Endpoint 1, Cluster 0x0000_0006 update version to d0856da6, log message shown when setting a value in on/off attribute.
As the title suggests, whenever I try to set the on/off attribute of the on/off cluster, the above log message is shown.
I am using vs code with nrf connect sdk v2.1.1 and working off the template sample.
I added 8 endpoints to my project with 8 gpio interrupts triggering the setting of the on/off attribute in their respective endpoints.
But whenever I trigger the gpio interrupt to set the on/off attribute, that particular log message is shown. Its the same for all the other endpoints as well.
I don't understand why this is happening. What does it mean?
I will attach the entire log below for your reference. Thank you in advance.
uart:~$ I: nRF5 802154 radio initialized
I: 4 Sectors of 4096 bytes
I: alloc wra: 0, f58
I: data wra: 0, 90
*** Booting Zephyr OS build v3.1.99-ncs1  ***
I: Init CHIP stack
I: 169 [DL]BLE address: FC:31:F1:20:44:D8
I: 193 [DL]OpenThread started: OK
I: 196 [DL]Setting OpenThread device type to MINIMAL END DEVICE
Init Touch Config
I: 204 [SVR]Server initializing...
D: 207 [FP]Initializing FabricTable from persistent storage
I: 212 [TS]Last Known Good Time: 2023-01-04T17:56:09
I: 217 [DMG]AccessControl: initializing
I: 221 [DMG]Examples::AccessControlDelegate::Init
I: 225 [DMG]AccessControl: setting
I: 228 [DMG]DefaultAclStorage: initializing
I: 232 [DMG]DefaultAclStorage: 0 entries loaded
D: 237 [IN]UDP::Init bind&listen port=5540
E: 240 [IN]SO_REUSEPORT failed: 109
D: 244 [IN]UDP::Init bound to port=5540
D: 247 [IN]BLEBase::Init - setting/overriding transport
D: 252 [IN]TransportMgr initialized
D: 257 [DL]Using Thread extended MAC for hostname.
I: 262 [ZCL]Using ZAP configuration...
D: 267 [DMG]Failed to read stored attribute (0, 0x0000_0028, 0x0000_0005: a0
I: 277 [DMG]AccessControlCluster: initializing
D: 281 [DMG]Endpoint 0, Cluster 0x0000_0030 update version to bcce792
D: 287 [DL]Boot reason: 1
D: 290 [ZCL]GeneralDiagnostics: OnDeviceReboot
D: 294 [DMG]Endpoint 0, Cluster 0x0000_0033 update version to ea33be60
D: 300 [EVL]LogEvent event number: 0x0000000000010000 priority: 2, endpoint id:  0x0 cluster id: 0x0000_0033 event id: 0x3 Sys timestamp: 0x000000000000012C
I: 314 [ZCL]Initiating Admin Commissioning cluster.
D: 319 [DMG]Endpoint 1, Cluster 0x0000_0004 update version to 880780d2
D: 325 [DMG]Endpoint 1, Cluster 0x0000_0004 update version to 880780d3
D: 331 [DMG]Endpoint 1, Cluster 0x0000_0005 update version to f7d42d1e
D: 338 [DMG]Endpoint 2, Cluster 0x0000_0004 update version to 6d8daf35
D: 344 [DMG]Endpoint 2, Cluster 0x0000_0004 update version to 6d8daf36
D: 350 [DMG]Endpoint 2, Cluster 0x0000_0005 update version to 2e1ded34
D: 357 [DMG]Endpoint 3, Cluster 0x0000_0004 update version to fb183a59
D: 363 [DMG]Endpoint 3, Cluster 0x0000_0004 update version to fb183a5a
D: 369 [DMG]Endpoint 3, Cluster 0x0000_0005 update version to bdb11ff5
D: 376 [DMG]Endpoint 4, Cluster 0x0000_0004 update version to e9f14448
D: 382 [DMG]Endpoint 4, Cluster 0x0000_0004 update version to e9f14449
D: 389 [DMG]Endpoint 4, Cluster 0x0000_0005 update version to f8a3c129
D: 395 [DMG]Endpoint 5, Cluster 0x0000_0004 update version to 150a81f0
D: 401 [DMG]Endpoint 5, Cluster 0x0000_0004 update version to 150a81f1
D: 408 [DMG]Endpoint 5, Cluster 0x0000_0005 update version to e4fcc314
D: 414 [DMG]Endpoint 6, Cluster 0x0000_0004 update version to 7efc24ba
D: 420 [DMG]Endpoint 6, Cluster 0x0000_0004 update version to 7efc24bb
D: 427 [DMG]Endpoint 6, Cluster 0x0000_0005 update version to 44fc8174
D: 433 [DMG]Endpoint 7, Cluster 0x0000_0004 update version to f478cced
D: 440 [DMG]Endpoint 7, Cluster 0x0000_0004 update version to f478ccee
D: 446 [DMG]Endpoint 7, Cluster 0x0000_0005 update version to a33241e1
D: 452 [DMG]Endpoint 8, Cluster 0x0000_0004 update version to 5e607041
D: 459 [DMG]Endpoint 8, Cluster 0x0000_0004 update version to 5e607042
D: 465 [DMG]Endpoint 8, Cluster 0x0000_0005 update version to e8c6e6c0
D: 473 [IN]SecureSession[0x20004550]: Allocated Type:1 LSID:64631
D: 479 [SC]Assigned local session key ID 64631
D: 483 [SC]Waiting for PBKDF param request
D: 486 [DL]CHIPoBLE advertising set to on
I: 490 [DIS]Updating services using commissioning mode 1
D: 495 [DL]Using Thread extended MAC for hostname.
D: 500 [DL]Using Thread extended MAC for hostname.
I: 505 [DIS]Advertise commission parameter vendorID=65521 productID=32768 discriminator=3840/15 cm=1
E: 514 [DIS]Failed to advertise commissionable node: 3
E: 519 [DIS]Failed to finalize service update: 1c
I: 523 [DIS]Updating services using commissioning mode 1
D: 528 [DL]Using Thread extended MAC for hostname.
D: 533 [DL]Using Thread extended MAC for hostname.
I: 538 [DIS]Advertise commission parameter vendorID=65521 productID=32768 discriminator=3840/15 cm=1
E: 547 [DIS]Failed to advertise commissionable node: 3
E: 552 [DIS]Failed to finalize service update: 1c
I: 556 [DIS]Delaying proxy of operational discovery: missing delegate
I: 563 [IN]CASE Server enabling CASE session setups
D: 568 [IN]SecureSession[0x20004608]: Allocated Type:2 LSID:64632
D: 573 [SC]Allocated SecureSession (0x20004608) - waiting for Sigma1 msg
I: 580 [SVR]Joining Multicast groups
D: 583 [ZCL]Emitting StartUp event
D: 586 [EVL]LogEvent event number: 0x0000000000010001 priority: 2, endpoint id:  0x0 cluster id: 0x0000_0028 event id: 0x0 Sys timestamp: 0x000000000000024A
I: 600 [SVR]Server Listening...
I: 603 [DL]Device Configuration:
I: 606 [DL]  Serial Number: 11223344556677889900
I: 610 [DL]  Vendor Id: 65521 (0xFFF1)
I: 614 [DL]  Product Id: 32768 (0x8000)
I: 618 [DL]  Hardware Version: 0
I: 621 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 626 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 633 [DL]  Manufacturing Date: (not set)
I: 637 [DL]  Device Type: 65535 (0xFFFF)
I: 641 [SVR]SetupQRCode: [MT:Y.K9042C00KA0648G00]
I: 645 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 651 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3AY.K9042C00KA0648G00
I: 660 [SVR]Manual pairing code: [34970112332]
I: 665 [DL]CHIP task running
I: 672 [DL]CHIPoBLE advertising started
Entered isr
enteer UpdateClusterState
D: 3457 [DMG]Endpoint 1, Cluster 0x0000_0006 update version to 6a9bbec9
ext UpdateClusterState
Exited isr
Parents Reply
  • Sorry for the delayed response. Thank you for your reply, the problem was with the matter callback function signature. I had used the
    "void MatterPostAttributeChangeCallback(const chip::app::ConcreteAttributePath & attributePath, uint8_t mask, uint8_t type, uint16_t size, uint8_t * value)" instead of
    "void MatterPostAttributeChangeCallback(const chip::app::ConcreteAttributePath &attributePath, uint8_t type, uint16_t size, uint8_t *value)" with the former being from an older sdk and the latter from the version I'm using. Surprisingly, the former didn't call an error.
