pwm always consume 300uA after app_pwm_init
I am using PWM for a buzzer. It is working, but the current consumption is always 300uA when PWM is not in use. This minimal current consumption appears right after the app_pwm_init function and never stops.
Could you confirm that this implementation is correct? Should I initialize the PWM instance for every use or can I resue an instance like in the code below?
APP_PWM_INSTANCE(PWM1,1);                   // Create the instance "PWM1" using TIMER1.
void pwm_ready_callback(uint32_t pwm_id)    // PWM callback function
void buzzer_kernel_init(void)
	uint32_t err_code;
	uint32_t duty = 50;
	// PWM
	app_pwm_config_t pwm1_cfg = APP_PWM_DEFAULT_CONFIG_1CH(250, WATCH_BUZZER_PIN_D);
	err_code = app_pwm_init(&PWM1,&pwm1_cfg,pwm_ready_callback);
	app_pwm_enable(&PWM1);
	// Set the duty cycle - keep trying until PWM is ready...
	while (app_pwm_channel_duty_set(&PWM1, 0, duty) == NRF_ERROR_BUSY);
	app_pwm_disable(&PWM1);
	// Do bip
	nrf_delay_ms(50);
	nrf_delay_ms(50);
	// Do bip
	nrf_delay_ms(50);
void buzzer_kernel_on(void)
void buzzer_kernel_off(void)
