OTA DFU Softdevice 3.1.0 -> 7.0.1 is feasible?
Hi!
We have some legacy IoT devices currently running with s132 3.1.0 softdevice (yes... very old). We would like to push a major update of the fleet, with our latest firmware running on s132 7.0.1
The DFU OTA is partially working: the first step is going well (SD + BL update) but then the procedure timeouts! The app update part is never reached. The device is then bricked.
I'm using the following command to generate the zip package:
nrfutil pkg generate --application "APP.hex" --application-version {app_ver} --softdevice "s132_nrf52_7.0.1_softdevice.hex" --bootloader "DFU.hex" --bootloader-version {bootloader_ver} --hw-version {hw_ver} --sd-req 0x91,0xCB --sd-id 0xCB --key-file "dfu_private_key.pem" DFU.zip'
This package is fully working on a 7.0.1 device, but it is unable to update a legacy 3.1.0 device.
I've also realized that the flash requirements are changing between the 2 soft devices... there is something that I'm missing?
Any help would be really appreciated! Thank you!
  • Could you try to start a debug session with the new bootloader project after the failed DFU attempt to see if you can figure out when hardfault is raised or why it does not enter DFU mode? I did go through the post-DFU-full.txt file again and compared it against REFLASHED.txt but nothing appears to be out of the ordinary.
    Daino said:
    Also the memory just before the application (0x258C0 - 0x25FFF) is not 0xFF in the post-DFU one, which seems a little bit weird to me (I don't know what this data is...)
    I understand this looks suspicious, but it is just a padding area reserved by the Softdevice which has not been cleaned up by the bootloader.
    The padding ensures the application starts on page aligned address (0x1000) and that we can make minor bug fix releases without changing the image size.
  • Hi Vidar,
    running the code step-by-step it looks like the DFU executes successfully.
    From my limited understanding it seems like the DFU finds a valid application and tries to run it. Then probably the application fails because it does not find the good SD.
    EDIT:
    Deep diving why the app was executed, we found out that the line
    if (!app_is_valid(crc_on_valid_app_required())) inside dfu_enter_check()
    was commented out, to speed up the startup and save energy (our application runs with a very low duty cycle and every millisecond counts to reach year-long battery life)... So basically the app CRC is never verified by the DFU. This allows the unexpected execution of the old app just after the DFU/SD update.
    The good news: bringing back the CRC control, the OTA update is now successfully completed Slight smileThank you for your support all along the way!
    Just as a closing note: do you see any viable alternative to bringing back the full CRC calculation in the DFU? We would really like to keep the boot-up as fast as possible.
    I am glad to hear that you found the issue Slight smile The problem with commenting out the line you mentioned is that you not only skip the CRC checksum validation, but also the .bank_code check here:
    This explains why the bootloader attempted to boot the application before it had been uploaded.
    To correctly disable CRC validation, you can use the '--app-boot-validation NO_VALIDATION' option when you generate your Bootloader settings page and DFU package with nrfutil.
    From the nrfutil help menus:
    $ nrfutil pkg generate --help
    Usage: nrfutil pkg generate [OPTIONS] ZIPFILE
      Generate a zip package for distribution to apps that support Nordic DFU OTA.
      The application, bootloader, and SoftDevice files are converted to .bin if
      supplied as .hex files. For more information on the generated package, see:
      http://developer.nordicsemi.com/nRF5_SDK/doc/
      --app-boot-validation [NO_VALIDATION|VALIDATE_GENERATED_CRC|VALIDATE_GENERATED_SHA256|VALIDATE_ECDSA_P256_SHA256]
                                      The method of boot validation for
                                      application.
    $ nrfutil settings generate --help
    Usage: nrfutil settings generate [OPTIONS] HEX_FILE
                                      application.
