LWM2M Client - XRAI
Good day
I an in the process of reducing power consumption with my edited LWM2M sample.  I am able to use XRAI commands successfully when doing using a a callback function but I'm having trouble applying this same logic to when a registration update occurs.  When using the same command I can't seem to get the device to enter edrx mode.  Any suggestions? I am using NB-iot.
kind regards,
Hassan.
  • Not sure, what you exactly do. There are two variants of RAI, using "AT%XRAI" is one, and it enables that feature for all future traffic. You may use it for an message exchange (request/response) or "one way message" (request with "no response option" or "non response/notify"). Once a mode is enabled, the future traffic will use that function. So while you device sends NON notifications, you may start that period with "AT%XRAI=4" (no response) and when the device checks the interest with a CON notification, you may switch to "AT%XRAI=3" (one response).
    if you sent a "registration update", you usually get at least one response, so that should also be "AT%XRAI=3" (one response). If you expect the LwM2M server to send further request to the device, you may even switch to "AT%XRAI=0" (disable RAI). I'm not that common with eDRX, so it may be also possible, that "AT%XRAI=3" is used and rare additional server request are then handled on the next eDRX receive/wakeup.
    According some other issues here in the forum, there seems to be no "hard relation", when a changed RAI mode is applied. So this changes may result in unexpected behavior, just test it "good enough".
    (There is also an alternative RAI mode, which requires support by the network operator, "AT%RAI". with that, the RAI mode is controlled by socket options. Maybe that relates such mode-switching more reliable with the messages.)
  • Let me add: using DTLS 1.2 then raise the question, if you need frequently DTLS handshakes. If so, you need also to consider that with "AT%XRAI=0" during the handshake.
  • Hello Hassan,
    Also thank you for the help Achim.
    Should I still look into it, or have you gotten the answer you were looking for?
    Michal
  • Hi Achim
    I tried all that you suggested thank you very much! unfortunately, still no luck.  I am attempting to contact my provider to find out whether the "AT%RAI" command will be able any time.
    KInd regards,
    Hassan
  • Hi Michal
    I have furthered by questions toward my provider and i'm hoping to hear back soon.  Thank you !
    Hassan
