NRF9160-DK debug port is not working for programming thingy91
The NRF9160-DK is not recognized  for programming Thingy91 by the debug port P19  after Nordic tool and J-Link firmware update from 3.10 to 3.12.
It showed error on VSCode when try to programming.
(IssueDirect flash to thingy91 by MCUboot is good)
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: C:\Users\slee\sdk-nrf\applications\asset_tracker_v2\build\zephyr\merged.hex
ERROR: Unable to connect to a debugger.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program 'C:\Users\slee\sdk-nrf\applications\asset_tracker_v2\build\zephyr\merged.hex' --sectorerase --verify -f NRF91 --snr 960011733
C:\Users\slee>nrfjprog -r
C:\Users\slee>nrfjprog -r --log
ERROR: [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
C:\Users\slee>nrfjprog -v
nrfjprog version: 10.15.2 external
JLinkARM.dll version: 7.84a
Applying system reset.
Run.
It very similar of this case Unable to flash nrf52820 using nrf52833DK debug out. - Nordic Q&A - Nordic DevZone - Nordic DevZone (nordicsemi.com)
  • Sorry about that, I mean I try to update nRF connect for desktop from 3.10.0 to 3.12.0
    For JLinkARM.dll which I try is 7.58,7.66 and the latest 7.84a all is failure and  some result.
    I have two DK board both some result. I also use a complete new Thingy91 try is some result
  • Not sure, if that's related, which OS and version do you use?
    Did you make sure that the Thingy:91 is also powered on? Also, from your log, it can been seen that you use nRF Comman Line Tools v10.15.2. Could you try updating this to the latest version? https://www.nordicsemi.com/Products/Development-tools/nRF-Command-Line-Tools/Download?lang=en#infotabs
    -Priyanka
  • Dear Priyanka:
    I am using Win10Pro 21H2.
    I just try to update the command line tools, but some:
    The thingy91 is good flash directly from USB as well as the DK board well programming itself.
    So that I don't know where the problem from , should I need try Linux ?
    nrfjprog version: 10.18.1 external
    [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
