30 16:30:43] [trace] [ JLink] - Value=0x02880000
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 0.853ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 1.099ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 0.841ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 1.092ms returns 0
    [2022-Dec-30 16:30:43] [debug] [SeggerBackend] - write_access_port_register
    [2022-Dec-30 16:30:43] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2022-Dec-30 16:30:43] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 0.819ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 1.095ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 1.157ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 0.807ms returns 0
    [2022-Dec-30 16:30:43] [debug] [ nRF52] - Just_readback_status
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 1.061ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 0.837ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 1.119ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 0.816ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 1.108ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 0.848ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - Value=0x00000000
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 1.077ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 0.823ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 1.151ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 0.767ms returns 0
    [2022-Dec-30 16:30:43] [ info] [ nRF52] - Protection status read as APPROTECT -> ALL
    [2022-Dec-30 16:30:43] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 1.214ms returns 0
    [2022-Dec-30 16:30:43] [trace] [ JLink] - - 0.832ms returns 0
    [2022-Dec-30 16:30:44] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:44] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:44] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:44] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:44] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:44] [trace] [ JLink] - - 0.565ms returns 0
    [2022-Dec-30 16:30:44] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:44] [trace] [ JLink] - - 0.495ms returns 0
    [2022-Dec-30 16:30:45] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:45] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:45] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:45] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:45] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:45] [trace] [ JLink] - - 1.137ms returns 0
    [2022-Dec-30 16:30:45] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:45] [trace] [ JLink] - - 1.049ms returns 0
    [2022-Dec-30 16:30:46] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:46] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:46] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:46] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:46] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:46] [trace] [ JLink] - - 0.892ms returns 0
    [2022-Dec-30 16:30:46] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:46] [trace] [ JLink] - - 1.219ms returns 0
    [2022-Dec-30 16:30:47] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:47] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:47] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:47] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:47] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:47] [trace] [ JLink] - - 0.482ms returns 0
    [2022-Dec-30 16:30:47] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:47] [trace] [ JLink] - - 1.309ms returns 0
    [2022-Dec-30 16:30:48] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:48] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:48] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:48] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:48] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:48] [trace] [ JLink] - - 0.485ms returns 0
    [2022-Dec-30 16:30:48] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:48] [trace] [ JLink] - - 0.951ms returns 0
    [2022-Dec-30 16:30:49] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:49] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:49] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:49] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:49] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:49] [trace] [ JLink] - - 0.897ms returns 0
    [2022-Dec-30 16:30:49] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:49] [trace] [ JLink] - - 1.342ms returns 0
    [2022-Dec-30 16:30:50] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:50] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:50] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:50] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:50] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:50] [trace] [ JLink] - - 1.063ms returns 0
    [2022-Dec-30 16:30:50] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:50] [trace] [ JLink] - - 0.940ms returns 0
    [2022-Dec-30 16:30:51] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:51] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:51] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:51] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:51] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:51] [trace] [ JLink] - - 1.312ms returns 0
    [2022-Dec-30 16:30:51] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:51] [trace] [ JLink] - - 1.189ms returns 0
    [2022-Dec-30 16:30:52] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:52] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:52] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:52] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:52] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:52] [trace] [ JLink] - - 1.149ms returns 0
    [2022-Dec-30 16:30:52] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:52] [trace] [ JLink] - - 0.953ms returns 0
    [2022-Dec-30 16:30:53] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:53] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:53] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:53] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:53] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.767ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:53] [debug] [ nRF52] - Just_debug_reset
    [2022-Dec-30 16:30:53] [debug] [ nRF52] - Just_is_ctrl_ap_available
    [2022-Dec-30 16:30:53] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2022-Dec-30 16:30:53] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 1.076ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2022-Dec-30 16:30:53] [trace] [ JLink] - Value=0x02880000
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.833ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 1.115ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.370ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.539ms returns 0
    [2022-Dec-30 16:30:53] [debug] [SeggerBackend] - write_access_port_register
    [2022-Dec-30 16:30:53] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2022-Dec-30 16:30:53] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.308ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.269ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.712ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.273ms returns 0
    [2022-Dec-30 16:30:53] [debug] [ nRF52] - Just_readback_status
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.499ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 1.019ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.784ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.521ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.285ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - Value=0x00000000
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.674ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.414ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 1.044ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.390ms returns 0
    [2022-Dec-30 16:30:53] [ info] [ nRF52] - Protection status read as APPROTECT -> ALL
    [2022-Dec-30 16:30:53] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 0.289ms returns 0
    [2022-Dec-30 16:30:53] [trace] [ JLink] - - 1.251ms returns 0
    [2022-Dec-30 16:30:54] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:54] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:54] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:54] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:54] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:54] [trace] [ JLink] - - 0.904ms returns 0
    [2022-Dec-30 16:30:54] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:54] [trace] [ JLink] - - 0.969ms returns 0
    [2022-Dec-30 16:30:55] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:55] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:55] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:55] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:55] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:55] [trace] [ JLink] - - 0.869ms returns 0
    [2022-Dec-30 16:30:55] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:55] [trace] [ JLink] - - 1.302ms returns 0
    [2022-Dec-30 16:30:56] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:56] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:56] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:56] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:56] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:56] [trace] [ JLink] - - 0.918ms returns 0
    [2022-Dec-30 16:30:56] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:56] [trace] [ JLink] - - 0.479ms returns 0
    [2022-Dec-30 16:30:57] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:57] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:57] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:57] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:57] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:57] [trace] [ JLink] - - 1.329ms returns 0
    [2022-Dec-30 16:30:57] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:57] [trace] [ JLink] - - 0.473ms returns 0
    [2022-Dec-30 16:30:58] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:58] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:58] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:58] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:58] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:58] [trace] [ JLink] - - 0.923ms returns 0
    [2022-Dec-30 16:30:58] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:58] [trace] [ JLink] - - 1.179ms returns 0
    [2022-Dec-30 16:30:59] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:30:59] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:30:59] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:30:59] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:30:59] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:30:59] [trace] [ JLink] - - 0.652ms returns 0
    [2022-Dec-30 16:30:59] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:30:59] [trace] [ JLink] - - 1.421ms returns 0
    [2022-Dec-30 16:31:00] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:31:00] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:31:00] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:31:00] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:31:00] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:31:00] [trace] [ JLink] - - 0.627ms returns 0
    [2022-Dec-30 16:31:00] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:31:00] [trace] [ JLink] - - 1.386ms returns 0
    [2022-Dec-30 16:31:01] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:31:01] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:31:01] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:31:01] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:31:01] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:31:01] [trace] [ JLink] - - 1.192ms returns 0
    [2022-Dec-30 16:31:01] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:31:01] [trace] [ JLink] - - 0.950ms returns 0
    [2022-Dec-30 16:31:02] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:31:02] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:31:02] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:31:02] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:31:02] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:31:02] [trace] [ JLink] - - 0.889ms returns 0
    [2022-Dec-30 16:31:02] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:31:02] [trace] [ JLink] - - 0.921ms returns 0
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - read_access_port_register
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2022-Dec-30 16:31:03] [trace] [ JLink] - Value=0x00000001
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 1.312ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_HasError()
    [2022-Dec-30 16:31:03] [debug] [ nRF52] - Just_debug_reset
    [2022-Dec-30 16:31:03] [debug] [ nRF52] - Just_is_ctrl_ap_available
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.422ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2022-Dec-30 16:31:03] [trace] [ JLink] - Value=0x02880000
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 1.105ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.923ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 1.349ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.386ms returns 0
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - write_access_port_register
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 1.120ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.741ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 1.189ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.430ms returns 0
    [2022-Dec-30 16:31:03] [debug] [ nRF52] - Just_readback_status
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 1.107ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.565ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.970ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.817ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.520ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.951ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ Client] - Command recover executed for 30211 milliseconds with result -21
    [2022-Dec-30 16:31:03] [trace] [ JLink] - Value=0x00000000
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.415ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 1.100ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.828ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 1.103ms returns 0
    [2022-Dec-30 16:31:03] [ info] [ nRF52] - Protection status read as APPROTECT -> ALL
    [2022-Dec-30 16:31:03] [debug] [ nRF52] - Just_read_device_version
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.779ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 1.152ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.806ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.566ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.436ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.804ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 1.182ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.755ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 1.119ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.762ms returns 0
    [2022-Dec-30 16:31:03] [error] [ nRF52] - Access protection is enabled, can't read device version.
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.019ms
    [2022-Dec-30 16:31:03] [trace] [ Worker] - Command recover executed for 30206 milliseconds with result -21
    [2022-Dec-30 16:31:03] [debug] [ nRF52] - close
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - is_connected_to_emu
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_IsOpen()
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.056ms returns 0x01
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_Lock()
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - close
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - disconnect_from_emu
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - is_connected_to_device
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_IsConnected()
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.010ms returns FALSE
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.307ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2022-Dec-30 16:31:03] [trace] [ JLink] - Value=0xF0000040
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.265ms returns 0
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - unpower_debug_and_system_regions
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - ---just_write_debug_port_register
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x01, 0x00000000)
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.251ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - Value=0x00000040
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 1.091ms returns 0
    [2022-Dec-30 16:31:03] [trace] [ JLink] - - 0.013ms
    [2022-Dec-30 16:31:03] [trace] [ JLink] - JLINK_Close()
    [2022-Dec-30 16:31:03] [debug] [SeggerBackend] - Segger Backend closed.
    [2022-Dec-30 16:31:03] [debug] [ nRF52] - nRF family DLL closed
    [2022-Dec-30 16:31:03] [trace] [ Worker] - Command close executed for 31 milliseconds with result 0
    [2022-Dec-30 16:31:03] [trace] [ Client] - Command close executed for 47 milliseconds with result 0
    [2022-Dec-30 16:31:03] [debug] [ Client] - terminate
    [2022-Dec-30 16:31:03] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2022-Dec-30 16:31:03] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2022-Dec-30 16:31:03] [trace] [ Worker] - Executed 8 commands for 30593 milliseconds
    [2022-Dec-30 16:31:03] [debug] [ Client] - Worker process exited with code: 0
    [2022-Dec-30 16:31:03] [debug] [ Client] - Child process terminated with result 0
    [2022-Dec-30 16:31:03] [trace] [ Client] - Executed 8 commands for 30725 milliseconds
    I can see a similar ticket created by you. So I will be answering in your first created thread.
    I am closing this ticket as it is a duplicate of this thread.
    Kind Regards,
    Abhijith
