J-Link Base not showing anything and debug not working VS Code
I am currently developing a software for a custom board with nRF9160 chip.
The code is tested and works on nrf9160DK. The debugging works and the device is showing all information from logs.
The problem comes when I move to my custom board and I try to upload code from my J-Link Base.
There the code uploads but you cannot see any log information on the port of the J-Link.
Also when I try to debug the code I get the following message:
and I cannot seem to fix it.
For trying to see the log I go to NRF Terminal, select the COM port that the device is on and choose 115200 8n1.
Also tried with putty with 9600 but still the connection is established but nothing comes on the screen,
Any suggestions on why the J-Link is not functioning as intended?
  • I am not sure that the problem is this because I cannot connect to the VCOM of the j-link at all.
    A JLink Base does not have USB/UART bridge. It is a pure debugger and programmer.
    Håkon
  • I did that but I get the same error.
    The error tells me to open launch.json file but that is it.
    Here is my launch.js file I don't know what to look in it.
        // Use IntelliSense to learn about possible attributes.
        // Hover to view descriptions of existing attributes.
        // For more information, visit: https://go.microsoft.com/fwlink/?linkid=830387
        "version": "0.2.0",
        "configurations": [
                "name": "(gdb) Launch",
                "type": "cppdbg",
                "request": "launch",
                "program": "enter program name, for example ${workspaceFolder}/a.exe",
                "args": [],
                "stopAtEntry": false,
                "cwd": "${fileDirname}",
                "environment": [],
                "externalConsole": false,
                "MIMode": "gdb",
                "miDebuggerPath": "/path/to/gdb",
                "setupCommands": [
                        "description": "Enable pretty-printing for gdb",
                        "text": "-enable-pretty-printing",
                        "ignoreFailures": true
                "type": "nrf-connect",
                "name": "Launch build",
                "config": "${workspaceFolder}/build",
                "runToEntryPoint": "main"
  • Hi.
    The second part of your file is pointing to a workspace build folder.
    Can you share where you're entering debug mode from? Here's where I'm selecting my project and entering debug:
    Can you please press "CTRL + shift + p" and write "nrf connect generate support information" and run that? This should print out all your environment details in the "OUTPUT". Please copy this and share it.
    Håkon
  • I am entering debug mode the same way as you are.
    Here are the results from the support information:
    IMPORTANT: The data below could contain sensitive or confidential information about your environment.
    For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Pro",
        "osKernel": "10.0.19041",
        "vscode": "1.74.3",
        "electron": "19.1.8",
        "node": "v16.14.2"
      "system": {
        "date": "2023-01-17T07:28:30.519Z",
        "vscodeRoot": "c:\\Users\\SvetoslavAnev\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
        "vscodeUptime": "00:08:11",
        "osUptime": "00:18:44",
        "cpu": {
          "model": "Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz",
          "speed": "1992 MHz",
          "count": 4
        "memory": {
          "total": "15.88 GB",
          "free": "8.39 GB"
      "workspace": {
        "name": "Untitled (Workspace)",
        "workspaceFile": "1670502190484",
        "folders": [
          "c:\\Users\\SvetoslavAnev\\tests\\aws",
          "c:\\Users\\SvetoslavAnev\\tests\\at",
          "c:\\Users\\SvetoslavAnev\\tests\\at_monitor"
      "extensions": {
        "internal": {
            "version": "2022.11.140",
            "path": "c:\\Users\\SvetoslavAnev\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2022.11.140-win32-x64",
            "isActive": true
            "version": "2022.11.29",
            "path": "c:\\Users\\SvetoslavAnev\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2022.11.29",
            "isActive": true
            "version": "2022.11.153",
            "path": "c:\\Users\\SvetoslavAnev\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2022.11.153",
            "isActive": true
            "version": "2022.11.50",
            "path": "c:\\Users\\SvetoslavAnev\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2022.11.50",
            "isActive": true
        "external": {
          "marus25.cortex-debug": "1.6.9",
          "ms-vscode.cpptools": "1.14.0",
          "ms-vscode-remote.remote-wsl-recommender": "0.0.18",
          "ms-vscode.js-debug": "1.74.1",
          "ms-vscode.js-debug-companion": "1.0.18",
          "ms-vscode.vscode-js-profile-table": "1.0.3",
          "bibhasdn.git-easy": "1.11.0",
          "cschlosser.doxdocgen": "1.4.0",
          "eamodio.gitlens": "13.2.0",
          "GitHub.vscode-pull-request-github": "0.56.0",
          "jeff-hykin.better-cpp-syntax": "1.17.2",
          "mcu-debug.debug-tracker-vscode": "0.0.13",
          "mcu-debug.memory-view": "0.0.18",
          "mcu-debug.rtos-views": "0.0.3",
          "ms-python.isort": "2022.8.0",
          "ms-python.python": "2022.20.2",
          "ms-python.vscode-pylance": "2023.1.20",
          "ms-toolsai.jupyter": "2022.11.1003412109",
          "ms-toolsai.jupyter-keymap": "1.0.0",
          "ms-toolsai.jupyter-renderers": "1.0.12",
          "ms-toolsai.vscode-jupyter-cell-tags": "0.1.6",
          "ms-toolsai.vscode-jupyter-slideshow": "0.1.5",
          "ms-vscode-remote.remote-containers": "0.266.1",
          "ms-vscode-remote.remote-ssh": "0.94.0",
          "ms-vscode-remote.remote-ssh-edit": "0.84.0",
          "ms-vscode-remote.remote-wsl": "0.72.0",
          "ms-vscode.cmake-tools": "1.12.27",
          "ms-vscode.remote-explorer": "0.0.3",
          "ms-vsliveshare.vsliveshare": "1.0.5803",
          "ms-vsliveshare.vsliveshare-audio": "0.1.91",
          "redjue.git-commit-plugin": "1.1.2",
          "twxs.cmake": "0.0.17"
      "tools": {
        "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin\\arm-none-eabi-gcc.exe": "9.2.1",
        "C:\\Program Files (x86)\\SEGGER\\JLink\\JLink.exe": "7.80c",
        "C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.18.1",
        "nrfutil": "Not found",
        "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin\\cmake.exe": "3.20.5",
        "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin\\Scripts\\west.exe": "0.11.1",
        "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin\\python.exe": "3.8.2",
        "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin\\ninja.exe": "1.9.0",
        "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin\\gperf.exe": "3.1",
        "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin\\dtc.exe": "1.4.7",
        "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin\\gn.exe": "1937",
        "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\mingw64\\bin\\git.exe": "2.26.2.windows.1",
        "gdbPath": "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin\\arm-none-eabi-gdb.exe"
      "sdks": [
          "version": "1.7.0",
          "path": "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0"
      "toolchains": [
          "version": "1.7.0",
          "path": "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain"
      "connectedDevices": [
          "serialNumber": "51011598"
          "serialNumber": "960072282"
      "deviceProviders": [
        "nrfjprog"
      "config": {
          "topdir": "${nrf-connect.sdk:1.7.0}",
          "toolchain": {
            "path": "${nrf-connect.toolchain:1.7.0}"
          "ozonePath": "",
          "applications": [
            "${workspaceFolder}",
            "c:\\Users\\SvetoslavAnev\\tests\\at_monitor",
          "applicationOptions": {},
          "kconfig": {
            "interface": "kconfig",
            "executeInDefaultShell": false
          "welcome": {
            "showOnStartup": true
          "west": {
            "env": {
              "$base": "terminal"
          "boardRoots": [],
          "enableTelemetry": false,
          "taskBindings": {},
          "debugging": {
            "backend": "nRF Debug",
            "flash": true,
            "bindings": {
              "${workspaceFolder}/build": "Launch build"
          "activeAppFollowActiveEditor": true
          "terminalMode": "character",
          "scrollBack": 1000
        "marus25.cortex-debug": {
          "armToolchainPath": null,
          "armToolchainPrefix": "arm-none-eabi",
          "gdbPath": null,
          "objdumpPath": null,
          "JLinkGDBServerPath": null,
          "openocdPath": null,
          "pyocdPath": null,
          "PEGDBServerPath": null,
          "stutilPath": null,
          "stlinkPath": null,
          "stm32cubeprogrammer": null,
          "enableTelemetry": true,
          "registerUseNaturalFormat": true,
          "variableUseNaturalFormat": true,
          "dbgServerLogfile": null,
          "showDevDebugOutput": "none"
      "environment": {
        "westExe": "west",
        "westEnv": {
          "ELECTRON_RUN_AS_NODE": "1",
          "HOME": "C:\\Users\\SvetoslavAnev",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\SvetoslavAnev",
          "Path": "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\mingw64\\bin;c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\mingw64\\libexec\\git-core;c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin;c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin\\Scripts;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\PuTTY\\;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\SvetoslavAnev\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\SvetoslavAnev\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Python27\\",
          "ZEPHYR_BASE": "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\zephyr",
          "GNUARMEMB_TOOLCHAIN_PATH": "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt",
          "ZEPHYR_TOOLCHAIN_VARIANT": "gnuarmemb",
          "PYTHONPATH": "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin;c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin\\Lib;c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin\\Lib\\site-packages",
          "Python3_ROOT": "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin"
        "inherited": {
          "HOMEDRIVE": "C:",
          "Path": "C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\PuTTY\\;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\SvetoslavAnev\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\SvetoslavAnev\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Python27\\",
          "PATH": "C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\PuTTY\\;C:\\ProgramData\\chocolatey\\bin;C:\\Program Files\\CMake\\bin;C:\\Program Files\\Git\\cmd;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin\\;C:\\Program Files\\IVI Foundation\\VISA\\Win64\\Bin\\;C:\\Program Files (x86)\\IVI Foundation\\VISA\\WinNT\\Bin;C:\\Program Files (x86)\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Users\\SvetoslavAnev\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\SvetoslavAnev\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Python27\\"
        "toolchainPath": "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain",
        "toolchainBinPath": "c:\\Users\\SvetoslavAnev\\ncs\\v1.7.0\\toolchain\\opt\\bin",
        "toolchainVersion": "1.7.0"
      "terminal": {
        "shell": null,
        "defaultProfile": null
