I have a legacy code base for NRF9160 with a custom board folder which created manually by applying installing manually steps in the past. I have neither experience with Nordic ecosystem nor Zephyr before.
Codebase is building successfully however it falls hard fault whenever I attempted to run zephyr.elf file via OZONE.
Ozone says there is PRECISERR and BFAR = 0x4000 9500.
Software are using uarte and this adress could be related with this. On the other hand, an instruction on my hand says " before the build, you should copy custom uarte.c driver to zephyr/driver/serial/uarte" I do not know why.
Here is the code snippet.
As far as I reviewed. This address is belongs to the uarte enable register. The project are using uart0 and uart1. I do not know which prj.conf I need to share with you please navigate me.
* Copyright (c) 2018 Nordic Semiconductor ASA
* @brief Driver for Nordic Semiconductor nRF UARTE
#include <drivers/uart.h>
#include <hal/nrf_gpio.h>
#include <hal/nrf_uarte.h>
#include <nrfx_timer.h>
#include <sys/util.h>
#include <kernel.h>
#include <logging/log.h>
#include <helpers/nrfx_gppi.h>
LOG_MODULE_REGISTER(uart_nrfx_uarte, LOG_LEVEL_ERR);
/* Generalize PPI or DPPI channel management */
#if defined(CONFIG_HAS_HW_NRF_PPI)
#include <nrfx_ppi.h>
#define gppi_channel_t nrf_ppi_channel_t
#define gppi_channel_alloc nrfx_ppi_channel_alloc
#define gppi_channel_enable nrfx_ppi_channel_enable
#elif defined(CONFIG_HAS_HW_NRF_DPPIC)
#include <nrfx_dppi.h>
#define gppi_channel_t uint8_t
#define gppi_channel_alloc nrfx_dppi_channel_alloc
#define gppi_channel_enable nrfx_dppi_channel_enable
#else
#error "No PPI or DPPI"
#if (defined(CONFIG_UART_0_NRF_UARTE) && \
defined(CONFIG_UART_0_INTERRUPT_DRIVEN)) || \
(defined(CONFIG_UART_1_NRF_UARTE) && \
defined(CONFIG_UART_1_INTERRUPT_DRIVEN)) || \
(defined(CONFIG_UART_2_NRF_UARTE) && \
defined(CONFIG_UART_2_INTERRUPT_DRIVEN)) || \
(defined(CONFIG_UART_3_NRF_UARTE) && \
defined(CONFIG_UART_3_INTERRUPT_DRIVEN))
#define UARTE_INTERRUPT_DRIVEN 1
#if (defined(CONFIG_UART_0_NRF_UARTE) && !defined(CONFIG_UART_0_ASYNC)) || \
(defined(CONFIG_UART_1_NRF_UARTE) && !defined(CONFIG_UART_1_ASYNC)) || \
(defined(CONFIG_UART_2_NRF_UARTE) && !defined(CONFIG_UART_2_ASYNC)) || \
(defined(CONFIG_UART_3_NRF_UARTE) && !defined(CONFIG_UART_3_ASYNC))
#define UARTE_ANY_NONE_ASYNC 1
uint32_t uarte_prev_rx_amount;
uint8_t uarte_prev_dirty;
uint8_t po_flush_buf[5];
* RX timeout is divided into time slabs, this define tells how many divisions
* should be made. More divisions - higher timeout accuracy and processor usage.
#define RX_TIMEOUT_DIV 5
#ifdef CONFIG_UART_ASYNC_API
struct uarte_async_cb {
uart_callback_t user_callback;
void *user_data;
const uint8_t *tx_buf;
volatile size_t tx_size;
uint8_t *pend_tx_buf;
struct k_timer tx_timeout_timer;
uint8_t *rx_buf;
size_t rx_buf_len;
size_t rx_offset;
uint8_t *rx_next_buf;
size_t rx_next_buf_len;
uint32_t rx_total_byte_cnt; /* Total number of bytes received */
uint32_t rx_total_user_byte_cnt; /* Total number of bytes passed to user */
int32_t rx_timeout; /* Timeout set by user */
int32_t rx_timeout_slab; /* rx_timeout divided by RX_TIMEOUT_DIV */
int32_t rx_timeout_left; /* Current time left until user callback */
struct k_timer rx_timeout_timer;
union {
gppi_channel_t ppi;
uint32_t cnt;
} rx_cnt;
volatile int tx_amount;
bool rx_enabled;
bool hw_rx_counting;
/* Flag to ensure that RX timeout won't be executed during ENDRX ISR */
volatile bool is_in_irq;
#ifdef UARTE_INTERRUPT_DRIVEN
struct uarte_nrfx_int_driven {
uart_irq_callback_user_data_t cb; /**< Callback function pointer */
void *cb_data; /**< Callback function arg */
uint8_t *tx_buffer;
uint16_t tx_buff_size;
volatile bool disable_tx_irq;
#ifdef CONFIG_PM_DEVICE
bool rx_irq_enabled;
atomic_t fifo_fill_lock;
/* Device data structure */
struct uarte_nrfx_data {
const struct device *dev;
struct uart_config uart_config;
struct uarte_nrfx_int_driven *int_driven;
struct uarte_async_cb *async;
atomic_val_t poll_out_lock;
uint32_t pm_state;
uint8_t char_out;
uint8_t rx_data;
gppi_channel_t ppi_ch_endtx;
#define CTS_PIN_SET_MASK BIT(1)
#define RTS_PIN_SET_MASK BIT(2)
#define IS_CTS_PIN_SET(mask) (mask & CTS_PIN_SET_MASK)
#define IS_RTS_PIN_SET(mask) (mask & RTS_PIN_SET_MASK)
* @brief Structure for UARTE configuration.
struct uarte_nrfx_config {
NRF_UARTE_Type *uarte_regs; /* Instance address */
uint8_t rts_cts_pins_set;
bool gpio_mgmt;
bool ppi_endtx;
nrfx_timer_t timer;
struct uarte_init_config {
uint32_t pseltxd; /* PSEL.TXD register value */
uint32_t pselrxd; /* PSEL.RXD register value */
uint32_t pselcts; /* PSEL.CTS register value */
uint32_t pselrts; /* PSEL.RTS register value */
static inline struct uarte_nrfx_data *get_dev_data(const struct device *dev)
return dev->data;
static inline const struct uarte_nrfx_config *get_dev_config(const struct device *dev)
return dev->config;
static inline NRF_UARTE_Type *get_uarte_instance(const struct device *dev)
const struct uarte_nrfx_config *config = get_dev_config(dev);
return config->uarte_regs;
static void endtx_isr(const struct device *dev)
NRF_UARTE_Type *uarte = get_uarte_instance(dev);
int key = irq_lock();
if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDTX)) {
nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_ENDTX);
nrf_uarte_task_trigger(uarte, NRF_UARTE_TASK_STOPTX);
irq_unlock(key);
#ifdef UARTE_ANY_NONE_ASYNC
* @brief Interrupt service routine.
* This simply calls the callback function, if one exists.
* @param arg Argument to ISR.
* @return N/A
static void uarte_nrfx_isr_int(void *arg)
const struct device *dev = arg;
/* If interrupt driven and asynchronous APIs are disabled then UART
* interrupt is still called to stop TX. Unless it is done using PPI.
if (nrf_uarte_int_enable_check(uarte, NRF_UARTE_INT_ENDTX_MASK) &&
endtx_isr(dev);
struct uarte_nrfx_data *data = get_dev_data(dev);
if (!data->int_driven) {
return;
if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_TXSTOPPED)) {
data->int_driven->fifo_fill_lock = 0;
if (data->int_driven->disable_tx_irq) {
nrf_uarte_int_disable(uarte,
NRF_UARTE_INT_TXSTOPPED_MASK);
data->int_driven->disable_tx_irq = false;
return;
if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ERROR)) {
nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_ERROR);
if (data->int_driven->cb) {
data->int_driven->cb(dev, data->int_driven->cb_data);
#endif /* UARTE_INTERRUPT_DRIVEN */
#endif /* UARTE_ANY_NONE_ASYNC */
* @brief Set the baud rate
* This routine set the given baud rate for the UARTE.
* @param dev UARTE device struct
* @param baudrate Baud rate
* @return 0 on success or error code
static int baudrate_set(const struct device *dev, uint32_t baudrate)
nrf_uarte_baudrate_t nrf_baudrate; /* calculated baudrate divisor */
switch (baudrate) {
case 300:
/* value not supported by Nordic HAL */
nrf_baudrate = 0x00014000;
case 600:
nrf_baudrate = 0x00027000;
case 1200:
nrf_baudrate = NRF_UARTE_BAUDRATE_1200;
case 2400:
nrf_baudrate = NRF_UARTE_BAUDRATE_2400;
case 4800:
nrf_baudrate = NRF_UARTE_BAUDRATE_4800;
case 9600:
nrf_baudrate = NRF_UARTE_BAUDRATE_9600;
case 14400:
nrf_baudrate = NRF_UARTE_BAUDRATE_14400;
case 19200:
nrf_baudrate = NRF_UARTE_BAUDRATE_19200;
case 28800:
nrf_baudrate = NRF_UARTE_BAUDRATE_28800;
case 31250:
nrf_baudrate = NRF_UARTE_BAUDRATE_31250;
case 38400:
nrf_baudrate = NRF_UARTE_BAUDRATE_38400;
case 56000:
nrf_baudrate = NRF_UARTE_BAUDRATE_56000;
case 57600:
nrf_baudrate = NRF_UARTE_BAUDRATE_57600;
case 76800:
nrf_baudrate = NRF_UARTE_BAUDRATE_76800;
case 115200:
nrf_baudrate = NRF_UARTE_BAUDRATE_115200;
case 230400:
nrf_baudrate = NRF_UARTE_BAUDRATE_230400;
case 250000:
nrf_baudrate = NRF_UARTE_BAUDRATE_250000;
case 460800:
nrf_baudrate = NRF_UARTE_BAUDRATE_460800;
case 921600:
nrf_baudrate = NRF_UARTE_BAUDRATE_921600;
case 1000000:
nrf_baudrate = NRF_UARTE_BAUDRATE_1000000;
return -EINVAL;
nrf_uarte_baudrate_set(uarte, nrf_baudrate);
return 0;
static int uarte_nrfx_configure(const struct device *dev,
const struct uart_config *cfg)
nrf_uarte_config_t uarte_cfg;
#if defined(UARTE_CONFIG_STOP_Msk)
switch (cfg->stop_bits) {
case UART_CFG_STOP_BITS_1:
uarte_cfg.stop = NRF_UARTE_STOP_ONE;
case UART_CFG_STOP_BITS_2:
uarte_cfg.stop = NRF_UARTE_STOP_TWO;
return -ENOTSUP;
#else
if (cfg->stop_bits != UART_CFG_STOP_BITS_1) {
return -ENOTSUP;
if (cfg->data_bits != UART_CFG_DATA_BITS_8) {
return -ENOTSUP;
switch (cfg->flow_ctrl) {
case UART_CFG_FLOW_CTRL_NONE:
uarte_cfg.hwfc = NRF_UARTE_HWFC_DISABLED;
case UART_CFG_FLOW_CTRL_RTS_CTS:
if (get_dev_config(dev)->rts_cts_pins_set) {
uarte_cfg.hwfc = NRF_UARTE_HWFC_ENABLED;
} else {
return -ENOTSUP;
return -ENOTSUP;
#if defined(UARTE_CONFIG_PARITYTYPE_Msk)
uarte_cfg.paritytype = NRF_UARTE_PARITYTYPE_EVEN;
switch (cfg->parity) {
case UART_CFG_PARITY_NONE:
uarte_cfg.parity = NRF_UARTE_PARITY_EXCLUDED;
case UART_CFG_PARITY_EVEN:
uarte_cfg.parity = NRF_UARTE_PARITY_INCLUDED;
case UART_CFG_PARITY_ODD:
uarte_cfg.paritytype = NRF_UARTE_PARITYTYPE_ODD;
return -ENOTSUP;
if (baudrate_set(dev, cfg->baudrate) != 0) {
return -ENOTSUP;
nrf_uarte_configure(get_uarte_instance(dev), &uarte_cfg);
get_dev_data(dev)->uart_config = *cfg;
return 0;
static int uarte_nrfx_config_get(const struct device *dev,
*cfg = get_dev_data(dev)->uart_config;
return 0;
static int uarte_nrfx_err_check(const struct device *dev)
/* register bitfields maps to the defines in uart.h */
return nrf_uarte_errorsrc_get_and_clear(uarte);
/* Function returns true if new transfer can be started. Since TXSTOPPED
* (and ENDTX) is cleared before triggering new transfer, TX is ready for new
* transfer if any event is set.
static bool is_tx_ready(const struct device *dev)
bool ppi_endtx = get_dev_config(dev)->ppi_endtx;
return nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_TXSTOPPED) ||
(!ppi_endtx ?
nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDTX) : 0);
/* Wait until the transmitter is in the idle state. When this function returns,
* IRQ's are locked with the returned key.
static int wait_tx_ready(const struct device *dev)
int key;
do {
/* wait arbitrary time before back off. */
bool res;
NRFX_WAIT_FOR(is_tx_ready(dev), 100, 1, res);
if (res) {
key = irq_lock();
if (is_tx_ready(dev)) {
irq_unlock(key);
k_msleep(1);
} while (1);
return key;
static void tx_start(NRF_UARTE_Type *uarte, const uint8_t *buf, size_t len)
nrf_uarte_tx_buffer_set(uarte, buf, len);
nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_TXSTOPPED);
nrf_uarte_task_trigger(uarte, NRF_UARTE_TASK_STARTTX);
static inline bool hw_rx_counting_enabled(struct uarte_nrfx_data *data)
if (IS_ENABLED(CONFIG_UARTE_NRF_HW_ASYNC)) {
return data->async->hw_rx_counting;
} else {
return false;
static void timer_handler(nrf_timer_event_t event_type, void *p_context) { }
static void rx_timeout(struct k_timer *timer);
static void tx_timeout(struct k_timer *timer);
static int uarte_nrfx_rx_counting_init(const struct device *dev)
const struct uarte_nrfx_config *cfg = get_dev_config(dev);
int ret;
if (hw_rx_counting_enabled(data)) {
nrfx_timer_config_t tmr_config = NRFX_TIMER_DEFAULT_CONFIG;
tmr_config.mode = NRF_TIMER_MODE_COUNTER;
tmr_config.bit_width = NRF_TIMER_BIT_WIDTH_32;
ret = nrfx_timer_init(&cfg->timer,
&tmr_config,
timer_handler);
if (ret != NRFX_SUCCESS) {
LOG_ERR("Timer already initialized, "
"switching to software byte counting.");
data->async->hw_rx_counting = false;
} else {
nrfx_timer_enable(&cfg->timer);
nrfx_timer_clear(&cfg->timer);
ret = gppi_channel_alloc(&data->async->rx_cnt.ppi);
LOG_ERR("Failed to allocate PPI Channel, "
nrfx_timer_uninit(&cfg->timer);
#if CONFIG_HAS_HW_NRF_PPI
ret = nrfx_ppi_channel_assign(
data->async->rx_cnt.ppi,
nrf_uarte_event_address_get(uarte,
NRF_UARTE_EVENT_RXDRDY),
nrfx_timer_task_address_get(&cfg->timer,
NRF_TIMER_TASK_COUNT));
return -EIO;
#else
nrf_uarte_publish_set(uarte,
NRF_UARTE_EVENT_RXDRDY,
nrf_timer_subscribe_set(cfg->timer.p_reg,
NRF_TIMER_TASK_COUNT,
ret = gppi_channel_enable(data->async->rx_cnt.ppi);
return -EIO;
} else {
nrf_uarte_int_enable(uarte, NRF_UARTE_INT_RXDRDY_MASK);
return 0;
static int uarte_nrfx_init(const struct device *dev)
int ret = uarte_nrfx_rx_counting_init(dev);
if (ret != 0) {
return ret;
NRF_UARTE_INT_ENDRX_MASK |
NRF_UARTE_INT_RXSTARTED_MASK |
NRF_UARTE_INT_ERROR_MASK |
NRF_UARTE_INT_RXTO_MASK);
nrf_uarte_enable(uarte);
* Stop any currently running RX operations. This can occur when a
* bootloader sets up the UART hardware and does not clean it up
* before jumping to the next application.
if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXSTARTED)) {
nrf_uarte_task_trigger(uarte, NRF_UARTE_TASK_STOPRX);
while (!nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXTO)) {
/* Busy wait for event to register */
nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_RXSTARTED);
nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_ENDRX);
nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_RXTO);
k_timer_init(&data->async->rx_timeout_timer, rx_timeout, NULL);
k_timer_user_data_set(&data->async->rx_timeout_timer, data);
k_timer_init(&data->async->tx_timeout_timer, tx_timeout, NULL);
k_timer_user_data_set(&data->async->tx_timeout_timer, data);
return 0;
static int uarte_nrfx_tx(const struct device *dev, const uint8_t *buf,
size_t len,
int32_t timeout)
if (!nrfx_is_in_ram(buf)) {
return -ENOTSUP;
if (data->async->tx_size) {
irq_unlock(key);
return -EBUSY;
} else {
data->async->tx_size = len;
nrf_uarte_int_enable(uarte, NRF_UARTE_INT_TXSTOPPED_MASK);
if (!is_tx_ready(dev)) {
/* Active poll out, postpone until it is completed. */
data->async->pend_tx_buf = (uint8_t *)buf;
} else {
data->async->tx_buf = buf;
data->async->tx_amount = -1;
tx_start(uarte, buf, len);
irq_unlock(key);
if (data->uart_config.flow_ctrl == UART_CFG_FLOW_CTRL_RTS_CTS
&& timeout != SYS_FOREVER_MS) {
k_timer_start(&data->async->tx_timeout_timer, K_MSEC(timeout),
K_NO_WAIT);
return 0;
static int uarte_nrfx_tx_abort(const struct device *dev)
if (data->async->tx_buf == NULL) {
return -EFAULT;
k_timer_stop(&data->async->tx_timeout_timer);
return 0;
static int uarte_nrfx_rx_enable(const struct device *dev, uint8_t *buf,
size_t len,
int32_t timeout)
if (nrf_uarte_rx_pin_get(uarte) == NRF_UARTE_PSEL_DISCONNECTED) {
__ASSERT(false, "TX only UARTE instance");
return -ENOTSUP;
data->async->rx_timeout = timeout;
data->async->rx_timeout_slab =
MAX(timeout / RX_TIMEOUT_DIV,
NRFX_CEIL_DIV(1000, CONFIG_SYS_CLOCK_TICKS_PER_SEC));
data->async->rx_buf = buf;
data->async->rx_buf_len = len;
data->async->rx_offset = 0;
data->async->rx_next_buf = NULL;
data->async->rx_next_buf_len = 0;
nrf_uarte_rx_buffer_set(uarte, buf, len);
data->async->rx_enabled = true;
nrf_uarte_task_trigger(uarte, NRF_UARTE_TASK_STARTRX);
return 0;
static int uarte_nrfx_rx_buf_rsp(const struct device *dev, uint8_t *buf,
size_t len)
int err;
if ((data->async->rx_buf == NULL)) {
err = -EACCES;
} else if (data->async->rx_next_buf == NULL) {
data->async->rx_next_buf = buf;
data->async->rx_next_buf_len = len;
nrf_uarte_shorts_enable(uarte, NRF_UARTE_SHORT_ENDRX_STARTRX);
err = 0;
} else {
err = -EBUSY;
irq_unlock(key);
return err;
static int uarte_nrfx_callback_set(const struct device *dev,
uart_callback_t callback,
void *user_data)
data->async->user_callback = callback;
data->async->user_data = user_data;
return 0;
static int uarte_nrfx_rx_disable(const struct device *dev)
if (data->async->rx_buf == NULL) {
return -EFAULT;
if (data->async->rx_next_buf != NULL) {
nrf_uarte_shorts_disable(uarte, NRF_UARTE_SHORT_ENDRX_STARTRX);
k_timer_stop(&data->async->rx_timeout_timer);
data->async->rx_enabled = false;
return 0;
struct uarte_nrfx_data *data = k_timer_user_data_get(timer);
(void) uarte_nrfx_tx_abort(data->dev);
static void user_callback(const struct device *dev, struct uart_event *evt)
if (data->async->user_callback) {
data->async->user_callback(dev, evt, data->async->user_data);
* Whole timeout is divided by RX_TIMEOUT_DIV into smaller units, rx_timeout
* is executed periodically every rx_timeout_slab ms. If between executions
* data was received, then we start counting down time from start, if not, then
* we subtract rx_timeout_slab from rx_timeout_left.
* If rx_timeout_left is less than rx_timeout_slab it means that receiving has
* timed out and we should tell user about that.
const struct device *dev = data->dev;
uint32_t read;
if (data->async->is_in_irq) {
return;
/* Disable ENDRX ISR, in case ENDRX event is generated, it will be
* handled after rx_timeout routine is complete.
nrf_uarte_int_disable(get_uarte_instance(dev),
NRF_UARTE_INT_ENDRX_MASK);
read = nrfx_timer_capture(&cfg->timer, 0);
} else {
read = data->async->rx_cnt.cnt;
/* Check if data was received since last function call */
if (read != data->async->rx_total_byte_cnt) {
data->async->rx_total_byte_cnt = read;
data->async->rx_timeout_left = data->async->rx_timeout;
/* Check if there is data that was not sent to user yet
* Note though that 'len' is a count of data bytes received, but not
* necessarily the amount available in the current buffer
int32_t len = data->async->rx_total_byte_cnt
- data->async->rx_total_user_byte_cnt;
/* Check for current buffer being full.
* if the UART receives characters before the the ENDRX is handled
* and the 'next' buffer is set up, then the SHORT between ENDRX and
* STARTRX will mean that data will be going into to the 'next' buffer
* until the ENDRX event gets a chance to be handled.
bool clipped = false;
if (len + data->async->rx_offset > data->async->rx_buf_len) {
len = data->async->rx_buf_len - data->async->rx_offset;
clipped = true;
if (len > 0) {
if (clipped ||
(data->async->rx_timeout_left
< data->async->rx_timeout_slab)) {
/* rx_timeout ms elapsed since last receiving */
struct uart_event evt = {
.type = UART_RX_RDY,
.data.rx.buf = data->async->rx_buf,
.data.rx.len = len,
.data.rx.offset = data->async->rx_offset
data->async->rx_offset += len;
data->async->rx_total_user_byte_cnt += len;
user_callback(dev, &evt);
} else {
data->async->rx_timeout_left -=
data->async->rx_timeout_slab;
/* If theres nothing left to report until the buffers are
* switched then the timer can be stopped
if (clipped) {
nrf_uarte_int_enable(get_uarte_instance(dev),
#define UARTE_ERROR_FROM_MASK(mask) \
((mask) & NRF_UARTE_ERROR_OVERRUN_MASK ? UART_ERROR_OVERRUN \
: (mask) & NRF_UARTE_ERROR_PARITY_MASK ? UART_ERROR_PARITY \
: (mask) & NRF_UARTE_ERROR_FRAMING_MASK ? UART_ERROR_FRAMING \
: (mask) & NRF_UARTE_ERROR_BREAK_MASK ? UART_BREAK \
: 0)
static void error_isr(const struct device *dev)
uint32_t err = nrf_uarte_errorsrc_get_and_clear(uarte);
.type = UART_RX_STOPPED,
.data.rx_stop.reason = UARTE_ERROR_FROM_MASK(err),
(void) uarte_nrfx_rx_disable(dev);
static void rxstarted_isr(const struct device *dev)
.type = UART_RX_BUF_REQUEST,
if (data->async->rx_timeout != SYS_FOREVER_MS) {
k_timer_start(&data->async->rx_timeout_timer,
K_MSEC(data->async->rx_timeout_slab),
K_MSEC(data->async->rx_timeout_slab));
static void endrx_isr(const struct device *dev)
if (!data->async->rx_enabled) {
/* This condition can occur only after triggering
* FLUSHRX task.
const int rx_amount = nrf_uarte_rx_amount_get(uarte);
int real_rx_amount = 0;
if(rx_amount != uarte_prev_rx_amount) {
real_rx_amount = rx_amount;
} else {
for(int i = 0; i < sizeof(po_flush_buf); i++) {
if(po_flush_buf[i] != uarte_prev_dirty) {
.type = UART_RX_DISABLED,
.data.rx.buf = &po_flush_buf,
.data.rx.len = real_rx_amount,
.data.rx.offset = -1,
return;
data->async->is_in_irq = true;
/* ensure rx timer is stopped - it will be restarted in RXSTARTED
* handler if needed
/* this is the amount that the EasyDMA controller has copied into the
* buffer
/* The 'rx_offset' can be bigger than 'rx_amount', so it the length
* of data we report back the the user may need to be clipped.
* This can happen because the 'rx_offset' count derives from RXRDY
* events, which can occur already for the next buffer before we are
* here to handle this buffer. (The next buffer is now already active
* because of the ENDRX_STARTRX shortcut)
int rx_len = rx_amount - data->async->rx_offset;
if (rx_len < 0) {
rx_len = 0;
data->async->rx_total_user_byte_cnt += rx_len;
if (!hw_rx_counting_enabled(data)) {
/* Prevent too low value of rx_cnt.cnt which may occur due to
* latencies in handling of the RXRDY interrupt. Because whole
* buffer was filled we can be sure that rx_total_user_byte_cnt
* is current total number of received bytes.
data->async->rx_cnt.cnt = data->async->rx_total_user_byte_cnt;
/* Only send the RX_RDY event if there is something to send */
if (rx_len > 0) {
.data.rx.len = rx_len,
.data.rx.offset = data->async->rx_offset,
data->async->is_in_irq = false;
return;
.type = UART_RX_BUF_RELEASED,
.data.rx_buf.buf = data->async->rx_buf,
/* If there is a next buffer, then STARTRX will have already been
* invoked by the short (the next buffer will be filling up already)
* and here we just do the swap of which buffer the driver is following,
* the next rx_timeout() will update the rx_offset.
if (data->async->rx_next_buf) {
data->async->rx_buf = data->async->rx_next_buf;
data->async->rx_buf_len = data->async->rx_next_buf_len;
/* Check is based on assumption that ISR handler handles
* ENDRX before RXSTARTED so if short was set on time, RXSTARTED
* event will be set.
if (!nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXSTARTED)) {
/* Remove the short until the subsequent next buffer is setup */
} else {
data->async->rx_buf = NULL;
irq_unlock(key);
evt.type = UART_RX_DISABLED;
/* This handler is called when the reception is interrupted, in contrary to
* finishing the reception after filling all provided buffers, in which case
* the events UART_RX_BUF_RELEASED and UART_RX_DISABLED are reported
* from endrx_isr.
static void rxto_isr(const struct device *dev)
static const uint8_t dirty;
evt.type = UART_RX_BUF_RELEASED;
evt.data.rx_buf.buf = data->async->rx_next_buf;
/* Flushing RX fifo requires buffer bigger than 4 bytes to empty fifo */
uarte_prev_rx_amount = nrf_uarte_rx_amount_get(get_uarte_instance(dev));
uarte_prev_dirty = dirty;
memset(po_flush_buf, dirty, sizeof(po_flush_buf));
nrf_uarte_rx_buffer_set(get_uarte_instance(dev), po_flush_buf, 5);
/* Final part of handling RXTO event is in ENDRX interrupt handler.
* ENDRX is generated as a result of FLUSHRX task.
nrf_uarte_task_trigger(get_uarte_instance(dev), NRF_UARTE_TASK_FLUSHRX);
static void txstopped_isr(const struct device *dev)
int key;
if (!data->async->tx_buf) {
/* If there is a pending tx request, it means that uart_tx()
* was called when there was ongoing uart_poll_out. Handling
* TXSTOPPED interrupt means that uart_poll_out has completed.
if (data->async->pend_tx_buf) {
key = irq_lock();
data->async->tx_buf = data->async->pend_tx_buf;
data->async->pend_tx_buf = NULL;
tx_start(uarte, data->async->tx_buf,
data->async->tx_size);
irq_unlock(key);
return;
key = irq_lock();
size_t amount = (data->async->tx_amount >= 0) ?
data->async->tx_amount : nrf_uarte_tx_amount_get(uarte);
irq_unlock(key);
.data.tx.buf = data->async->tx_buf,
.data.tx.len = amount,
if (amount == data->async->tx_size) {
evt.type = UART_TX_DONE;
} else {
evt.type = UART_TX_ABORTED;
nrf_uarte_int_disable(uarte, NRF_UARTE_INT_TXSTOPPED_MASK);
data->async->tx_buf = NULL;
data->async->tx_size = 0;
static void uarte_nrfx_isr_async(const struct device *dev)
&& nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXDRDY)) {
nrf_uarte_event_clear(uarte, NRF_UARTE_EVENT_RXDRDY);
data->async->rx_cnt.cnt++;
return;
error_isr(dev);
if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDRX)) {
endrx_isr(dev);
rxstarted_isr(dev);
if (nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_RXTO)) {
rxto_isr(dev);
&& nrf_uarte_int_enable_check(uarte, NRF_UARTE_INT_ENDTX_MASK)) {
endtx_isr(dev);
NRF_UARTE_INT_TXSTOPPED_MASK)) {
txstopped_isr(dev);
#endif /* CONFIG_UART_ASYNC_API */
* @brief Poll the device for input.
* @param c Pointer to character
* @return 0 if a character arrived, -1 if the input buffer is empty.
static int uarte_nrfx_poll_in(const struct device *dev, unsigned char *c)
const struct uarte_nrfx_data *data = get_dev_data(dev);
if (data->async) {
return -ENOTSUP;
if (!nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDRX)) {
return -1;
*c = data->rx_data;
/* clear the interrupt */
return 0;
* @brief Output a character in polled mode.
* @param c Character to send
static void uarte_nrfx_poll_out(const struct device *dev, unsigned char c)
bool isr_mode = k_is_in_isr() || k_is_pre_kernel();
int key;
if (data->pm_state != DEVICE_PM_ACTIVE_STATE) {
return;
if (isr_mode) {
while (1) {
key = irq_lock();
#if CONFIG_UART_ASYNC_API
if (data->async && data->async->tx_size &&
data->async->tx_amount < 0) {
irq_unlock(key);
} else {
key = wait_tx_ready(dev);
/* At this point we should have irq locked and any previous transfer
* completed. Transfer can be started, no need to wait for completion.
data->char_out = c;
tx_start(uarte, &data->char_out, 1);
irq_unlock(key);
/** Interrupt driven FIFO fill function */
static int uarte_nrfx_fifo_fill(const struct device *dev,
const uint8_t *tx_data,
int len)
len = MIN(len, data->int_driven->tx_buff_size);
if (!atomic_cas(&data->int_driven->fifo_fill_lock, 0, 1)) {
return 0;
/* Copy data to RAM buffer for EasyDMA transfer */
for (int i = 0; i < len; i++) {
data->int_driven->tx_buffer[i] = tx_data[i];
len = 0;
} else {
tx_start(uarte, data->int_driven->tx_buffer, len);
irq_unlock(key);
return len;
/** Interrupt driven FIFO read function */
static int uarte_nrfx_fifo_read(const struct device *dev,
uint8_t *rx_data,
const int size)
int num_rx = 0;
/* Clear the interrupt */
/* Receive a character */
rx_data[num_rx++] = (uint8_t)data->rx_data;
return num_rx;
/** Interrupt driven transfer enabling function */
static void uarte_nrfx_irq_tx_enable(const struct device *dev)
irq_unlock(key);
/** Interrupt driven transfer disabling function */
static void uarte_nrfx_irq_tx_disable(const struct device *dev)
/* TX IRQ will be disabled after current transmission is finished */
data->int_driven->disable_tx_irq = true;
/** Interrupt driven transfer ready function */
static int uarte_nrfx_irq_tx_ready_complete(const struct device *dev)
/* ENDTX flag is always on so that ISR is called when we enable TX IRQ.
* Because of that we have to explicitly check if ENDTX interrupt is
* enabled, otherwise this function would always return true no matter
* what would be the source of interrupt.
bool ready = !data->int_driven->disable_tx_irq &&
nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_TXSTOPPED) &&
if (ready) {
return ready;
static int uarte_nrfx_irq_rx_ready(const struct device *dev)
return nrf_uarte_event_check(uarte, NRF_UARTE_EVENT_ENDRX);
/** Interrupt driven receiver enabling function */
static void uarte_nrfx_irq_rx_enable(const struct device *dev)
nrf_uarte_int_enable(uarte, NRF_UARTE_INT_ENDRX_MASK);
/** Interrupt driven receiver disabling function */
static void uarte_nrfx_irq_rx_disable(const struct device *dev)
nrf_uarte_int_disable(uarte, NRF_UARTE_INT_ENDRX_MASK);
/** Interrupt driven error enabling function */
static void uarte_nrfx_irq_err_enable(const struct device *dev)
nrf_uarte_int_enable(uarte, NRF_UARTE_INT_ERROR_MASK);
/** Interrupt driven error disabling function */
static void uarte_nrfx_irq_err_disable(const struct device *dev)
nrf_uarte_int_disable(uarte, NRF_UARTE_INT_ERROR_MASK);
/** Interrupt driven pending status function */
static int uarte_nrfx_irq_is_pending(const struct device *dev)
return ((nrf_uarte_int_enable_check(uarte,
NRF_UARTE_INT_TXSTOPPED_MASK) &&
uarte_nrfx_irq_tx_ready_complete(dev))
NRF_UARTE_INT_ENDRX_MASK) &&
uarte_nrfx_irq_rx_ready(dev)));
/** Interrupt driven interrupt update function */
static int uarte_nrfx_irq_update(const struct device *dev)
return 1;
/** Set the callback function */
static void uarte_nrfx_irq_callback_set(const struct device *dev,
uart_irq_callback_user_data_t cb,
void *cb_data)
data->int_driven->cb = cb;
data->int_driven->cb_data = cb_data;
static const struct uart_driver_api uart_nrfx_uarte_driver_api = {
.poll_in = uarte_nrfx_poll_in,
.poll_out = uarte_nrfx_poll_out,
.err_check = uarte_nrfx_err_check,
.configure = uarte_nrfx_configure,
.config_get = uarte_nrfx_config_get,
.callback_set = uarte_nrfx_callback_set,
.tx = uarte_nrfx_tx,
.tx_abort = uarte_nrfx_tx_abort,
.rx_enable = uarte_nrfx_rx_enable,
.rx_buf_rsp = uarte_nrfx_rx_buf_rsp,
.rx_disable = uarte_nrfx_rx_disable,
.fifo_fill = uarte_nrfx_fifo_fill,
.fifo_read = uarte_nrfx_fifo_read,
.irq_tx_enable = uarte_nrfx_irq_tx_enable,
.irq_tx_disable = uarte_nrfx_irq_tx_disable,
.irq_tx_ready = uarte_nrfx_irq_tx_ready_complete,
.irq_rx_enable = uarte_nrfx_irq_rx_enable,
.irq_rx_disable = uarte_nrfx_irq_rx_disable,
.irq_tx_complete = uarte_nrfx_irq_tx_ready_complete,
.irq_rx_ready = uarte_nrfx_irq_rx_ready,
.irq_err_enable = uarte_nrfx_irq_err_enable,
.irq_err_disable = uarte_nrfx_irq_err_disable,
.irq_is_pending = uarte_nrfx_irq_is_pending,
.irq_update = uarte_nrfx_irq_update,
.irq_callback_set = uarte_nrfx_irq_callback_set,
static int endtx_stoptx_ppi_init(NRF_UARTE_Type *uarte,
nrfx_err_t ret;
ret = gppi_channel_alloc(&data->ppi_ch_endtx);
LOG_ERR("Failed to allocate PPI Channel");
return -EIO;
nrfx_gppi_channel_endpoints_setup(data->ppi_ch_endtx,
nrf_uarte_event_address_get(uarte, NRF_UARTE_EVENT_ENDTX),
nrf_uarte_task_address_get(uarte, NRF_UARTE_TASK_STOPTX));
nrfx_gppi_channels_enable(BIT(data->ppi_ch_endtx));
return 0;
static int uarte_instance_init(const struct device *dev,
const struct uarte_init_config *config,
uint8_t interrupts_active)
int err;
nrf_uarte_disable(uarte);
data->dev = dev;
nrf_gpio_pin_write(config->pseltxd, 1);
nrf_gpio_cfg_output(config->pseltxd);
if (config->pselrxd != NRF_UARTE_PSEL_DISCONNECTED) {
nrf_gpio_cfg_input(config->pselrxd, NRF_GPIO_PIN_NOPULL);
nrf_uarte_txrx_pins_set(uarte, config->pseltxd, config->pselrxd);
if (config->pselcts != NRF_UARTE_PSEL_DISCONNECTED) {
nrf_gpio_cfg_input(config->pselcts, NRF_GPIO_PIN_NOPULL);
if (config->pselrts != NRF_UARTE_PSEL_DISCONNECTED) {
nrf_gpio_pin_write(config->pselrts, 1);
nrf_gpio_cfg_output(config->pselrts);
nrf_uarte_hwfc_pins_set(uarte, config->pselrts, config->pselcts);
err = uarte_nrfx_configure(dev, &get_dev_data(dev)->uart_config);
if (err) {
return err;
data->pm_state = DEVICE_PM_ACTIVE_STATE;
if (get_dev_config(dev)->ppi_endtx) {
err = endtx_stoptx_ppi_init(uarte, data);
if (err < 0) {
return err;
if (data->async) {
err = uarte_nrfx_init(dev);
if (err < 0) {
return err;
} else
/* Enable receiver and transmitter */
nrf_uarte_rx_buffer_set(uarte, &data->rx_data, 1);
if (!get_dev_config(dev)->ppi_endtx) {
nrf_uarte_int_enable(uarte, NRF_UARTE_INT_ENDTX_MASK);
/* Set TXSTOPPED event by requesting fake (zero-length) transfer.
* Pointer to RAM variable (data->tx_buffer) is set because otherwise
* such operation may result in HardFault or RAM corruption.
nrf_uarte_tx_buffer_set(uarte, &data->char_out, 0);
/* switch off transmitter to save an energy */
return 0;
static void uarte_nrfx_pins_enable(const struct device *dev, bool enable)
if (!get_dev_config(dev)->gpio_mgmt) {
return;
uint32_t tx_pin = nrf_uarte_tx_pin_get(uarte);
uint32_t rx_pin = nrf_uarte_rx_pin_get(uarte);
uint32_t cts_pin = nrf_uarte_cts_pin_get(uarte);
uint32_t rts_pin = nrf_uarte_rts_pin_get(uarte);
if (enable) {
nrf_gpio_pin_write(tx_pin, 1);
nrf_gpio_cfg_output(tx_pin);
if (rx_pin != NRF_UARTE_PSEL_DISCONNECTED) {
nrf_gpio_cfg_input(rx_pin, NRF_GPIO_PIN_NOPULL);
if (IS_RTS_PIN_SET(get_dev_config(dev)->rts_cts_pins_set)) {
nrf_gpio_pin_write(rts_pin, 1);
nrf_gpio_cfg_output(rts_pin);
if (IS_CTS_PIN_SET(get_dev_config(dev)->rts_cts_pins_set)) {
nrf_gpio_cfg_input(cts_pin,
} else {
nrf_gpio_cfg_default(tx_pin);
nrf_gpio_cfg_default(rx_pin);
nrf_gpio_cfg_default(rts_pin);
nrf_gpio_cfg_default(cts_pin);
static void uarte_nrfx_set_power_state(const struct device *dev,
uint32_t new_state)
if (new_state == DEVICE_PM_ACTIVE_STATE) {
uarte_nrfx_pins_enable(dev, true);
data->pm_state = new_state;
if (hw_rx_counting_enabled(get_dev_data(dev))) {
nrfx_timer_enable(&get_dev_config(dev)->timer);
if (get_dev_data(dev)->async) {
return;
if (nrf_uarte_rx_pin_get(uarte) !=
if (data->int_driven &&
data->int_driven->rx_irq_enabled) {
} else {
__ASSERT_NO_MSG(new_state == DEVICE_PM_LOW_POWER_STATE ||
new_state == DEVICE_PM_SUSPEND_STATE ||
new_state == DEVICE_PM_OFF_STATE);
/* if pm is already not active, driver will stay indefinitely
* in while loop waiting for event NRF_UARTE_EVENT_RXTO
return;
/* Disabling UART requires stopping RX, but stop RX event is
* only sent after each RX if async UART API is used.
nrfx_timer_disable(&get_dev_config(dev)->timer);
/* Timer/counter value is reset when disabled. */
data->async->rx_total_byte_cnt = 0;
data->async->rx_total_user_byte_cnt = 0;
/* Wait for the transmitter to go idle.
* While the async API can wait for transmission to
* complete before disabling the peripheral, the poll
* API exits before the character is sent on the wire.
* If the transmission is ongoing when the peripheral
* is disabled, the ENDTX and TXSTOPPED events will
* never be generated. This will block the driver in
* any future calls to poll_out.
irq_unlock(wait_tx_ready(dev));
uarte_nrfx_pins_enable(dev, false);
return;
if (data->int_driven) {
data->int_driven->rx_irq_enabled =
if (data->int_driven->rx_irq_enabled) {
static int uarte_nrfx_pm_control(const struct device *dev,
uint32_t ctrl_command,
void *context, device_pm_cb cb, void *arg)
if (ctrl_command == DEVICE_PM_SET_POWER_STATE) {
uint32_t new_state = *((const uint32_t *)context);
if (new_state != data->pm_state) {
uarte_nrfx_set_power_state(dev, new_state);
} else {
__ASSERT_NO_MSG(ctrl_command == DEVICE_PM_GET_POWER_STATE);
*((uint32_t *)context) = data->pm_state;
if (cb) {
cb(dev, 0, context, arg);
return 0;
#endif /* CONFIG_PM_DEVICE */
#define UARTE(idx) DT_NODELABEL(uart##idx)
#define UARTE_HAS_PROP(idx, prop) DT_NODE_HAS_PROP(UARTE(idx), prop)
#define UARTE_PROP(idx, prop) DT_PROP(UARTE(idx), prop)
#define UARTE_PSEL(idx, pin_prop) \
COND_CODE_1(UARTE_HAS_PROP(idx, pin_prop), \
(UARTE_PROP(idx, pin_prop)), \
(NRF_UARTE_PSEL_DISCONNECTED))
#define HWFC_AVAILABLE(idx) \
(UARTE_HAS_PROP(idx, rts_pin) || UARTE_HAS_PROP(idx, cts_pin))
#define UARTE_IRQ_CONFIGURE(idx, isr_handler) \
do { \
IRQ_CONNECT(DT_IRQN(UARTE(idx)), DT_IRQ(UARTE(idx), priority), \
isr_handler, DEVICE_DT_GET(UARTE(idx)), 0); \
irq_enable(DT_IRQN(UARTE(idx))); \
} while (0)
#define HWFC_CONFIG_CHECK(idx) \
BUILD_ASSERT( \
(UARTE_PROP(idx, hw_flow_control) && HWFC_AVAILABLE(idx)) \
!UARTE_PROP(idx, hw_flow_control) \
#define UART_NRF_UARTE_DEVICE(idx) \
HWFC_CONFIG_CHECK(idx); \
UARTE_INT_DRIVEN(idx); \
UARTE_ASYNC(idx); \
static struct uarte_nrfx_data uarte_##idx##_data = { \
UARTE_CONFIG(idx), \
IF_ENABLED(CONFIG_UART_##idx##_ASYNC, \
(.async = &uarte##idx##_async,)) \
IF_ENABLED(CONFIG_UART_##idx##_INTERRUPT_DRIVEN, \
(.int_driven = &uarte##idx##_int_driven,)) \
static const struct uarte_nrfx_config uarte_##idx##z_config = { \
.uarte_regs = (NRF_UARTE_Type *)DT_REG_ADDR(UARTE(idx)), \
.rts_cts_pins_set = \
(UARTE_HAS_PROP(idx, rts_pin) ? RTS_PIN_SET_MASK : 0) |\
(UARTE_HAS_PROP(idx, cts_pin) ? CTS_PIN_SET_MASK : 0), \
.gpio_mgmt = IS_ENABLED(CONFIG_UART_##idx##_GPIO_MANAGEMENT), \
.ppi_endtx = IS_ENABLED(CONFIG_UART_##idx##_ENHANCED_POLL_OUT),\
IF_ENABLED(CONFIG_UART_##idx##_NRF_HW_ASYNC, \
(.timer = NRFX_TIMER_INSTANCE( \
CONFIG_UART_##idx##_NRF_HW_ASYNC_TIMER),)) \
static int uarte_##idx##_init(const struct device *dev) \
const struct uarte_init_config init_config = { \
.pseltxd = UARTE_PROP(idx, tx_pin), /* must be set */ \
.pselrxd = UARTE_PSEL(idx, rx_pin), /* optional */ \
.pselcts = UARTE_PSEL(idx, cts_pin), /* optional */ \
.pselrts = UARTE_PSEL(idx, rts_pin), /* optional */ \
COND_CODE_1(CONFIG_UART_##idx##_ASYNC, \
(UARTE_IRQ_CONFIGURE(idx, uarte_nrfx_isr_async);), \
(UARTE_IRQ_CONFIGURE(idx, uarte_nrfx_isr_int);)) \
return uarte_instance_init( \
dev, \
&init_config, \
IS_ENABLED(CONFIG_UART_##idx##_INTERRUPT_DRIVEN)); \
DEVICE_DT_DEFINE(UARTE(idx), \
uarte_##idx##_init, \
uarte_nrfx_pm_control, \
&uarte_##idx##_data, \
&uarte_##idx##z_config, \
PRE_KERNEL_1, \
CONFIG_KERNEL_INIT_PRIORITY_DEVICE, \
&uart_nrfx_uarte_driver_api)
#define UARTE_CONFIG(idx) \
.uart_config = { \
.baudrate = UARTE_PROP(idx, current_speed), \
.data_bits = UART_CFG_DATA_BITS_8, \
.stop_bits = UART_CFG_STOP_BITS_1, \
.parity = IS_ENABLED(CONFIG_UART_##idx##_NRF_PARITY_BIT) \
? UART_CFG_PARITY_EVEN \
: UART_CFG_PARITY_NONE, \
.flow_ctrl = UARTE_PROP(idx, hw_flow_control) \
? UART_CFG_FLOW_CTRL_RTS_CTS \
: UART_CFG_FLOW_CTRL_NONE, \
#define UARTE_ASYNC(idx) \
(struct uarte_async_cb uarte##idx##_async = { \
.hw_rx_counting = \
IS_ENABLED(CONFIG_UART_##idx##_NRF_HW_ASYNC), \
#define UARTE_INT_DRIVEN(idx) \
(static uint8_t uarte##idx##_tx_buffer[\
MIN(CONFIG_UART_##idx##_NRF_TX_BUFFER_SIZE, \
BIT_MASK(UARTE##idx##_EASYDMA_MAXCNT_SIZE))]; \
static struct uarte_nrfx_int_driven \
uarte##idx##_int_driven = { \
.tx_buffer = uarte##idx##_tx_buffer, \
.tx_buff_size = sizeof(uarte##idx##_tx_buffer),\
#ifdef CONFIG_UART_0_NRF_UARTE
UART_NRF_UARTE_DEVICE(0);
#ifdef CONFIG_UART_1_NRF_UARTE
UART_NRF_UARTE_DEVICE(1);
#ifdef CONFIG_UART_2_NRF_UARTE
UART_NRF_UARTE_DEVICE(2);
#ifdef CONFIG_UART_3_NRF_UARTE
UART_NRF_UARTE_DEVICE(3);
prj.conf
# NEWLIB C CONFIG_NEWLIB_LIBC=y CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y CONFIG_SERIAL=y CONFIG_UART_ASYNC_API=y CONFIG_NRFX_UARTE0=y # General # CONFIG_REBOOT=y # CONFIG_EVENT_MANAGER=y # CONFIG_LINKER_ORPHAN_SECTION_PLACE=y # CONFIG_SPEED_OPTIMIZATIONS=y # CONFIG_DEVICE_POWER_MANAGEMENT=y # CONFIG_PM_POLICY_APP=y # # UART # CONFIG_SERIAL=y # CONFIG_UART_INTERRUPT_DRIVEN=y # CONFIG_UART_0_INTERRUPT_DRIVEN=n # CONFIG_UART_1_INTERRUPT_DRIVEN=n # CONFIG_UART_LINE_CTRL=y # CONFIG_UART_ASYNC_API=y # CONFIG_UART_0_ASYNC=y # CONFIG_UART_1_ASYNC=y # CONFIG_UART_0_NRF_HW_ASYNC=y # CONFIG_UART_1_NRF_HW_ASYNC=y # CONFIG_UART_0_NRF_HW_ASYNC_TIMER=1 # CONFIG_UART_1_NRF_HW_ASYNC_TIMER=2 # CONFIG_NRFX_UARTE=y # CONFIG_NRFX_UARTE0=y # CONFIG_NRFX_UARTE1=y # CONFIG_NRFX_TIMER=y # CONFIG_NRFX_TIMER1=y # CONFIG_NRFX_TIMER2=y # CONFIG_NRFX_PPI=y CONFIG_NRF_MODEM_LIB=y CONFIG_NRF_MODEM_LIB_SYS_INIT=n # Modem information CONFIG_MODEM_INFO=y CONFIG_NETWORKING=y CONFIG_NET_TCP=y CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_POSIX_NAMES=y CONFIG_NET_NATIVE=n CONFIG_NET_IPV6=n CONFIG_NET_IPV4=y CONFIG_NET_SOCKETS_POLL_MAX=4 CONFIG_NET_CONNECTION_MANAGER=y # Network buffers CONFIG_NET_PKT_RX_COUNT=16 CONFIG_NET_PKT_TX_COUNT=16 CONFIG_NET_BUF_RX_COUNT=80 CONFIG_NET_BUF_TX_COUNT=80 CONFIG_NET_CONTEXT_NET_PKT_POOL=y #CONFIG_NET_IF_MAX_IPV4_COUNT=2 #CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=3 #CONFIG_DNS_SERVER_IP_ADDRESSES=y #CONFIG_DNS_SERVER1="8.8.8.8" #CONFIG_DNS_RESOLVER=y #CONFIG_DNS_RESOLVER_ADDITIONAL_BUF_CTR=2 #CONFIG_SNTP=y CONFIG_HTTP_CLIENT=y CONFIG_HTTP_PARSER_URL=y CONFIG_HEAP_MEM_POOL_SIZE=65536 CONFIG_MAIN_STACK_SIZE=8192 CONFIG_PRIVILEGED_STACK_SIZE=8192 CONFIG_ISR_STACK_SIZE=8192 #CONFIG_AT_CMD_THREAD_STACK_SIZE=4096 CONFIG_MODEM_KEY_MGMT=y CONFIG_LTE_LINK_CONTROL=y CONFIG_LTE_AUTO_INIT_AND_CONNECT=n # CONFIG_DFU_TARGET=y CONFIG_BOOTLOADER_MCUBOOT=y #CONFIG_BOOT_ENCRYPT_RSA=n #CONFIG_BOOT_SIGNATURE_TYPE_RSA=y #CONFIG_BOOT_SIGNATURE_TYPE_ECDSA_P256=n #CONFIG_BOOT_SIGNATURE_KEY_FILE="tinykey.pem" CONFIG_MCUBOOT_IMAGE_VERSION="1.0.10" CONFIG_HWINFO=y CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_IMG_MANAGER=y CONFIG_FLASH=y CONFIG_IMG_ERASE_PROGRESSIVELY=y CONFIG_LOG=y CONFIG_LOG_PRINTK=y CONFIG_LOG_BACKEND_UART=n CONFIG_LOG_IMMEDIATE=n CONFIG_OBJECT_TRACING=y CONFIG_THREAD_MONITOR=y CONFIG_ASSERT=y CONFIG_BASE64=y #CONFIG_FILE_SYSTEM=y #CONFIG_FILE_SYSTEM_LITTLEFS=y #CONFIG_ASSERT=n #CONFIG_LOG_BUFFER_SIZE=1024 #CONFIG_LOG_STRDUP_BUF_COUNT=2 #CONFIG_LOG_STRDUP_MAX_STRING=512 #CONFIG_LOG_MIPI_SYST_ENABLE=y #CONFIG_LOG_BACKEND_UART_SYST_ENABLE=y #CONFIG_SOC_LOG_LEVEL_OFF=y #CONFIG_ARCH_LOG_LEVEL_OFF=y #CONFIG_KERNEL_LOG_LEVEL_OFF=y #CONFIG_LOG_RUNTIME_FILTERING=n #CONFIG_MAIN_THREAD_PRIORITY=10 #CONFIG_LOG_FUNC_NAME_PREFIX_DBG=n #CONFIG_LOG_PROCESS_THREAD=y #CONFIG_LOG_PROCESS_THREAD_SLEEP_MS=100 #CONFIG_LOG_PROCESS_TRIGGER_THRESHOLD=2 #CONFIG_LOG_PRINTK_MAX_STRING_LENGTH=256 CONFIG_LOG_PROCESS_THREAD_STACK_SIZE=8192 CONFIG_SECURE_BOOT=y #CONFIG_BUILD_S1_VARIANT=y CONFIG_SB_SIGNING_KEY_FILE="configuration/tinycarrierv1/tiny_b0_priv.pem" CONFIG_DFU_TARGET=y CONFIG_DFU_TARGET_MCUBOOT=y CONFIG_DFU_TARGET_MODEM_DELTA=y CONFIG_DFU_TARGET_FULL_MODEM=n CONFIG_MCUMGR=y CONFIG_MCUMGR_CMD_IMG_MGMT=y CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 CONFIG_BUILD_S1_VARIANT=y CONFIG_FW_INFO=y CONFIG_FW_INFO_FIRMWARE_VERSION=1
prj.overlay
&uart0 {
