How to stop advertising and go into a non-connectable state?
I want to stop advertising and be in a non-connectable state, if someone connected sends the wrong data through a characteristic three times in a row. I will start a timer, and after x amount of seconds, start advertising again for people to connect.
I've tried calling sd_ble_gap_disconnect() and sd_ble_gap_adv_stop(), but the device goes straight into advertising again. How can I stop this?
// Stop advertising
sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
NRF_LOG_INFO("Stopping advertising");
sd_ble_gap_adv_stop(m_advertising.adv_handle)
  • Hi Jerome,
    We would need to have a look on how you start advertising. Did you use ble_advertising module ? Or you use the sd_ble_gap_adv directly ?
    If you use ble_advertising, you can change ble_adv_on_disconnect_disabled configuration in init.config when you setting up advertising in advertising_init().
    If you use the softdevice API directly you need to check you code when you handle the BLE_GAP_EVT_DISCONNECTED event, usually in ble_evt_handler() . Most likely the start of new advertising after disconnected is located there.
    Calling sd_ble_gap_adv_stop() right after sd_ble_gap_disconnect() doesn't work because at that moment the link is not actually disconnected yet. Advertising will restarted when BLE_GAP_EVT_DISCONNECTED event is triggered.
