[ Nrf52840 spi ] strange data received in spis
Hi, I tried to run peripheral spi / spis examples on Nrf52840 with sdk 17.1.0
However I had problems with receiving data from master.
I expected to get "Nordic" every 200ms, but buffer was fiiled with different data.
Buffer data is not totally different, but it seems like dummy data is going inside the buffer.
I haven't touch anything from the examples, but still this is happening.
And why is the size of m_rx_buf larger than the size of TEST_STRING?
I can't understand why this is happening plz help me.
Below here is my source code for spi and spis.
#define TEST_STRING "Nordic"
static uint8_t       m_tx_buf[] = TEST_STRING;           /**< TX buffer. */
static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];    /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
#include "sdk_config.h"
#include "nrf_drv_spis.h"
#include "nrf_gpio.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SPIS_INSTANCE 1 /**< SPIS instance index. */
static const nrf_drv_spis_t spis = NRF_DRV_SPIS_INSTANCE(SPIS_INSTANCE);/**< SPIS instance. */
static volatile bool spis_xfer_done; /**< Flag used to indicate that SPIS instance completed the transfer. */
void spis_event_handler(nrf_drv_spis_event_t event)
    if (event.evt_type == NRF_DRV_SPIS_XFER_DONE)
        spis_xfer_done = true;
        NRF_LOG_INFO(" Transfer completed. Received: %s, size: %d",(uint32_t)m_rx_buf);
    // Enable the constant latency sub power mode to minimize the time it takes
    // for the SPIS peripheral to become active after the CSN line is asserted
    // (when the CPU is in sleep mode).
    NRF_POWER->TASKS_CONSTLAT = 1;
    NRF_LOG_INFO("SPIS example");
    nrf_drv_spis_config_t spis_config = NRF_DRV_SPIS_DEFAULT_CONFIG;
    spis_config.csn_pin               = APP_SPIS_CS_PIN;
    spis_config.miso_pin              = APP_SPIS_MISO_PIN;
    spis_config.mosi_pin              = APP_SPIS_MOSI_PIN;
    spis_config.sck_pin               = APP_SPIS_SCK_PIN;
    APP_ERROR_CHECK(nrf_drv_spis_init(&spis, &spis_config, spis_event_handler));
    while (1)
        memset(m_rx_buf, 0, m_length);
        spis_xfer_done = false;
        APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, m_tx_buf, m_length, m_rx_buf, m_length));
        while (!spis_xfer_done)
            __WFE();
        NRF_LOG_FLUSH();
        bsp_board_led_invert(BSP_BOARD_LED_0);
spi
#ifndef NRF_DRV_SPI_H__
#define NRF_DRV_SPI_H__
#include <nrfx.h>
#ifdef SPIM_PRESENT
    #include <nrfx_spim.h>
#else
    // Compilers (at least the smart ones) will remove the SPIM related code
    // (blocks starting with "if (NRF_DRV_SPI_USE_SPIM)") when it is not used,
    // but to perform the compilation they need the following definitions.
    #define nrfx_spim_init(...)             0
    #define nrfx_spim_uninit(...)
    #define nrfx_spim_start_task_get(...)   0
    #define nrfx_spim_end_event_get(...)    0
    #define nrfx_spim_abort(...)
#ifdef SPI_PRESENT
    #include <nrfx_spi.h>
#else
    // Compilers (at least the smart ones) will remove the SPI related code
    // (blocks starting with "if (NRF_DRV_SPI_USE_SPI)") when it is not used,
    #define nrfx_spi_init(...)              0
    #define nrfx_spi_uninit(...)
    #define nrfx_spi_start_task_get(...)    0
    #define nrfx_spi_end_event_get(...)     0
    #define nrfx_spi_abort(...)
    // This part is for old modules that use directly SPI HAL definitions
    // (to make them compilable for chips that have only SPIM).
    #define NRF_SPI_FREQ_125K           NRF_SPIM_FREQ_125K
    #define NRF_SPI_FREQ_250K           NRF_SPIM_FREQ_250K
    #define NRF_SPI_FREQ_500K           NRF_SPIM_FREQ_500K
    #define NRF_SPI_FREQ_1M             NRF_SPIM_FREQ_1M
    #define NRF_SPI_FREQ_2M             NRF_SPIM_FREQ_2M
    #define NRF_SPI_FREQ_4M             NRF_SPIM_FREQ_4M
    #define NRF_SPI_FREQ_8M             NRF_SPIM_FREQ_8M
    #define NRF_SPI_MODE_0              NRF_SPIM_MODE_0
    #define NRF_SPI_MODE_1              NRF_SPIM_MODE_1
    #define NRF_SPI_MODE_2              NRF_SPIM_MODE_2
    #define NRF_SPI_MODE_3              NRF_SPIM_MODE_3
    #define NRF_SPI_BIT_ORDER_MSB_FIRST NRF_SPIM_BIT_ORDER_MSB_FIRST
    #define NRF_SPI_BIT_ORDER_LSB_FIRST NRF_SPIM_BIT_ORDER_LSB_FIRST
#ifdef __cplusplus
extern "C" {
 * @defgroup nrf_drv_spi SPI master driver
 * @ingroup  nrf_spi
 * @brief    Layer providing compatibility with the former API.
 * @brief SPI master driver instance data structure.
typedef struct
    uint8_t inst_idx;
    union
#ifdef SPIM_PRESENT
        nrfx_spim_t spim;
#ifdef SPI_PRESENT
        nrfx_spi_t  spi;
    } u;
    bool    use_easy_dma;
} nrf_drv_spi_t;
 * @brief Macro for creating an SPI master driver instance.
#define NRF_DRV_SPI_INSTANCE(id)    NRF_DRV_SPI_INSTANCE_(id)
#define NRF_DRV_SPI_INSTANCE_(id)   NRF_DRV_SPI_INSTANCE_ ## id
#if NRFX_CHECK(NRFX_SPIM0_ENABLED)
    #define NRF_DRV_SPI_INSTANCE_0 \
        { 0, { .spim = NRFX_SPIM_INSTANCE(0) }, true }
#elif NRFX_CHECK(NRFX_SPI0_ENABLED)
        { 0, { .spi = NRFX_SPI_INSTANCE(0) }, false }
#if NRFX_CHECK(NRFX_SPIM1_ENABLED)
    #define NRF_DRV_SPI_INSTANCE_1 \
        { 1, { .spim = NRFX_SPIM_INSTANCE(1) }, true }
#elif NRFX_CHECK(NRFX_SPI1_ENABLED)
        { 1, { .spi = NRFX_SPI_INSTANCE(1) }, false }
#if NRFX_CHECK(NRFX_SPIM2_ENABLED)
    #define NRF_DRV_SPI_INSTANCE_2 \
        { 2, { .spim = NRFX_SPIM_INSTANCE(2) }, true }
#elif NRFX_CHECK(NRFX_SPI2_ENABLED)
        { 2, { .spi = NRFX_SPI_INSTANCE(2) }, false }
 * @brief This value can be provided instead of a pin number for signals MOSI,
 *        MISO, and Slave Select to specify that the given signal is not used and
 *        therefore does not need to be connected to a pin.
#define NRF_DRV_SPI_PIN_NOT_USED  0xFF
 * @brief SPI data rates.
typedef enum
    NRF_DRV_SPI_FREQ_125K = NRF_SPI_FREQ_125K, ///< 125 kbps.
    NRF_DRV_SPI_FREQ_250K = NRF_SPI_FREQ_250K, ///< 250 kbps.
    NRF_DRV_SPI_FREQ_500K = NRF_SPI_FREQ_500K, ///< 500 kbps.
    NRF_DRV_SPI_FREQ_1M   = NRF_SPI_FREQ_1M,   ///< 1 Mbps.
    NRF_DRV_SPI_FREQ_2M   = NRF_SPI_FREQ_2M,   ///< 2 Mbps.
    NRF_DRV_SPI_FREQ_4M   = NRF_SPI_FREQ_4M,   ///< 4 Mbps.
    NRF_DRV_SPI_FREQ_8M   = NRF_SPI_FREQ_8M    ///< 8 Mbps.
} nrf_drv_spi_frequency_t;
 * @brief SPI modes.
typedef enum
    NRF_DRV_SPI_MODE_0 = NRF_SPI_MODE_0, ///< SCK active high, sample on leading edge of clock.
    NRF_DRV_SPI_MODE_1 = NRF_SPI_MODE_1, ///< SCK active high, sample on trailing edge of clock.
    NRF_DRV_SPI_MODE_2 = NRF_SPI_MODE_2, ///< SCK active low, sample on leading edge of clock.
    NRF_DRV_SPI_MODE_3 = NRF_SPI_MODE_3  ///< SCK active low, sample on trailing edge of clock.
} nrf_drv_spi_mode_t;
 * @brief SPI bit orders.
typedef enum
    NRF_DRV_SPI_BIT_ORDER_MSB_FIRST = NRF_SPI_BIT_ORDER_MSB_FIRST, ///< Most significant bit shifted out first.
    NRF_DRV_SPI_BIT_ORDER_LSB_FIRST = NRF_SPI_BIT_ORDER_LSB_FIRST  ///< Least significant bit shifted out first.
} nrf_drv_spi_bit_order_t;
 * @brief SPI master driver instance configuration structure.
typedef struct
    uint8_t sck_pin;      ///< SCK pin number.
    uint8_t mosi_pin;     ///< MOSI pin number (optional).
                          /**< Set to @ref NRF_DRV_SPI_PIN_NOT_USED
                           *   if this signal is not needed. */
    uint8_t miso_pin;     ///< MISO pin number (optional).
    uint8_t ss_pin;       ///< Slave Select pin number (optional).
                           *   if this signal is not needed. The driver
                           *   supports only active low for this signal.
                           *   If the signal should be active high,
                           *   it must be controlled externally. */
    uint8_t irq_priority; ///< Interrupt priority.
    uint8_t orc;          ///< Over-run character.
                          /**< This character is used when all bytes from the TX buffer are sent,
                               but the transfer continues due to RX. */
    nrf_drv_spi_frequency_t frequency; ///< SPI frequency.
    nrf_drv_spi_mode_t      mode;      ///< SPI mode.
    nrf_drv_spi_bit_order_t bit_order; ///< SPI bit order.
} nrf_drv_spi_config_t;
 * @brief SPI master instance default configuration.
#define NRF_DRV_SPI_DEFAULT_CONFIG                           \
    .sck_pin      = NRF_DRV_SPI_PIN_NOT_USED,                \
    .mosi_pin     = NRF_DRV_SPI_PIN_NOT_USED,                \
    .miso_pin     = NRF_DRV_SPI_PIN_NOT_USED,                \
    .ss_pin       = NRF_DRV_SPI_PIN_NOT_USED,                \
    .irq_priority = SPI_DEFAULT_CONFIG_IRQ_PRIORITY,         \
    .orc          = 0xFF,                                    \
    .frequency    = NRF_DRV_SPI_FREQ_4M,                     \
    .mode         = NRF_DRV_SPI_MODE_0,                      \
    .bit_order    = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST,         \
#define NRF_DRV_SPI_FLAG_TX_POSTINC          (1UL << 0) /**< TX buffer address incremented after transfer. */
#define NRF_DRV_SPI_FLAG_RX_POSTINC          (1UL << 1) /**< RX buffer address incremented after transfer. */
#define NRF_DRV_SPI_FLAG_NO_XFER_EVT_HANDLER (1UL << 2) /**< Interrupt after each transfer is suppressed, and the event handler is not called. */
#define NRF_DRV_SPI_FLAG_HOLD_XFER           (1UL << 3) /**< Set up the transfer but do not start it. */
#define NRF_DRV_SPI_FLAG_REPEATED_XFER       (1UL << 4) /**< Flag indicating that the transfer will be executed multiple times. */
 * @brief Single transfer descriptor structure.
typedef struct
    uint8_t const * p_tx_buffer; ///< Pointer to TX buffer.
    uint8_t         tx_length;   ///< TX buffer length.
    uint8_t       * p_rx_buffer; ///< Pointer to RX buffer.
    uint8_t         rx_length;   ///< RX buffer length.
}nrf_drv_spi_xfer_desc_t;
 * @brief Macro for setting up single transfer descriptor.
 * This macro is for internal use only.
#define NRF_DRV_SPI_SINGLE_XFER(p_tx, tx_len, p_rx, rx_len)  \
    .p_tx_buffer = (uint8_t const *)(p_tx),                  \
    .tx_length = (tx_len),                                   \
    .p_rx_buffer = (p_rx),                                   \
    .rx_length = (rx_len),                                   \
 * @brief Macro for setting duplex TX RX transfer.
#define NRF_DRV_SPI_XFER_TRX(p_tx_buf, tx_length, p_rx_buf, rx_length)                    \
        NRF_DRV_SPI_SINGLE_XFER(p_tx_buf, tx_length, p_rx_buf, rx_length)
 * @brief Macro for setting TX transfer.
#define NRF_DRV_SPI_XFER_TX(p_buf, length) \
        NRF_DRV_SPI_SINGLE_XFER(p_buf, length, NULL, 0)
 * @brief Macro for setting RX transfer.
#define NRF_DRV_SPI_XFER_RX(p_buf, length) \
        NRF_DRV_SPI_SINGLE_XFER(NULL, 0, p_buf, length)
 * @brief SPI master driver event types, passed to the handler routine provided
 *        during initialization.
typedef enum
    NRF_DRV_SPI_EVENT_DONE, ///< Transfer done.
} nrf_drv_spi_evt_type_t;
typedef struct
    nrf_drv_spi_evt_type_t  type;      ///< Event type.
    union
        nrf_drv_spi_xfer_desc_t done;  ///< Event data for DONE event.
    } data;
} nrf_drv_spi_evt_t;
 * @brief SPI master driver event handler type.
typedef void (* nrf_drv_spi_evt_handler_t)(nrf_drv_spi_evt_t const * p_event,
                                           void *                    p_context);
 * @brief Function for initializing the SPI master driver instance.
 * This function configures and enables the specified peripheral.
 * @note MISO pin has pull down enabled.
 * @param[in] p_instance Pointer to the driver instance structure.
 * @param[in] p_config   Pointer to the structure with the initial configuration.
 * @param     handler    Event handler provided by the user. If NULL, transfers
 *                       will be performed in blocking mode.
 * @param      p_context Context passed to event handler.
 * @retval NRF_SUCCESS             If initialization was successful.
 * @retval NRF_ERROR_INVALID_STATE If the driver was already initialized.
 * @retval NRF_ERROR_BUSY          If some other peripheral with the same
 *                                 instance ID is already in use. This is
 *                                 possible only if PERIPHERAL_RESOURCE_SHARING_ENABLED
 *                                 is set to a value other than zero.
ret_code_t nrf_drv_spi_init(nrf_drv_spi_t const * const p_instance,
                            nrf_drv_spi_config_t const * p_config,
                            nrf_drv_spi_evt_handler_t    handler,
                            void *                       p_context);
 * @brief Function for uninitializing the SPI master driver instance.
 * @note Configuration of pins is kept.
__STATIC_INLINE
void nrf_drv_spi_uninit(nrf_drv_spi_t const * const p_instance);
 * @brief Function for starting the SPI data transfer.
 * If an event handler was provided in the @ref nrf_drv_spi_init call, this function
 * returns immediately and the handler is called when the transfer is done.
 * Otherwise, the transfer is performed in blocking mode, which means that this function
 * returns when the transfer is finished.
 * @note Peripherals using EasyDMA (for example, SPIM) require the transfer buffers
 *       to be placed in the Data RAM region. If they are not and an SPIM instance is
 *       used, this function will fail with the error code NRF_ERROR_INVALID_ADDR.
 * @param[in] p_tx_buffer      Pointer to the transmit buffer. Can be NULL
 *                             if there is nothing to send.
 * @param     tx_buffer_length Length of the transmit buffer.
 * @param[in] p_rx_buffer      Pointer to the receive buffer. Can be NULL
 *                             if there is nothing to receive.
 * @param     rx_buffer_length Length of the receive buffer.
 * @retval NRF_SUCCESS            If the operation was successful.
 * @retval NRF_ERROR_BUSY         If a previously started transfer has not finished
 *                                yet.
 * @retval NRF_ERROR_INVALID_ADDR If the provided buffers are not placed in the Data
 *                                RAM region.
__STATIC_INLINE
ret_code_t nrf_drv_spi_transfer(nrf_drv_spi_t const * const p_instance,
                                uint8_t const * p_tx_buffer,
                                uint8_t         tx_buffer_length,
                                uint8_t       * p_rx_buffer,
                                uint8_t         rx_buffer_length);
 * @brief Function for starting the SPI data transfer with additional option flags.
 * Function enables customizing the transfer by using option flags.
 * Additional options are provided using the flags parameter:
 * - @ref NRF_DRV_SPI_FLAG_TX_POSTINC and @ref NRF_DRV_SPI_FLAG_RX_POSTINC<span></span>:
 *   Post-incrementation of buffer addresses. Supported only by SPIM.
 * - @ref NRF_DRV_SPI_FLAG_HOLD_XFER<span></span>: Driver is not starting the transfer. Use this
 *   flag if the transfer is triggered externally by PPI. Supported only by SPIM. Use
 *   @ref nrf_drv_spi_start_task_get to get the address of the start task.
 * - @ref NRF_DRV_SPI_FLAG_NO_XFER_EVT_HANDLER<span></span>: No user event handler after transfer
 *   completion. This also means no interrupt at the end of the transfer. Supported only by SPIM.
 *   If @ref NRF_DRV_SPI_FLAG_NO_XFER_EVT_HANDLER is used, the driver does not set the instance into
 *   busy state, so you must ensure that the next transfers are set up when SPIM is not active.
 *   @ref nrf_drv_spi_end_event_get function can be used to detect end of transfer. Option can be used
 *   together with @ref NRF_DRV_SPI_FLAG_REPEATED_XFER to prepare a sequence of SPI transfers
 *   without interruptions.
 * - @ref NRF_DRV_SPI_FLAG_REPEATED_XFER<span></span>: Prepare for repeated transfers. You can set
 *   up a number of transfers that will be triggered externally (for example by PPI). An example is
 *   a TXRX transfer with the options @ref NRF_DRV_SPI_FLAG_RX_POSTINC,
 *   @ref NRF_DRV_SPI_FLAG_NO_XFER_EVT_HANDLER, and @ref NRF_DRV_SPI_FLAG_REPEATED_XFER. After the
 *   transfer is set up, a set of transfers can be triggered by PPI that will read, for example,
 *   the same register of an external component and put it into a RAM buffer without any interrupts.
 *   @ref nrf_drv_spi_end_event_get can be used to get the address of the END event, which can be
 *   used to count the number of transfers. If @ref NRF_DRV_SPI_FLAG_REPEATED_XFER is used,
 *   the driver does not set the instance into busy state, so you must ensure that the next
 *   transfers are set up when SPIM is not active. Supported only by SPIM.
 * @note Function is intended to be used only in non-blocking mode.
 * @param p_instance  Pointer to the driver instance structure.
 * @param p_xfer_desc Pointer to the transfer descriptor.
 * @param flags       Transfer options (0 for default settings).
 * @retval NRF_SUCCESS             If the procedure was successful.
 * @retval NRF_ERROR_BUSY          If the driver is not ready for a new transfer.
 * @retval NRF_ERROR_NOT_SUPPORTED If the provided parameters are not supported.
 *                                 RAM region.
__STATIC_INLINE
ret_code_t nrf_drv_spi_xfer(nrf_drv_spi_t     const * const p_instance,
                            nrf_drv_spi_xfer_desc_t const * p_xfer_desc,
                            uint32_t                        flags);
 * @brief Function for returning the address of a SPIM start task.
 * This function should be used if @ref nrf_drv_spi_xfer was called with the flag @ref NRF_DRV_SPI_FLAG_HOLD_XFER.
 * In that case, the transfer is not started by the driver, but it must be started externally by PPI.
 * @return     Start task address.
__STATIC_INLINE
uint32_t nrf_drv_spi_start_task_get(nrf_drv_spi_t const * p_instance);
 * @brief Function for returning the address of a END SPIM event.
 * A END event can be used to detect the end of a transfer if the @ref NRF_DRV_SPI_FLAG_NO_XFER_EVT_HANDLER
 * option is used.
 * @return     END event address.
__STATIC_INLINE
uint32_t nrf_drv_spi_end_event_get(nrf_drv_spi_t const * p_instance);
 * @brief Function for aborting ongoing transfer.
__STATIC_INLINE
void nrf_drv_spi_abort(nrf_drv_spi_t const * p_instance);
#ifndef SUPPRESS_INLINE_IMPLEMENTATION
#if defined(SPI_PRESENT) && !defined(SPIM_PRESENT)
#define NRF_DRV_SPI_WITH_SPI
#elif !defined(SPI_PRESENT) && defined(SPIM_PRESENT)
#define NRF_DRV_SPI_WITH_SPIM
#else
#if (NRFX_CHECK(SPI0_ENABLED) &&  NRFX_CHECK(SPI0_USE_EASY_DMA)) || \
    (NRFX_CHECK(SPI1_ENABLED) &&  NRFX_CHECK(SPI1_USE_EASY_DMA)) || \
    (NRFX_CHECK(SPI2_ENABLED) &&  NRFX_CHECK(SPI2_USE_EASY_DMA))
#if (NRFX_CHECK(SPI0_ENABLED) && !NRFX_CHECK(SPI0_USE_EASY_DMA)) || \
    (NRFX_CHECK(SPI1_ENABLED) && !NRFX_CHECK(SPI1_USE_EASY_DMA)) || \
    (NRFX_CHECK(SPI2_ENABLED) && !NRFX_CHECK(SPI2_USE_EASY_DMA))
#if defined(NRF_DRV_SPI_WITH_SPIM) && defined(NRF_DRV_SPI_WITH_SPI)
    #define NRF_DRV_SPI_USE_SPIM  (p_instance->use_easy_dma)
#elif defined(NRF_DRV_SPI_WITH_SPIM)
    #define NRF_DRV_SPI_USE_SPIM  true
#else
    #define NRF_DRV_SPI_USE_SPIM  false
#define NRF_DRV_SPI_USE_SPI  (!NRF_DRV_SPI_USE_SPIM)
__STATIC_INLINE
void nrf_drv_spi_uninit(nrf_drv_spi_t const * p_instance)
        nrfx_spim_uninit(&p_instance->u.spim);
    else if (NRF_DRV_SPI_USE_SPI)
        nrfx_spi_uninit(&p_instance->u.spi);
__STATIC_INLINE
    ret_code_t result = 0;
    #ifdef SPIM_PRESENT
        nrfx_spim_xfer_desc_t const spim_xfer_desc =
            .p_tx_buffer = p_tx_buffer,
            .tx_length   = tx_buffer_length,
            .p_rx_buffer = p_rx_buffer,
            .rx_length   = rx_buffer_length,
        result = nrfx_spim_xfer(&p_instance->u.spim, &spim_xfer_desc, 0);
    #ifdef SPI_PRESENT
        nrfx_spi_xfer_desc_t const spi_xfer_desc =
        result = nrfx_spi_xfer(&p_instance->u.spi, &spi_xfer_desc, 0);
    return result;
__STATIC_INLINE
                            uint32_t                        flags)
    #ifdef SPIM_PRESENT
            .p_tx_buffer = p_xfer_desc->p_tx_buffer,
            .tx_length   = p_xfer_desc->tx_length,
            .p_rx_buffer = p_xfer_desc->p_rx_buffer,
            .rx_length   = p_xfer_desc->rx_length,
        result = nrfx_spim_xfer(&p_instance->u.spim, &spim_xfer_desc, flags);
    #ifdef SPI_PRESENT
        result = nrfx_spi_xfer(&p_instance->u.spi, &spi_xfer_desc, flags);
    return result;
__STATIC_INLINE
    uint32_t result = 0;
        result = nrfx_spim_start_task_get(&p_instance->u.spim);
        NRFX_ASSERT(false); // not supported
        result = 0;
    return result;
__STATIC_INLINE
        result = nrfx_spim_end_event_get(&p_instance->u.spim);
        result = 0;
    return result;
__STATIC_INLINE
        nrfx_spim_abort(&p_instance->u.spim);
        nrfx_spi_abort(&p_instance->u.spi);
#endif // SUPPRESS_INLINE_IMPLEMENTATION
#ifdef __cplusplus
#endif // NRF_DRV_SPI_H__
spis
Thank you all for reading this.
    Have you checked the receive buffer with a debugger, to see if the data is corrupted when received by SPIS, or if it is during the logging that the data gets corrupted? Do you log over UART or RTT?
    Did you check the SPI signals with a logic analyzer, to see if the data being sent from the master is correct?
    If you have bad connection between the master and slave, you might need to increase the drive strength of the pins by calling nrf_gpio_cfg() with drive parameter set to (NRF_GPIO_PIN_H0H1) after spi_init.
    Jørgen
