Libuarte + nus
  • Libuarte seems can't handle too many data or fast enough that comes from nus.
  • Peripheral and central devices transmit data through Libuarte and nus.
  • Below is the part I have done,libuarte is unable to output complete data when transferring the file
  • What should I do to make B output complete data when transferring files
  • nrf52832   SDK_17.1.0
  • /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the LIBUARTE module.
     * @param[in] p_evt       Nordic UART Service event.
    void nus_data_handler(ble_nus_evt_t * p_evt)
    		ble_nus_chars_received_uart_print((uint8_t*)p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
    /**@brief Function for handling characters received by the Nordic UART Service (NUS).
     * @details This function takes a list of characters of length data_len and prints the characters out on UART.
     *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
    	len+=data_len;
    	NRF_LOG_INFO("re %d",len);//Get the total NUS data length
    	if((transfer_buf.nus_rxd_pos+244)>=TRANSFER_NUS_BUFFER_SIZE)
    		transfer_buf.nus_rxd_pos = 0;
    	//The new data has been added to transfer_buf.nus_rxd_buf.
    	for(int i=0;i<data_len;i++)
    		transfer_buf.nus_rxd_buf[transfer_buf.nus_rxd_pos+i] = p_data[i];
    	buffer_t buf = {
    		.ptr = &transfer_buf.nus_rxd_buf[transfer_buf.nus_rxd_pos],
    		.len = data_len,
    	//if libuarte_tx is not transmitting anything at the moment, we must start a new transmission here.
        uint32_t ret = nrf_libuarte_async_tx(&libuarte,&transfer_buf.nus_rxd_buf[transfer_buf.nus_rxd_pos], data_len);
        if (ret != NRF_SUCCESS)
    		//If libuarte_tx is busy, it puts the address and length of the data in the queue,
    		if(nrf_queue_is_full(&nus_rxd_buf_queue)) NRF_LOG_INFO("full");
    		ret = nrf_queue_push(&nus_rxd_buf_queue, &buf);
    		APP_ERROR_CHECK(ret);
    	transfer_buf.nus_rxd_pos += data_len;
    • My logic is to imitate app_uart_put.
    • I can confirm that nus received the data in its entirety and saved it in an 8k buffer.
    • libuarte is perfectly fine.
    • Transfer rates up to roughly 35kb/s are fine, but higher rates will cause byte loss. Buffers storing data received by nus also print overflow flags.
    • Under the same conditions, the mobile phone as the central device can receive data completely and print data completely.
  • I found a new phenomenon when the transfer rate is 23kb/s, and after 5 minutes of continuous transfer, the phenomenon of byte loss occurs. The same is true for the other rates but the time at which the loss starts is different. I think there is something wrong with my code. I will check it again. Thank you very much.
  • Did you make any progress (find anything when checking your code)?
  • I'm not getting anywhere.
    I want peripheral and central high-speed transmission.The problem is that libuarte cannot timely output the data received by nus.
    Set the baud rate for the peripheral to 115200,Set the baud rate for the central to 460800.The periphery sends data to the center,liburte in the center can print the data completely,But when the baud rate is the same,The periphery again sends data to the center,At this time, liburte in the center cannot complete the output data.The phone acts as the center and receives the data completely.But I don't have a solution yet.
    My test scenario. pc<-->periphery <-->Central<-->pc .
  • I see. You should be able to get much more than 35 kbps which I see you get. I did not fully understand from your last posts if you did verify that you got a good throughput via UART when using dummy data and not NUS? If not, please do this first. Secondly, when you start doing more than one thing you need to optimize a bit, so ensure you use double buffering as described in this thread. If you still cannot make it work, can you upload your code here along with instructions on how you test (I need to see more than just some snippets to get the full picture of how you are doing things)?
