Multi-Image DFU project structure
I am working on a project with the nrf5340, on ncs version 2.1.2, though I plan to bring it into v2.2.0.
I have been working on this sample on the side because Multi-Image DFU is a must for my application. While there are issues unresolved on the thread, (about iOS being faulty when running DFU more than once), it is the only sample that has uploaded 2 images through BLE and successfully updated the device. However, I have run into some complications in implementing this code into my firmware.
The sample structure is very simple:
Fullscreen
1
2
3
4
5
6
7
8
9
10
mcu_smp_ble_simultaneous:
- child_image
-mcuboot.conf
- src
- main.c
- bluetooth_smp.c
- bluetooth_smp.h
app.overlay
CMakeLists.txt
prj.conf
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
My project is more involved. I am struggling to figure out where the mcuboot.conf will be added, and how to add its configurations for the mcuboot bootloader. I have several questions that I have been trying to research, so I am reaching out for help here while I continue to try.
When building my project with the following CMakeLists.txt, I can see in the build output that it seems to build my child image and mcuboot configurations, but how can I be sure?
When the build is complete, the dfu_application.zip contains the following even though the mcuboot.conf states "UPDATEABLE_IMAGE=2"
How would I get the cpu_net image into this dfu_application.zip? Am I on the right track?
Here is my project structure:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
project_folder
- cpu_app
- inc
- *.h files
- src
-*.c files (including main.c)
- CMakeLists.txt
- cpu_net
- inc
- *.h files
- src
- CMakeLists.txt
- nrf5340dk_nrf5340_cpu_net.overlay
- prj.conf
- CMakeLists.txt
- nrf5340dk_nrf5340_cpuapp.overlay
- KConfig
- prj.conf
My project_folder/CMakeLists.txt looks like:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
# Copyright (c) 2020 Nordic Semiconductor
cmake_minimum_required(VERSION 3.20.0)
set(ZEPHYR_EXTRA_MODULES ${CMAKE_CURRENT_LIST_DIR})
find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE})
project(app)
# NORDIC SDK APP START
FILE(GLOB app_sources cpu_app/src/*.c)
target_sources(app PRIVATE ${app_sources})
target_include_directories(app PRIVATE cpu_app/inc)
# NORDIC SDK APP END
zephyr_library_include_directories(.)
My project_folder/cpu_app/CMakeLists.txt looks like:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
# This check is needed to avoid infinite recursion. This module code will
# be executed for all images in the build, also for the child image being
# added below.
if (CONFIG_INCLUDE_NET_CORE_IMAGE)
add_child_image(
NAME cpu_net
SOURCE_DIR ${CMAKE_CURRENT_LIST_DIR}/../cpu_net
DOMAIN cpunet
BOARD ${CONFIG_DOMAIN_CPUNET_BOARD}
# Add this just below the line "cmake_minimum_required(...)" !!
if (EXISTS "${CMAKE_CURRENT_SOURCE_DIR}/../mcuboot.conf")
list(APPEND mcuboot_OVERLAY_CONFIG
"${CMAKE_CURRENT_SOURCE_DIR}/mcuboot.conf"
endif()
endif()
My project_folder/cpu_net/CMakeLists.txt looks like:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
project(cpu_net)
FILE(GLOB app_sources src/*.c)
target_include_directories(app PRIVATE inc)
if (CONFIG_SOC_NRF5340_CPUAPP)
message(FATAL_ERROR "This sample is not supported on the nRF53 application core")
endif()
  • I just entered a new ticket here:  Encrypted DFU nrf5340 in NCS with case ID 301424.
    Back on the same topic of FOTA DFU for both the network and application core:
    I am able to send over a DFU binary, and update the application core via BLE FOTA for my custom project that contains source code for both the application and network core. However, this of course does not update the network core.
    Is it possible to generate and send over the binary package required to update just the network core? Essentially, my customer would be satisfied with performing a DFU of the network core and application core separately with two different binaries instead of simultaneously.
  • Could I get an update on this?
  • Hi, sorry for not getting back to you earlier
    It is possible to send over the binary for each core separately, app_update.bin for the application core and net_core_app_update.bin for the network core.
    However, this still requires an MCUboot build that supports updating both cores, which is the core issue. As I said earlier, the issue is in the build system, not in MCUboot's capabilities.
    You mentioned earlier that you could perhaps modify hci_rpmsg to fit your needs, and if that is sufficient then you should not encounter any issues with simultaneous or non-simultaneous updates of the cores.
  • Robert, If you haven't already seen this link, perhaps this could be useful to you.
1 2
