I'm able to enable AT command and shell command terminal separately on nRF9160 DK. However, is there anyway to enable both AT and shell command?
1) in prj.conf
CONFIG_SHELL=y It gives the uart shell CLI terminal, however AT command won't be available. Is there anyway to have both, or it needs some special command to switch between them?
# AT host library
CONFIG_AT_HOST_LIBRARY=y
2) in addition, if I set the CONFIG_NRF_MODEM_LIB_SYS_INIT=y, there is no UART shell showing up, but only AT command support, either from LTE_Link_Monitor tool or just Tera terminal tool
# Modem library
CONFIG_NRF_MODEM_LIB=y
CONFIG_NRF_MODEM_LIB_SYS_INIT=n
