How to configure ble_app_beacon example from SDK 9.0.0 for PCA20006?
I'm trying to upload ble_app_beacon example from SDK 9.0.0 to a beacon board (PCA20006) after successfully uploading it to a DK board (PCA10028).
My first step was to connect the beacon to nRF51-DK using a Tag-connect cable, erase the memory using nRFgo studio and upload S110 (s110_softdevice.hex from C:\Keil_v5\ARM\Pack\NordicSemiconductor\nRF_SoftDevice_S110\8.0.2\hex).
I'm rather intrigued that nRFgo studio showed the S110 softdevie as 8.0.0 instead of 8.0.02.
Anyway, the second step was trying to modify the ble_app_beacon code from PCA10028 to PCA20006 in Keil. I made a few modifications in Flash > Configure flash tools
  • Device: to nRF51822xxAA
  • C/C++: use BOARD_PCA20006
  • Target: ROM (start=0x18000; size=0x40000); RAM (start=0x20000000; size=0x8000); Xtal=16.0
  • Debug: J-Link/J-TRACE Cortex
I received two errors when building the project.
    compiling nrf_drv_gpiote.c...
C:\Keil_v5\ARM\PACK\NordicSemiconductor\nRF_Drivers\3.0.1\gpiote\nrf_drv_gpiote.c(43): error:  #20: identifier "GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS" is undefined
nrf_drv_gpiote_evt_handler_t handlers[NUMBER_OF_GPIO_TE+GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS];
C:\Keil_v5\ARM\PACK\NordicSemiconductor\nRF_Drivers\3.0.1\gpiote\nrf_drv_gpiote.c(157): error:  #20: identifier "GPIOTE_CONFIG_IRQ_PRIORITY" is undefined
nrf_drv_common_irq_enable(GPIOTE_IRQn, GPIOTE_CONFIG_IRQ_PRIORITY);
C:\Keil_v5\ARM\PACK\NordicSemiconductor\nRF_Drivers\3.0.1\gpiote\nrf_drv_gpiote.c: 0 warnings, 2 errors
".\_build\nrf51422_xxac_s110.axf" - 2 Error(s), 0 Warning(s).
If I left the device to nRF51422, the error would not appear. I found that there were two different nrf_drv_gpiote.h, one for nRF51422 and the other nRF51822. In nrf_drv_gpiote.h for nRF51422,
#define GPIOTE_ENABLED 1
But in nrf_drv_gpiote.h for nRF51822,
#define GPIOTE_ENABLED 0
When I tried to build using nRF51422 as the device and uploaded the app, the beacon could not be detected by the nRF master control panel on an Android phone. Its LED did not blink either.
What steps have I missed?
  • The configuration of GPIOTE_ENABLED is example specific. for some example it is needed and for some it is not. If you are using packs then i think disabling GPIOTE_ENABLED for 51822 is a mistake inside the pack manager.
    Please select the device as 51822 and change to
    manually.
  • I enabled GPIOTE as suggested. It could be built. The hex file was uploaded successfully using nRFgo studio and could be verified.
    However, the app did not seem to work. The nRF Master control panel could not detect it. The LEDs did not blink either.
    Is there any guide/checklist on how to migrate a project from PCA10028 to PCA20006?
    In Keil, I changed the settings in Flash > Configure flash tools.
    • Device: 51822 xxA
    • C/C++: BOARD_PCA20006
    • Target: Xtal:16.0
  • I am having exactly the same issue. GPIOTE enabled, Base address adjusted to 0x18000, with 51822 XXAA (256kB, 16kB). The hex and softdevice 110 got uploaded fine, but advertisement does not seem to be detected by nRF Beacons. Are we missing anything?
  • i have noticed you replies just now, but its late night here, i will have to try out the example to see what is being missed, i will update you guys tomorrow.
  • I just checked with your settings and changed only one
    Target: ROM (start=0x18000; size=0x28000); RAM (start=0x20002000; size=0x2000); Xtal=16.0
    And it worked ok, i was able to see the beacon in MCP
