Hi:
NCS use v2.2.0.
Build Config:
Borad: PCA10090
Runing UDP example:
I can run other examples with LOG output.
Hi:
NCS use v2.2.0.
Build Config:
Borad: PCA10090
Runing UDP example:
Hi John,
As opposed to many other samples, the nRF9160 UDP sample has CONFIG_SERIAL disabled by default to demonstrate low power usage, as stated here. So just to make sure, could you make sure that CONFIG_SERIAL is set to y in your proj.conf?
I see that a warning about CONFIG_SERIAL is generated when building this sample, but since building still completes, it's easy to miss.
Raoul
