HI,
I build project direct_test_mode and empty_app_core and connect to PC softwarre DTM v2.
If build from ncs v1.9.1, it connect ok to show standby. but if build from ncs v2.2.0, DTM show NG.
Can you help me to verify it? something wrong?
HI,
I build DTM with ncs v1.9.1, and I only see P0.25 pin has a pulse, P0.26 is always low. Is it correct?
If it is wrong, how to fix?
DTM v2 setting:
UART monitor:
Q1: Does it behave like this in ncs v2.2.0 at your end as well?
You can disable the remote_shell, and use empty_app_core (as previous) by setting this:
CONFIG_NCS_SAMPLE_REMOTE_SHELL_CHILD_IMAGE=n
Q2: Also, if you try to switch the GPIOs, dtm_antenna_1_pin =26 and _2_pin=25, does the issue follow the GPIO?
Håkon
Can you show me how to modify overlay file to use P0.25, P0.26?
It use the different format than ncs v1.9.1, and I will try it in the office tomorrow. Thanks!
I follow your suggestion to build DTM in ncs v2.2.0, but test fail in our HW.
Our HW structure is as following,
nRF5340 UART (P1.00, P1.01) connect to another MCU (as UART transparent role),
can I use ncs v2.2.0 DTM? or I just can use ncs v1.9.1 DTM?
You said "As a workaround, can you try to select the application core COM-port?" before.
My apologies, but there are more steps that needs to be included for DTM in ncs v2.2.0 to behave similar to previous SDK versions.
Håkon Alseth said:You can disable the remote_shell, and use empty_app_core (as previous) by setting this
You will need to change this section:
to:
&uart0 { status = "okay"; compatible = "nordic,nrf-uarte"; current-speed = <19200>; };
And also change the board .conf file:
To only include this line:
Unfortunately, this does not automatically include the empty_app_core project, so that must also manually be flashed first.
Felix Shih said:nRF5340 UART (P1.00, P1.01) connect to another MCU (as UART transparent role),
As long as your external mcu forwards byte for byte, that should in theory work. One thing that will be different is the timing of the bus communication in your scenario.
Håkon
