How to disable TFM_CRYPTO_AEAD_MODULE_ENABLED
Due to the flash size limitation, we want to reduce the code size of TF-M. After I set CONFIG_TFM_CRYPTO_AEAD_MODULE_ENABLED=n in SDK v2.2.0, the size of TF-M code can be reduced by about 32KB, but the program does not run into the main of the app, but into tfm_hal_system_halt.
How to turn off TFM_CRYPTO_AEAD_MODULE_ENABLED?
Or how to configure TF-M to reduce code size?
Also, we need to set CONFIG_TFM_PROFILE_TYPE_NOT_SET=y instead of using TF-M mini mode.
