About an ASSERTION FAIL and ZEPHYR FATAL ERROR 4
Hi
Right now I'm using NCS2.0.0 & nRF52832 for development the mesh application.
Whenever My setting the "Light CTL Default Set"(in the file light_ctl_srv.c for function handle_default_set),it will ASSERTION.
After my tracking, I found that the problem is in the timer call from "light_ctl_srv.c" file.The calling sequence is as follows:
handle_default_set() of Line:268
default_set() of Line:232
lightness_srv_default_set() of Line:324
store_state() of Line:55
static void store_state(struct bt_mesh_lightness_srv *srv)
#if CONFIG_BT_SETTINGS
	k_work_schedule(
		&srv->store_timer,
		K_SECONDS(CONFIG_BT_MESH_MODEL_SRV_STORE_TIMEOUT));
In the function "store_state() " it will calling "k_work_schedule()".At this times, an assertion is triggered.And the k_work_schedule() return value 1.
finally in the work.c file of work_queue_main function "__ASSERT_NO_MSG(handler != NULL)" assertion.
The RTT LOG as follows:
D: Store: Last: 47607 Default: 45498 State: On Range: [656 - 65535]
ASSERTION FAIL @ WEST_TOPDIR/zephyr/kernel/work.c:648
E: r0/a1:  0x00000004  r1/a2:  0x00000288  r2/a3:  0x00000001
E: r3/a4:  0x2000a2f6 r12/ip:  0x00000000 r14/lr:  0x0003e0f5
E:  xpsr:  0x61000000
E: Faulting instruction address (r15/pc): 0x0004372c
E: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
E: Current thread: 0x20005a30 (sysworkq)
E: Resetting system
Why does calling the k_work_schedule here cause an assertion, but calling it elsewhere does not?
  • After I tested again, I found the assertion occurred when the k_work_schedule timed out.My test procedure is as follows:
    1.Remove the calling k_work_schedule code in the store_state() function of file light_temp_srv.c.
    static void store_state(struct bt_mesh_light_temp_srv *srv)
    // #if CONFIG_BT_SETTINGS
    // 	k_work_schedule(
    // 		&srv->store_timer,
    // 		K_SECONDS(CONFIG_BT_MESH_MODEL_SRV_STORE_TIMEOUT));
    // #endif
    When My setting the "Light CTL Default Set",the result is that no assertion occurs.
    2.Set the timeout to 10s,and remove the all code in the store_timeout() function of file light_temp_srv.c.
    static void store_timeout(struct k_work *work)
    	// struct k_work_delayable *dwork = k_work_delayable_from_work(work);
    	// struct bt_mesh_light_temp_srv *srv = CONTAINER_OF(
    	// 	dwork, struct bt_mesh_light_temp_srv, store_timer);
    	// struct settings_data data = {
    	// 	.dflt = srv->dflt,
    	// 	.range = srv->range,
    	// 	.last = srv->last,
    	// (void)bt_mesh_model_data_store(srv->model, false, NULL, &data,
    	// 			       sizeof(data));
    	k_work_schedule(
    		&srv->store_timer,
    		K_SECONDS(10));
    When My setting the "Light CTL Default Set",after 10 seconds the assertion occurs.
    One initial guess is that it might have something to do with the work queue stack size, i.e CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE. Could you try to increase this and see if this removes the error?
    If this does not work, can you supply a minimal sample that reproduces this error for me so I can investigate it closer? Please remember that you don't add any sensitive information in the sample.
    Let me know about these things and I'll do my best to see if I can help you solve this issue!
    Andreas
