DTM (direct test mode) connect fail in ncs v2.2.0
HI,
I build project direct_test_mode and empty_app_core and connect to PC softwarre DTM v2.
If build from ncs v1.9.1, it connect ok to show standby. but if build from ncs v2.2.0, DTM show NG.
Can you help me to verify it? something wrong?
    I follow your steps to build DTM in ncs v2.2.0, it seems to work. DTM v2 can connect to nRF5340 and show "STAND BY" now.
    I also got the following problem message in VS code, is it ok?
    \projects\direct_test_mode\src/fem/Kconfig:49: error: couldn't parse 'depends on $(dt_nodelabel_has_prop,nrf_radio_fem,chl-gpios)': macro expanded to blank string
    This indicates that you're adding a frontend module (like nRF21540 or a generic 2-wire PA/LNA setup). Can you share the board that you're using (ie. nrf5340dk_nrf5340_cpunet for instance) and any additional .overlay files that you're including in your build?
    Håkon
    I may made mistake in the previous build process, and I rebuild the direct_test_mode project and the problem message disappeared now.
    I got the antenna pins waveform as the following, but it seems strange, P0.26 keep low.
    My overlay file is:
    	chosen {
    		ncs,dtm-uart = &uart0;
    &uart0 {
    	status = "okay";
    	compatible = "nordic,nrf-ipc-uart";
    	ipc = <&ipc0>;
    	ept-name = "remote shell";
    	current-speed = <19200>;
    &uart0 {
    	status = "okay";
    	current-speed = < 115200 >;
    &radio {
    	status = "okay";
    	/* This is a number of antennas that are available on antenna matrix
    	 * designed by Nordic. For more information see README.rst.
    	/* dfe-antenna-num = <12>; */
    	dfe-antenna-num = <4>;
    	/* This is a setting that enables antenna 12 (in antenna matrix designed
    	 * by Nordic) for PDU. For more information see README.rst.
    	dfe-pdu-antenna = <0x0>;
    	/* These are GPIO pin numbers that are provided to
    	 * Radio peripheral. The pins will be acquired by Radio to
    	 * drive antenna switching.
    	 * Pin numbers are selected to drive switches on antenna matrix
    	 * desinged by Nordic. For more information see README.rst.
    	dfegpio0-gpios = <&gpio0 4 0>;
    	dfegpio1-gpios = <&gpio0 5 0>;
    	dfegpio2-gpios = <&gpio0 6 0>;
    	dfegpio3-gpios = <&gpio0 7 0>;
    	dfegpio0-gpios = <&gpio0 25 0>;
    	dfegpio1-gpios = <&gpio0 26 0>;
    My conf file is:
    # Copyright (c) 2021 Nordic Semiconductor
    #CONFIG_IPC_UART=y
    #CONFIG_IPC_SERVICE=y
    #CONFIG_IPC_SERVICE_BACKEND_RPMSG=y
    #CONFIG_MBOX=y
    #CONFIG_NRFX_DPPI=y
    #CONFIG_HEAP_MEM_POOL_SIZE=4096
    # Build Remote shell APP Core sample for the application core
    CONFIG_NCS_SAMPLE_REMOTE_SHELL_CHILD_IMAGE=n
    CONFIG_LOG=y
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_LOG_BACKEND_RTT=y
    DTM v2 settings:
    I used the exact same settings as you, which corresponds with the dfegpio0 and dfegpio1 setting in the overlay file, and got this output on P0.25 and P0.26:
    Also tested other GPIOs, and they also worked as expected. Could you try to do the same?
    I cannot see if the type that you've selected is "1 us" or "2 us" in the CTE Info -> "Type", but I used 1 us there.
    Håkon
    My test as follow:
    1)
    use 1us, P0.25, P0.26 change
    use 2us, P0.26 keeps low
    2) In 1us condition, it repeats (high, low) -> (low, high) -> (low, low) pattern, it lacks (high, high) combination, the waveform is correct?
