FATAL ERROR: command exited with status 1: 'c:\ncs\toolchains\v2.1.2\opt\bin\cmake.EXE' --build 'e:\nrf\door_sample1\build'
Hi,I am using nrf52840 with nRF Connect SDK V2.1.2.I am trying to run nrf/samples/matter/template but getting the following error. But the similar code is run on my colleague's laptop with the same SDK version, and it has been build successfully. Is there any solution?
* Executing task: nRF Connect: Generate config nrf52840dk_nrf52840 for e:\nrf\door_sample1
Building door_sample1
west build --build-dir e:\nrf\door_sample1\build e:\nrf\door_sample1 --pristine --board nrf52840dk_nrf52840 -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONFIG_DEBUG_OPTIMIZATIONS=y -DCONFIG_DEBUG_THREAD_INFO=y -DBOARD_ROOT:STRING="e:/nrf/door_sample1"
-- Application: E:/nrf/door_sample1
-- Found Python3: C:/ncs/toolchains/v2.1.2/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.1.2/zephyr/.cache
-- Zephyr version: 3.1.99 (C:/ncs/v2.1.2/zephyr)
-- Board: nrf52840dk_nrf52840
-- Found host-tools: zephyr 0.14.1 (C:/ncs/toolchains/v2.1.2/opt/zephyr-sdk)
-- Found dtc: C:/ncs/toolchains/v2.1.2/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: zephyr 0.14.1 (C:/ncs/toolchains/v2.1.2/opt/zephyr-sdk)
-- Found BOARD.dts: C:/ncs/v2.1.2/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
-- Found devicetree overlay: E:/nrf/door_sample1/boards/nrf52840dk_nrf52840.overlay
-- Generated zephyr.dts: E:/nrf/door_sample1/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: E:/nrf/door_sample1/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: E:/nrf/door_sample1/build/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: E:/nrf/door_sample1/build/zephyr/dts.cmake
Parsing E:/nrf/door_sample1/Kconfig
Loaded configuration 'C:/ncs/v2.1.2/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
Merged configuration 'E:/nrf/door_sample1/prj.conf'
Merged configuration 'E:/nrf/door_sample1/build/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'E:/nrf/door_sample1/build/zephyr/.config'
Kconfig header saved to 'E:/nrf/door_sample1/build/zephyr/include/generated/autoconf.h'
-- The C compiler identification is GNU 10.3.0
-- The CXX compiler identification is GNU 10.3.0
-- Found assembler: C:/ncs/toolchains/v2.1.2/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Found Python3: C:/ncs/toolchains/v2.1.2/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
=== child image mcuboot - begin ===
loading initial cache file E:/nrf/door_sample1/build/mcuboot/child_image_preload.cmake
-- Application: C:/ncs/v2.1.2/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: C:/ncs/v2.1.2/bootloader/mcuboot/boot/zephyr/dts.overlay
-- Generated zephyr.dts: E:/nrf/door_sample1/build/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: E:/nrf/door_sample1/build/mcuboot/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: E:/nrf/door_sample1/build/mcuboot/zephyr/include/generated/device_extern.h
-- Including generated dts.cmake file: E:/nrf/door_sample1/build/mcuboot/zephyr/dts.cmake
Parsing C:/ncs/v2.1.2/modules/lib/matter/config/nrfconnect/chip-module/Kconfig.mcuboot.root
Merged configuration 'E:/nrf/door_sample1/child_image/mcuboot/prj.conf'
Merged configuration 'C:/ncs/v2.1.2/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
Merged configuration 'C:/ncs/v2.1.2/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'E:/nrf/door_sample1/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'E:/nrf/door_sample1/build/mcuboot/zephyr/.config'
Kconfig header saved to 'E:/nrf/door_sample1/build/mcuboot/zephyr/include/generated/autoconf.h'
CMake Warning at C:/ncs/v2.1.2/nrf/lib/flash_patch/CMakeLists.txt:8 (message):
--- WARNING: To maintain the integrity of secure boot, ---
--- enable CONFIG_DISABLE_FLASH_PATCH in production. ---
MCUBoot bootloader key file: C:/ncs/v2.1.2/bootloader/mcuboot/root-ec-p256.pem
-- Configuring done
-- Generating done
-- Build files have been written to: E:/nrf/door_sample1/build/mcuboot
=== child image mcuboot - end ===
CMake Warning at C:/ncs/v2.1.2/nrf/modules/mcuboot/CMakeLists.txt:286 (message):
--- WARNING: Using default MCUBoot key, it should not ---
--- be used for production. ---
CMake Warning at C:/ncs/v2.1.2/nrfxlib/openthread/cmake/extensions.cmake:114 (message):
Current nrf_security configuration does not provide all MBEDTLS options which are required by precompiled OpenThread libraries.
The minimum of MBEDTLS configuration is stored at: C:/ncs/v2.1.2/nrfxlib/openthread/lib/cortex-m4/hard-float/v1.3/mtd/oberon/nrf_security_mbedtls_configuration.h
C:/ncs/v2.1.2/nrfxlib/openthread/CMakeLists.txt:82 (check_openthread_dependencies)
CMake Warning at C:/ncs/v2.1.2/zephyr/CMakeLists.txt:1839 (message):
-- Found partition manager static configuration: E:/nrf/door_sample1/configuration/nrf52840dk_nrf52840/pm_static_dfu.yml
Partition 'mcuboot' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_pad' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_primary_app' is not included in the dynamic resolving since it is statically defined.
Partition 'settings_storage' is not included in the dynamic resolving since it is statically defined.
Partition 'mcuboot_secondary' is not included in the dynamic resolving since it is statically defined.
-- Configuring done
-- Generating done
[1/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/ncs/v2.1.2/mbedtls/library/debug.c.obj
[2/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedtls.dir/C_/ncs/v2.1.2/mbedtls/library/net_sockets.c.obj
[3/504] Generating include/generated/version.h
-- Zephyr version: 3.1.99 (C:/ncs/v2.1.2/zephyr), build: v3.1.99-ncs1-1
[4/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.1.2/mbedtls/library/base64.c.obj
[5/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/ncs/v2.1.2/mbedtls/library/x509_csr.c.obj
[6/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.1.2/mbedtls/library/padlock.c.obj
[7/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.1.2/mbedtls/library/asn1parse.c.obj
[8/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.1.2/mbedtls/library/platform.c.obj
[9/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.1.2/mbedtls/library/asn1write.c.obj
[10/504] Creating directories for 'mcuboot_subimage'
[11/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.1.2/mbedtls/library/nist_kw.c.obj
[12/504] No download step for 'mcuboot_subimage'
[13/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.1.2/mbedtls/library/version.c.obj
[14/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedx509.dir/C_/ncs/v2.1.2/mbedtls/library/x509_crt.c.obj
[15/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.1.2/mbedtls/library/oid.c.obj
[16/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.1.2/mbedtls/library/platform_util.c.obj
[17/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.1.2/mbedtls/library/constant_time.c.obj
[18/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto_base.dir/C_/ncs/v2.1.2/mbedtls/library/bignum.c.obj
[19/504] No update step for 'mcuboot_subimage'
[20/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.1.2/mbedtls/library/psa_crypto_storage.c.obj
[21/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.1.2/mbedtls/library/psa_crypto_aead.c.obj
[22/504] No patch step for 'mcuboot_subimage'
[23/504] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\libmbedcrypto_base.a
[24/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.1.2/mbedtls/library/psa_crypto_hash.c.obj
[25/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.1.2/mbedtls/library/psa_crypto_client.c.obj
[26/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.1.2/mbedtls/library/psa_crypto_cipher.c.obj
[27/504] Building C object modules/nrfxlib/nrfxlib/nrf_security/src/CMakeFiles/mbedcrypto.dir/C_/ncs/v2.1.2/mbedtls/library/psa_crypto_ecp.c.obj
[28/504] No configure step for 'mcuboot_subimage'
[28/504] Performing build step for 'mcuboot_subimage'
[1/183] Generating include/generated/version.h
[2/183] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/183] Generating include/generated/driver-validation.h
[4/183] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[5/183] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[6/183] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/183] Generating include/generated/offsets.h
[8/183] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[9/183] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[10/183] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[11/183] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[12/183] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.1.2/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[13/183] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.1.2/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
[14/183] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[15/183] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.1.2/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[16/183] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[17/183] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[18/183] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[19/183] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[20/183] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[21/183] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[22/183] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[23/183] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[24/183] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[25/183] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[26/183] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[27/183] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[28/183] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[29/183] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[30/183] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[31/183] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[32/183] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[33/183] Linking C static library zephyr\arch\common\libisr_tables.a
[34/183] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[35/183] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[36/183] Generating linker_zephyr_pre0.cmd
[37/183] Generating linker_zephyr_pre1.cmd
[38/183] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/nanosleep.c.obj
[39/183] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/perror.c.obj
[40/183] Building C object zephyr/lib/posix/CMakeFiles/lib__posix.dir/pthread_common.c.obj
[41/183] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[42/183] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[43/183] Linking C static library zephyr\arch\common\libarch__common.a
[44/183] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[45/183] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[46/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[47/183] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[48/183] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[49/183] Generating ../../../include/generated/libc/minimal/strerror_table.h
[50/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[51/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[52/183] Generating zephyr/autogen-pubkey.c
[53/183] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[54/183] Linking C static library zephyr\lib\posix\liblib__posix.a
[55/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[56/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[57/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[58/183] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[59/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[60/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[61/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[62/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[63/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[64/183] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[65/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[66/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[67/183] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[68/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[69/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[70/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[71/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[72/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[73/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[74/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[75/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[76/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[77/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[78/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[79/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[80/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[81/183] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[82/183] Building C object CMakeFiles/app.dir/os.c.obj
[83/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
[84/183] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
[85/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
[86/183] Building C object CMakeFiles/app.dir/keys.c.obj
[87/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
[88/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
[89/183] Building C object CMakeFiles/app.dir/main.c.obj
[90/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
[91/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
[92/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
[93/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
[94/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
[95/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
[96/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
[97/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
[98/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
[99/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/ext/mbedtls-asn1/src/platform_util.c.obj
[100/183] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
[101/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/ext/nrf/cc310_glue.c.obj
[102/183] Building C object CMakeFiles/app.dir/C_/ncs/v2.1.2/bootloader/mcuboot/ext/mbedtls-asn1/src/asn1parse.c.obj
[103/183] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[104/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[105/183] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
[106/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[107/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[108/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[109/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[110/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[111/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[112/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[113/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[114/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[115/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[116/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[117/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[118/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[119/183] Linking C static library app\libapp.a
[120/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[121/183] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[122/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[123/183] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[124/183] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[125/183] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[126/183] Building C object zephyr/soc/arm/nordic_nrf/nrf52/CMakeFiles/soc__arm__nordic_nrf__nrf52.dir/soc.c.obj
[127/183] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[128/183] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[129/183] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
[130/183] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[131/183] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[132/183] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/nrf_qspi_nor.c.obj
[133/183] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[134/183] Linking C static library zephyr\libzephyr.a
[135/183] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[136/183] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[137/183] Linking C static library zephyr\soc\arm\nordic_nrf\nrf52\libsoc__arm__nordic_nrf__nrf52.a
[138/183] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[139/183] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[140/183] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_acl.c.obj
[141/183] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[142/183] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.1.2/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[143/183] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/C_/ncs/v2.1.2/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
[144/183] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[145/183] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
[146/183] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.1.2/modules/hal/nordic/nrfx/mdk/system_nrf52840.c.obj
[147/183] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[148/183] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.1.2/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[149/183] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.1.2/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
[150/183] Linking C static library modules\nrf\lib\fprotect\lib..__nrf__lib__fprotect.a
[151/183] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[152/183] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[153/183] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.1.2/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[154/183] Linking C static library modules\mcuboot\boot\bootutil\zephyr\libmcuboot_util.a
[155/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[156/183] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.1.2/modules/hal/nordic/nrfx/drivers/src/nrfx_qspi.c.obj
[157/183] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.1.2/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[158/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[159/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[160/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[161/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[162/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[163/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[164/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[165/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[166/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[167/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[168/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[169/183] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[170/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[171/183] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[172/183] Linking C static library zephyr\kernel\libkernel.a
[173/183] Linking C executable zephyr\zephyr_pre0.elf
[174/183] Generating dev_handles.c
[175/183] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/misc/empty_file.c.obj
[176/183] Building C object zephyr/CMakeFiles/zephyr_pre1.dir/dev_handles.c.obj
[177/183] Linking C executable zephyr\zephyr_pre1.elf
[178/183] Generating linker.cmd
[179/183] Generating isr_tables.c, isrList.bin
[180/183] Building C object zephyr/CMakeFiles/zephyr_final.dir/misc/empty_file.c.obj
[181/183] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
[182/183] Building C object zephyr/CMakeFiles/zephyr_final.dir/dev_handles.c.obj
[183/183] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 28480 B 28 KB 99.33%
SRAM: 18624 B 256 KB 7.10%
IDT_LIST: 0 GB 2 KB 0.00%
[429/504] No patch step for 'chip-gn'
[430/504] No configure step for 'chip-gn'
[431/504] No install step for 'mcuboot_subimage'
[432/504] Performing build step for 'chip-gn'
Generating compile_commands took 612ms
Done. Made 88 targets from 90 files in 2035ms
ninja: error: obj/examples/providers/device_info_provider.ninja:9: expected newline, got ':'
[433/504] Completed 'mcuboot_subimage'
FAILED: modules/connectedhomeip/src/chip-gn-stamp/chip-gn-build modules/connectedhomeip/-lCHIP modules/connectedhomeip/-lMatterDeviceInfoProviderExample
cmd.exe /C "cd /D E:\nrf\door_sample1\build\modules\connectedhomeip && C:\ncs\toolchains\v2.1.2\opt\bin\python.exe C:/ncs/v2.1.2/modules/lib/matter/config/nrfconnect/chip-module/make_gn_args.py @args.tmp > args.gn && C:/ncs/toolchains/v2.1.2/opt/bin/gn.exe --root=C:/ncs/v2.1.2/modules/lib/matter --root-target=C:/ncs/v2.1.2/modules/lib/matter/config/nrfconnect/chip-gn --dotfile=C:/ncs/v2.1.2/modules/lib/matter/config/nrfconnect/chip-gn/.gn --script-executable=C:/ncs/toolchains/v2.1.2/opt/bin/python.exe --export-compile-commands gen --check --fail-on-unused-args . && ninja"
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
Thanking you,
Franshee Francis
