I am using NCS 2.2.0, nRF5340.
A few days ago, i add NSIB to my project, but i can't upgrade MCUboot. I find some puzzled quetionns after reading the MCUboot code.
In loader.c, path ${NCS_ROOT}/bootloader/mcuboot/boot/bootutil/src/loader.c
static int
boot_validated_swap_type(struct boot_loader_state *state,
struct boot_status *bs)
int swap_type;
fih_int fih_rc = FIH_FAILURE;
bool upgrade_valid = false;
#if defined(PM_S1_ADDRESS) || defined(CONFIG_SOC_NRF5340_CPUAPP)
const struct flash_area *secondary_fa =
BOOT_IMG_AREA(state, BOOT_SECONDARY_SLOT);
struct image_header *hdr = (struct image_header *)secondary_fa->fa_off;
uint32_t vtable_addr = 0;
uint32_t *vtable = 0;
uint32_t reset_addr = 0;
/* Patch needed for NCS. Since image 0 (the app) and image 1 (the other
* B1 slot S0 or S1) share the same secondary slot, we need to check
* whether the update candidate in the secondary slot is intended for
* image 0 or image 1 primary by looking at the address of the reset
* vector. Note that there are good reasons for not using img_num from
* the swap info.
if (hdr->ih_magic == IMAGE_MAGIC) {
vtable_addr = (uint32_t)hdr + hdr->ih_hdr_size;
vtable = (uint32_t *)(vtable_addr);
reset_addr = vtable[1];
#ifdef PM_S1_ADDRESS
#ifdef PM_CPUNET_B0N_ADDRESS
if(reset_addr < PM_CPUNET_B0N_ADDRESS)
It is ok when using internal flash but ext flash.
When i using ext flash, the image header should read from ext flash not 'secondary_fa->fa_off'.
At this point, it will generate erasing the secondary when upgrading target is not the first item later.
if (reset_value < min_addr || reset_value> (max_addr)) {
BOOT_LOG_ERR("Reset address of image in secondary slot is not in the primary slot");
BOOT_LOG_ERR("Erasing image from secondary slot");
/* The vector table in the image located in the secondary
* slot does not target the primary slot. This might
* indicate that the image was loaded to the wrong slot.
* Erase the image and continue booting from the primary slot.
flash_area_erase(fap, 0, fap->fa_size);
fih_rc = fih_int_encode(1);
goto out;
Is this question is true?
Yang Hu
