I am developing a custom board application in Zephyr 3.2.99. I have a single PWM Channel running now but having trouble adding addtional channels.
In the 52811.dtsi, I have a single pwm node:
pwm0: pwm@4001c000 {
compatible = "nordic,nrf-pwm";
reg = <0x4001c000 0x1000>;
interrupts = <28 NRF_DEFAULT_IRQ_PRIORITY>;
status = "disabled";
#pwm-cells = <3>;
then, in my pinctrl-dtsi I have:
pwm0_default: pwm0_default {
// Channel 0
group1 {
psels = <NRF_PSEL(PWM_OUT0, 0, 23)>;
nordic,invert;
pwm0_sleep: pwm0_sleep {
group1 {
low-power-enable;
The in my .dts I have:
pwmleds {
compatible = "pwm-leds";
// pwm0 Ch 0
pwm_led0: pwm_led_0 {
pwms = <&pwm0 0 PWM_NSEC(62500) PWM_POLARITY_INVERTED>;
and:
&pwm0 {
status = "okay";
//status = "disabled";
pinctrl-0 = <&pwm0_default>;
pinctrl-1 = <&pwm0_sleep>;
in my main driver, I have followed the Zephyr example code:
static const struct pwm_dt_spec pwm_led0 = PWM_DT_SPEC_GET(DT_ALIAS(pwm_led0));
#define NUM_STEPS 1024U
#define SLEEP_MSEC 25U
uint32_t pulse_width = 0U;
uint32_t step = pwm_led0.period / NUM_STEPS;
//uint32_t step = pwm_led1.period / NUM_STEPS;
uint8_t dir = 1U;
int ret;
printk("PWM-based LED fade\n");
if (!device_is_ready(pwm_led0.dev)) {
printk("Error: PWM device %s is not ready\n",
pwm_led0.dev->name);
return;
while (1) {
ret = pwm_set_pulse_dt(&pwm_led0, pulse_width);
if (ret) {
printk("Error %d: failed to set pulse width\n", ret);
return;
if (dir) {
pulse_width += step;
if (pulse_width >= pwm_led0.period) {
pulse_width = pwm_led0.period - step;
dir = 0U;
} else {
if (pulse_width >= step) {
pulse_width -= step;
} else {
pulse_width = step;
dir = 1U;
k_sleep(K_MSEC(SLEEP_MSEC));
I have been stuck on this for a while and now I'm really in a bind.
Drew
