Flash read/write with S340 SoftDevcie
I need help regarding flash memory read on nRF52840 device, SDk16, SD=340.
I have using the fds libarary for memory read/write in my code for many years now. However, after changing the softdevice from S140 to S340 started causing issues with reading the flash after writing. The same code is used in both cases, for S140 it works fine but for S340, upon memory read after a power cycle, the device crashes and becomes unresponsive.
Is there something changed with this SD? Is there anybody else facing same problem?
Im attaching the fds if that helps.
Thanks.
#include <stdint.h>
#include <string.h>
#include "nrf.h"
#include "nordic_common.h"
#ifdef SOFTDEVICE_PRESENT
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#else
#include "nrf_drv_clock.h"
#include "fds.h"
#include "app_timer.h"
#include "app_error.h"
#include "nrf_cli.h"
#include "fds_driver.h"
#include "nrf_delay.h"
//#define NRF_LOG_MODULE_NAME app
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "Services/scr_service.h"
#include "Services/dev_service.h"
#include "globals.h"
/* A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_CONN_CFG_TAG    1
// FOr Hotshot
#define FDS_SUCCESS             NRF_SUCCESS
uint16_t script_total_length = 0;
uint64_t last_log_index = 0;
/* Array to map FDS return values to strings. */
char const * fds_err_str[] =
    "FDS_SUCCESS",
    "FDS_ERR_OPERATION_TIMEOUT",
    "FDS_ERR_NOT_INITIALIZED",
    "FDS_ERR_UNALIGNED_ADDR",
    "FDS_ERR_INVALID_ARG",
    "FDS_ERR_NULL_ARG",
    "FDS_ERR_NO_OPEN_RECORDS",
    "FDS_ERR_NO_SPACE_IN_FLASH",
    "FDS_ERR_NO_SPACE_IN_QUEUES",
    "FDS_ERR_RECORD_TOO_LARGE",
    "FDS_ERR_NOT_FOUND",
    "FDS_ERR_NO_PAGES",
    "FDS_ERR_USER_LIMIT_REACHED",
    "FDS_ERR_CRC_CHECK_FAILED",
    "FDS_ERR_BUSY",
    "FDS_ERR_INTERNAL",
/* Array to map FDS events to strings. */
static char const * fds_evt_str[] =
    "FDS_EVT_INIT",
    "FDS_EVT_WRITE",
    "FDS_EVT_UPDATE",
    "FDS_EVT_DEL_RECORD",
    "FDS_EVT_DEL_FILE",
    "FDS_EVT_GC",
static rgb_values_t rgb_dummy_cfg =
    .red    = 0x0,
    .green  = 0x0,
    .blue   = 0x0,
    .ant_address = 0x0,
//    .ant_rf_freq = 0x0,
//    .ant_dev_type = 0x0,
static data_values_t data_dummy_cfg =
    .time_stamp    = 0x0,
static show_script_t scr_dummy_cfg =
    .script = "0123456789ABCDEF0123456789ABCDEF0123456789ABCDEF0123456789ABCDEF0123456789ABCDEF0123456789ABCDEF0123",
static ant_bytes_t ant_dummy_cfg =
    .data = "01",
#ifdef INTERNAL_LOG_ENABLED
static log_value_t log_dummy_cfg =
    .log_table = "",
static fds_record_t const rgb_dummy_record =
    .file_id  = RGB_FILE_ID,
    .key      = RGB_REC_KEY,
    .data.p_data = &rgb_dummy_cfg,
    .data.length_words = (sizeof(&rgb_dummy_cfg) + 3) / sizeof(uint32_t),
    //.data.p_data = sizeof(&rgb_dummy_cfg),
static fds_record_t const data_dummy_record =
    .file_id  = DATA_FILE_ID,
    .key      = DATA_REC_KEY,
    .data.p_data = &data_dummy_cfg,
    .data.length_words = (sizeof(&data_dummy_cfg) + 3) / sizeof(uint32_t),
static fds_record_t const log_dummy_record =
    .file_id  = LOG_FILE_ID,
    .key      = LOG_REC_KEY,
    .data.p_data = &log_dummy_cfg,
    .data.length_words = LOG_DATA_SIZE/4,  //(sizeof(&log_dummy_cfg) + 3) / sizeof(uint32_t),
static fds_record_t const scr_dummy_record =
    .file_id  = SCR_FILE_ID,
    .key      = SCR_REC_KEY,
    .data.p_data = &scr_dummy_cfg,
    .data.length_words = SCRIPT_LENGTH/4, //(sizeof(&scr_dummy_cfg) + 3) / sizeof(uint32_t),
static fds_record_t const ant_dummy_record =
    .file_id  = ANT_FILE_ID,
    .key      = ANT_REC_KEY,
    .data.p_data = &ant_dummy_cfg,
    .data.length_words = (sizeof(&ant_dummy_cfg) + 3) / sizeof(uint32_t),
/* Keep track of the progress of a delete_all operation. */
static struct
    bool delete_next;   //!< Delete next record.
    bool pending;       //!< Waiting for an fds FDS_EVT_DEL_RECORD event, to delete the next record.
} m_delete_all;
/* Flag to check fds initialization. */
static bool volatile m_fds_initialized;
static void fds_evt_handler(fds_evt_t const * p_evt)
    NRF_LOG_GREEN("Event: %s received (%s)",
                  fds_evt_str[p_evt->id],
                  fds_err_str[p_evt->result]);
    switch (p_evt->id)
        case FDS_EVT_INIT:
            if (p_evt->result == FDS_SUCCESS)
                m_fds_initialized = true;
        case FDS_EVT_WRITE:
                NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->write.record_id);
                NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->write.file_id);
                NRF_LOG_INFO("Record key:\t0x%04x", p_evt->write.record_key);
        } break;
        case FDS_EVT_DEL_RECORD:
                NRF_LOG_INFO("Record ID:\t0x%04x",  p_evt->del.record_id);
                NRF_LOG_INFO("File ID:\t0x%04x",    p_evt->del.file_id);
                NRF_LOG_INFO("Record key:\t0x%04x", p_evt->del.record_key);
            m_delete_all.pending = false;
        } break;
bool record_delete_next(void)
    fds_find_token_t  tok   = {0};
    fds_record_desc_t desc  = {0};
    if (fds_record_iterate(&desc, &tok) == FDS_SUCCESS)
        ret_code_t rc = fds_record_delete(&desc);
        if (rc != FDS_SUCCESS)
            return false;
        return true;
        /* No records left to delete. */
        return false;
/**@brief   Begin deleting all records, one by one. */
void delete_all_begin(void)
    m_delete_all.delete_next = true;
/**@brief   Process a delete all command.
 * Delete records, one by one, until no records are left.
void delete_all_process(void)
    if (   m_delete_all.delete_next
        & !m_delete_all.pending)
        NRF_LOG_INFO("Deleting next record.");
        m_delete_all.delete_next = record_delete_next();
        if (!m_delete_all.delete_next)
            NRF_LOG_CYAN("No records left to delete.");
/**@brief   Sleep until an event is received. */
static void power_manage(void)
    (void) sd_app_evt_wait();
#else
    __WFE();
/**@brief   Wait for fds to initialize. */
static void wait_for_fds_ready(void)
    while (!m_fds_initialized)
        power_manage();
void fdsm_init(){
    ret_code_t rc;
    uint32_t *data;
    (void) fds_register(fds_evt_handler);
    NRF_LOG_INFO("Initializing fds...");
    rc = fds_init();
    APP_ERROR_CHECK(rc);
    /* Wait for fds to initialize. */
    wait_for_fds_ready();
    // Call garbage collector
    NRF_LOG_INFO("Running garbage collector...");
    rc = fds_gc();
    if (rc == FDS_SUCCESS){
        NRF_LOG_INFO("Garbage collection complete");
    // Delete files and records
    //rc = fds_file_delete(SCR_FILE_ID);
    //rc = fds_file_delete(RGB_FILE_ID);
    //nrf_delay_ms(10);
    NRF_LOG_INFO("Reading flash usage statistics...");
    fds_stat_t stat = {0};
    rc = fds_stat(&stat);
    NRF_LOG_INFO("Found %d valid records.", stat.valid_records);
    NRF_LOG_INFO("Found %d dirty records (ready to be garbage collected).", stat.dirty_records);
    //nrf_delay_ms(10);
void record_read_rgb(uint8_t *red, uint8_t *green, uint8_t *blue, uint8_t *ant_address/*, uint8_t *ant_rf_freq, uint8_t *ant_dev_type*/){
    ret_code_t rc;
    uint32_t *data;
    //NRF_LOG_INFO("Reading RGB Record...");
    // It is required to zero the token before first use. */
    memset(&tok, 0x00, sizeof(fds_find_token_t));
    rc = fds_record_find(RGB_FILE_ID, RGB_REC_KEY, &desc, &tok);
        // RGB record found
        #ifdef LOG_ENABLED_2
        NRF_LOG_INFO("RGB record found");
        // A config file is in flash. Let's update it.
        fds_flash_record_t config = {0};
        // Open the record and read its contents.
        rc = fds_record_open(&desc, &config);
        NRF_LOG_INFO("Found Record ID = %d",desc.record_id);
        // Copy the configuration from flash into m_dummy_cfg.
        memcpy(&rgb_dummy_cfg, config.p_data, sizeof(rgb_values_t));
        *red    = rgb_dummy_cfg.red;
        *green  = rgb_dummy_cfg.green;
        *blue   = rgb_dummy_cfg.blue;
        *ant_address = rgb_dummy_cfg.ant_address;
//        *ant_rf_freq = rgb_dummy_cfg.ant_rf_freq;
//        *ant_dev_type = rgb_dummy_cfg.ant_dev_type;
        //#ifdef LOG_ENABLED_2
        //NRF_LOG_INFO("RGB record values:%X,%X,%X", rgb_dummy_cfg.red, rgb_dummy_cfg.green, rgb_dummy_cfg.blue);
        //NRF_LOG_INFO("ANT settings from flash: %X, %X", ant_rf_freq, ant_dev_type);
        //#endif
        // Close the record when done reading.
        rc = fds_record_close(&desc);
    else{
        // System config not found; write a new one.
        NRF_LOG_INFO("RGB record not found");
void record_update_rgb(uint8_t red, uint8_t green, uint8_t blue, uint8_t ant_address/*, uint8_t ant_rf_freq, uint8_t ant_dev_type*/){
    ret_code_t rc;
    NRF_LOG_INFO("Updating RGB Record...");
        // RGB record found
        rgb_dummy_cfg.red = red;
        rgb_dummy_cfg.green = green;
        rgb_dummy_cfg.blue = blue;
        rgb_dummy_cfg.ant_address = ant_address;
        NRF_LOG_INFO("Saving R=%X, G=%X, B=%X, ANT_Addr=%X", rgb_dummy_cfg.red, rgb_dummy_cfg.green, rgb_dummy_cfg.blue, rgb_dummy_cfg.ant_address);
        rc = fds_record_update(&desc, &rgb_dummy_record);
        //APP_ERROR_CHECK(rc);
            NRF_LOG_INFO("RGB record updated: %X,%X,%X", rgb_dummy_cfg.red, rgb_dummy_cfg.green, rgb_dummy_cfg.blue);
            NRF_LOG_INFO("RGB record id: %d", desc.record_id);
        else{
            NRF_LOG_INFO("Creating new RGB file...");
            rc = fds_record_write(&desc, &rgb_dummy_record);
            if (rc != FDS_SUCCESS){
                NRF_LOG_INFO("Could not save RGB address of the device.");
    else{
char * record_read_scr(){
    ret_code_t rc;
    uint32_t *data;
    // Make log entry
    log_data("SLM");
    NRF_LOG_INFO("Reading Script Record...");
    rc = fds_record_find(SCR_FILE_ID, SCR_REC_KEY, &desc, &tok);
        // Script record found
        NRF_LOG_INFO("Script record found");
        memcpy(&scr_dummy_cfg, config.p_data, sizeof(show_script_t));
        //*script = scr_dummy_cfg.script;
        NRF_LOG_INFO("Script record values:");
        NRF_LOG_INFO("p_data:");
        NRF_LOG_HEXDUMP_INFO(config.p_data, sizeof(config.p_data));
        NRF_LOG_INFO("Script data read.");
        NRF_LOG_INFO("dummy:");
        //NRF_LOG_HEXDUMP_INFO(scr_dummy_cfg.script, sizeof(scr_dummy_cfg.script));
        // Calculate length of recored
        for (int i=0; i<121; i++){
            // If end of script found, terminate
            if (scr_dummy_cfg.script[i] == 0xFF)
            script_total_length++;
        // Read the current script ID
        scr_script_id = scr_dummy_cfg.script[script_total_length+1];
        NRF_LOG_INFO("Script total length: %d", script_total_length);
        NRF_LOG_INFO("Script ID: 0x%2X", scr_script_id);
        return scr_dummy_cfg.script;
    else{
        NRF_LOG_INFO("Script record not found");
void record_update_scr(char script[], int len){
    ret_code_t rc;
    // Make log entry
    log_data("SUP");
    // Call garbage collector before saving script data
    rc = fds_gc();
    NRF_LOG_INFO("Updating Script Record...");
    //NRF_LOG_INFO("Received string:");
    //NRF_LOG_HEXDUMP_INFO(script, sizeof(scr_dummy_cfg.script));
    //script_id = script[len-1];
    //NRF_LOG_INFO("Script ID: %d", script_id);
    // copy data into scr_dummy_cfg
    //int len = sizeof(scr_dummy_cfg.script);
    int i=0;
    for (i=0; i<len; i++){
        scr_dummy_cfg.script[i] = script[i];
    for (i=len; i<scr_dummy_record.data.length_words*4; i++){
        scr_dummy_cfg.script[i] = 0;
    NRF_LOG_INFO("Copied/dummy string");
    NRF_LOG_INFO("Copied/dummy string len: %d", len); //strlen(scr_dummy_cfg.script))
    //NRF_LOG_INFO("Record len: %d", scr_dummy_record.data.length_words);
        // RGB record found
        rc = fds_record_update(&desc, &scr_dummy_record);
            NRF_LOG_INFO("Script record updated");
            //NRF_LOG_INFO("Script record id: %d", desc.record_id);
    else{
        NRF_LOG_INFO("Creating new Script file...");
        rc = fds_record_write(&desc, &scr_dummy_record);
void record_read_ant(){
    ret_code_t rc;
    uint32_t *data;
    // Make log entry
    log_data("SLM");
    rc = fds_record_find(ANT_FILE_ID, ANT_REC_KEY, &desc, &tok);
        memcpy(&ant_dummy_cfg, config.p_data, sizeof(ant_bytes_t));
        ant_rf_frequency = ant_dummy_cfg.data[0];
        ant_channel_id_dev_type = ant_dummy_cfg.data[1];
        NRF_LOG_INFO("ANT freq read: %d", ant_rf_frequency);
        NRF_LOG_INFO("ANT type read: %d", ant_channel_id_dev_type);
        //return scr_dummy_cfg.script;
    else{
        NRF_LOG_INFO("ANT record not found");
void record_update_ant(char data[2]){
    ret_code_t rc;
    ant_dummy_cfg.data[0] = data[0];
    ant_dummy_cfg.data[1] = data[1];
    //NRF_LOG_INFO("Copied/dummy string for ANT network: %02x, %02x", data[0], data[1]);
    NRF_LOG_HEXDUMP_INFO(ant_dummy_cfg.data, sizeof(ant_dummy_cfg.data));
    //NRF_LOG_INFO("Copied/dummy string len: %d", len); //strlen(scr_dummy_cfg.script))
        // RGB record found
        NRF_LOG_INFO("ANT record found");
        rc = fds_record_update(&desc, &ant_dummy_record);
            NRF_LOG_INFO("ANT record updated");
    else{
        NRF_LOG_INFO("Creating new ANTt file...");
        rc = fds_record_write(&desc, &ant_dummy_record);
char * record_read_log(){
    ret_code_t rc;
    uint32_t *data;
    rc = fds_record_find(LOG_FILE_ID, LOG_REC_KEY, &desc, &tok);
        NRF_LOG_INFO("Log record found");
        memcpy(&log_dummy_cfg, config.p_data, sizeof(log_value_t));
        NRF_LOG_INFO("Log record values:");
//        NRF_LOG_INFO("Log data read.");
//        NRF_LOG_INFO("dummy:");
//        NRF_LOG_HEXDUMP_INFO(log_dummy_cfg.log_table, sizeof(log_dummy_cfg.log_table));
        last_log_index = strlen(log_dummy_cfg.log_table);
        NRF_LOG_INFO("last_log_index:%d", last_log_index);
//        // Calculate length of recored
//        log_total_length = 0;
//        for (int i=0; i<121; i++){
//            // If end of script found, terminate
//            if (log_dummy_cfg.log_table[i] == 0xFF)
//                break;
//            script_total_length++;
        //scr_script_id = scr_dummy_cfg.script[script_total_length+1];
        //NRF_LOG_INFO("Script total length: %d", script_total_length);
        //NRF_LOG_INFO("Script ID: 0x%2X", scr_script_id);
        return log_dummy_cfg.log_table;
    else{
        NRF_LOG_INFO("Log record not found");
void record_update_log(char log_data[], int len){
    ret_code_t rc;
    NRF_LOG_INFO("Updating LOG Record...");
    // copy data into log_dummy_cfg
    //int len = sizeof(log_dummy_cfg.log_table);
    int i=0;
        log_dummy_cfg.log_table[i] = log_data[i];
    for (i=len; i<log_dummy_record.data.length_words*4; i++){
        log_dummy_cfg.log_table[i] = 0;
//    NRF_LOG_INFO("Copied/dummy log");
//    NRF_LOG_INFO("Copied/dummy log len: %d", len); //strlen(scr_dummy_cfg.script))
        // LOG record found
        NRF_LOG_INFO("LOG record found");
        rc = fds_record_update(&desc, &log_dummy_record);
            NRF_LOG_INFO("LOG record updated: %X", log_dummy_cfg.log_table);
            NRF_LOG_INFO("LOG record id: %d", desc.record_id);
    else{
        NRF_LOG_INFO("Creating new LOG file...");
        rc = fds_record_write(&desc, &log_dummy_record);
void record_read_data(uint8_t *time_stamp){
    ret_code_t rc;
    uint32_t *data;
    NRF_LOG_INFO("Reading DATA Record...");
    rc = fds_record_find(DATA_FILE_ID, DATA_REC_KEY, &desc, &tok);
        // DATA record found
        NRF_LOG_INFO("DATA record found");
        memcpy(&data_dummy_cfg, config.p_data, sizeof(data_values_t));
        *time_stamp    = data_dummy_cfg.time_stamp;
    else{
        NRF_LOG_INFO("DATA record not found");
void record_update_data(uint8_t time_stamp){
    ret_code_t rc;
    NRF_LOG_INFO("Updating DATA Record...");
        // RGB record found
        data_dummy_cfg.time_stamp = time_stamp;
        rc = fds_record_update(&desc, &data_dummy_record);
    else{
        NRF_LOG_INFO("Creating new DATA file...");
        rc = fds_record_write(&desc, &data_dummy_record);
