Github led/button example nrf51_ble_app_lbs_master for SDK 8.0.0 not discovered on Master Control Panel
Dear all, after solution of some compilation errors on github nrf51_ble_app_lbs_master for SDK 8.0.0, I tried flash application using nRFgo Studio, it says that application must be programmed without softdevice alone previous programming, OK, programm was flashed without problems but after device didn't appears on Master Control Panel, that means device was not discovered. I'm using following components:
Nordic PCA10028 DK board Nordic PCA10000 Bluetooth dongle Nordic Master Control PAnel Nordic nRFgo Studio Nordic SDK 8.0.0 Keil IDE Lite version Nordic auxiliar tools
can you help?
Thanks and regards. Luis Tenedorio Globaltronic SA
Dear Petter, after a lot of efforts and posts we had concluded that problem was located on my example compilation, as you said something about "10 errors all same type cannot open source input file core_cm0.h, no such file or directory" that forced me delete original startup files and add new CMSIS startup files. Following your last comment please accept attached project file in order to observe something wrong. As you said, I had compiled other examples of SDK 8.0.0 namely blinky and hrs and they work fine! lbe-app-hrs including was advertised on MCPanel, so there are a small "stone" on lbe-app-lbs-master but we will find that. Thanks amd regards Luis nrf51-ble-app-lbs-master_100.rar
