We have an application scanning 4 ADC inputs AN1, AN5, AN6 and AN7
We setup the SSADC in scanning mode:
void saadc_init(void) { ret_code_t err_code; nrf_saadc_channel_config_t channel_0_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1); nrf_saadc_channel_config_t channel_1_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN5); nrf_saadc_channel_config_t channel_2_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN6); nrf_saadc_channel_config_t channel_3_config = NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN7); channel_0_config.gain = NRF_SAADC_GAIN1_4; channel_0_config.reference = NRF_SAADC_REFERENCE_VDD4; channel_0_config.acq_time = NRF_SAADC_ACQTIME_20US; channel_1_config.gain = NRF_SAADC_GAIN1_4; channel_1_config.reference = NRF_SAADC_REFERENCE_VDD4; channel_1_config.acq_time = NRF_SAADC_ACQTIME_20US; channel_2_config.gain = NRF_SAADC_GAIN1_4; channel_2_config.reference = NRF_SAADC_REFERENCE_VDD4; channel_2_config.acq_time = NRF_SAADC_ACQTIME_20US; channel_3_config.gain = NRF_SAADC_GAIN1_4; channel_3_config.reference = NRF_SAADC_REFERENCE_VDD4; channel_3_config.acq_time = NRF_SAADC_ACQTIME_20US; err_code = nrf_drv_saadc_channel_init(0, &channel_0_config); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_channel_init(1, &channel_1_config); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_channel_init(2, &channel_2_config); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_channel_init(3, &channel_3_config); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_init( NULL, saadc_callback ); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); }
We start sampling the ADC on a regular basis using PPI:
err_code = nrf_drv_ppi_channel_alloc(&m_ppi_channel2); APP_ERROR_CHECK(err_code); err_code = nrf_drv_ppi_channel_assign(m_ppi_channel2, nrf_drv_timer_event_address_get(&timer_3, NRF_TIMER_EVENT_COMPARE0), nrf_drv_saadc_sample_task_get() ); APP_ERROR_CHECK(err_code);
Here is the SSADC callback, we do averaging here too.
void saadc_callback(nrf_drv_saadc_evt_t const * p_event) { static uint8_t channel = 0; static uint32_t array_index = 0; uint32_t avg_index; nrf_gpio_pin_set( DEBUG_PIN ); if (p_event->type == NRF_DRV_SAADC_EVT_DONE) { err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER); APP_ERROR_CHECK(err_code); debug_counter++; switch( channel ) { case 0: adc_count_array[0][array_index] = p_event->data.done.p_buffer[0]; channel++; break; case 1: adc_count_array[1][array_index] = p_event->data.done.p_buffer[1]; channel++; break; case 2: adc_count_array[2][array_index] = p_event->data.done.p_buffer[2]; channel++; break; case 3: adc_count_array[3][array_index] = p_event->data.done.p_buffer[3]; channel = 0; array_index++; if( array_index > 9 ) { array_index = 0; // Clear averages adc_count_average[0] = 0; adc_count_average[1] = 0; adc_count_average[2] = 0; adc_count_average[3] = 0; // Add all up for( avg_index = 0; avg_index < 10; avg_index ++ ) { adc_count_average[0] += adc_count_array[0][avg_index]; adc_count_average[1] += adc_count_array[1][avg_index]; adc_count_average[2] += adc_count_array[2][avg_index]; adc_count_average[3] += adc_count_array[3][avg_index]; } // divide by 10 adc_count_average[0] /= 10; adc_count_average[1] /= 10; adc_count_average[2] /= 10; adc_count_average[3] /= 10; adc_new_data = true; } break; default: break; } } }
The buffer is setup as follows:
static nrf_saadc_value_t m_buffer_pool[2][SAMPLES_IN_BUFFER];
SAMPLES_IN_BUFFER is set to 4
When we scan at low speed e.g. 5000us the values are correct:
When we scan at a higher speed e.g. 500us the values switch over:
The above values are from our averaging buffer.
We have also checked the result buffer directly.
As you can see....
AN0 moves to AN5, AN5 moves to AN6, AN6 moves to AN7 and AN7 moves to AN0
Does anyone have any idea why these values are shifting position depending on the ppi / timer speed?
There is also a question on the forum that was never answered.
