I was working with ncs2.0.0 and using the CONFIG_AT_HOST_UART_1=y config command in the .prj file to change at_host uart config from uart0 to uart1 and I was able to send an at-command over uart1 to comms nrf9160 modem. However, after migration to ncs2.2.0. I noticed that that command is no longer available in this ncs version. It seems not enough to change zephyr,shell-uart = &uart0; to uart1 config in the chosen node. Because I tested this config by sending at-command after changing zephyr,shell-uart uart0 to uart1 and it didn't work but it works when I use uart0.
Is there any way to change at_host_uart in the ncs2.2.0 version?
Thank you, Kind regards.
