Partition Manager not using flash efficiently
Dear Nordic Team
When I run the command `west build -t partition_manager_report` from inside our build folder I get :
  flash_primary (0x100000 - 1024kB):
| 0x0: mcuboot (0xc000 - 48kB)                     |
| 0xc000: EMPTY_0 (0x4000 - 16kB)                  |
+---0x10000: mcuboot_primary (0x70000 - 448kB)-----+
+---0x10000: tfm_secure (0xc200 - 48kB)------------+
| 0x10000: mcuboot_pad (0x200 - 512B)              |
+---0x10200: mcuboot_primary_app (0x6fe00 - 447kB)-+
| 0x10200: tfm (0xc000 - 48kB)                     |
+---0x1c200: tfm_nonsecure (0x63e00 - 399kB)-------+
| 0x1c200: app (0x63e00 - 399kB)                   |
| 0x80000: mcuboot_secondary (0x70000 - 448kB)     |
| 0xf0000: EMPTY_1 (0x8000 - 32kB)                 |
+---0xf8000: nonsecure_storage (0x6000 - 24kB)-----+
| 0xf8000: nvs_storage (0x6000 - 24kB)             |
+---0xfe000: tfm_storage (0x2000 - 8kB)------------+
| 0xfe000: tfm_its (0x2000 - 8kB)                  |
This seems like an inefficient use of flash and flash is quite valuable to us. We have to make use of every kB we can.
It seems like a waste in the following respects:
1. Why is there an EMPTY_0 partition? Potential gain 16kB
2. Why is there an EMPTY_1 partition? Potential gain 32kB
3. Why does mcuboot take 48kB, it only needs 33996B in our build? Potential gain at least ~12kB
My main question is, how can the flash layout be optimized (by Hand)? If it cannot, how can partition manager be disable, so that the partitions from the device-tree are used instead?
My assumption is, that to optimize the flash layout one has to move to a static partition setup as described here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/scripts/partition_manager/partition_manager.html#static-configuration
So I copied the `build/paritions.yml` file to the `pm_static.yml` and started hand-optimizing. This is quite difficult, but I managed to achieve the following temporary result:
| 0x0: mcuboot (0x9000 - 36kB)                    |
+---0x9000: mcuboot_primary (0x77000 - 476kB)-----+
+---0x9000: tfm_secure (0x13200 - 76kB)-----------+
| 0x9000: mcuboot_pad (0x200 - 512B)              |
+---0x9200: mcuboot_primary_app (0x76e00 - 475kB)-+
| 0x9200: tfm (0x13200 - 76kB)                    |
+---0x1c200: tfm_nonsecure (0x63e00 - 399kB)------+
| 0x1c400: app (0x63c00 - 399kB)                  |
| 0x80000: EMPTY_1 (0x1000 - 4kB)                 |
| 0x81000: mcuboot_secondary (0x77000 - 476kB)    |
+---0xf8000: nonsecure_storage (0x6000 - 24kB)----+
+---0xfe000: tfm_storage (0x2000 - 8kB)-----------+
I managed to reduce the empty partitions and move the free space into the mcuboot_primary and secondary partitions respectively. To achieve this, I had to increase the tfm-partitions, instead the goal is to increase the app partitions. Trying to reduce the tfm partition size again to the original 48kB and moving the free space into the app partition I run into a linker issue.
That leaves me with the following secondary questions:
1. Is this approach to optimize the flash-layout correct?
2. Is there a reason, that the tfm partition is expected to be located at a certain address?
3. What is the mcubootpad partition for?
4. Why do some of the partitions use the keyword "align" in the pm_static.yml? The documentation reads "Ensure the alignment of the start or the end of the partition by specifying a dict with a start or end key respectively, where the value is the number of bytes to align to. If necessary, empty partitions are inserted in front of or behind the partition to ensure that the alignment is correct...." In our case it is "align: -start: 0x8000", does this mean, that the start of those partitions needs to be a multiple of 0x8000 for maximum space efficiency (or the partition manager will insert empty partitions)? What are the alignment requirements?
5. We are using mcuboot for firmware upgrades as described here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/mcuboot/design.html#swap-without-using-scratch. As described there, the primary partition needs to be bigger by a certain amount than the secondary partition. Can this be baked into the flash layout, such that an offending (too big) image is not only discovered when trying to switch to it after reboot when upgrading, but earlier? Ideally the secondary slot has exactly the size, such that it fits into the primary slot with enough padding for the move algorithm as described in the link.
  • Update:
    On 4. I found some helpful infos here: Interpretation of the partition manager report
    Is the CONFIG_NRF_SPU_FLASH_REGION_SIZE = 0x8000 in the nRF9160 ?
    On 3. It seems it is for the image header answer found here: Partition manager primary and secondary slot sizes
    On 5. It seems others have also observed:
     Big primary image prevents FOTA
    Regarding the empty partitions also see:
    RE: west build generates large EMPTY partitions
    After investigating a bit, I think I have to update my assumptions. Maybe someone could confirm?
    - On the nRF9160 the flash sector size is 0x8000=32KiB. It has a total of 1MiB/32KiB=32 sectors.
    - The sectors occupied by mcuboot can not hold anything else. Since the build > 32KiB it takes 2 sectors
    - The storages (nvs and tfm) currently takes 1 sector, exactly 32kiB size.
    - that leaves 32 - 3 = 29 sectors for the mcuboot primary and secondary partition. They need to be equal size (leaving out the caveat about the move algorithm for now). They also need to be aligned to the flash sectors (if so, why?). That means the sector count has to be even 29-1=28. Each partition needs half of the space 28/2=14. Which is what we see in the above report (14*32KiB = 448KiB).
    Yes, static partitioning (pm_static.yml) is the way to optimize partitions "by hand".
    If you use child images, Partition Manager is included by default, so I think it will be hard to disable it if you want to use MCUboot.
    You have two different ways to configure mcuboot flash usage:
    1. CONFIG_PM_PARTITION_SIZE_MCUBOOT and CONFIG_PM_PARTITION_SIZE_MCUBOOT_PAD. Ref  RE: west build generates large EMPTY partitions
    2. pm_static.yml
    MCUboot operates with static partitioning.
    Meaning that you can not change partitioning in an DFU update to MCUboot.
    Because of this, I think it is just as well to use pm_static.yml, as you might want static partitions either way.
    I do not know of any certain address requirements of tfm. Can you explain a bit further?
    If we imagine an application without a bootloader for a moment: The tfm partition is placed at the beginning of flash to make sure it is the first thing that is executed.
    Yes
    The general block size of the flash is 4kB(0x1000), see INFO.CODEPAGESIZE in the FICR.
    However, the SPU splits the flash for partitions, and have a size of 32kB(0x8000). See SPU Flash access control.
    Use Kcofig(in VS Code) search to verify what this configuration is set to for your build specifically.
    Or "west build -t menuconfig" in the Terminal.
    Cla said:
    Yes, and there seems to be a pull request for this as well:
    https://github.com/nrfconnect/sdk-nrf/pull/6245
    Yes, both I and one of my colleagues agree with your assumptions.
    I hope I answered your questions.
    Let me know if I missed some or if you have more.
    Good job with searching and finding relevant DevZone cases yourself by the way.
    Sigurd Hellesvik
  • Thanks for the detailed explanation.
    These are unfortunately not accessible to me. I get a "503 Service unavailable".
    When I hand edited the `pm_static` I ran into a linker issue with tfm. Even when I did not modify the size of the partition. This was unexpected. Now that I learned more, I guess that it was an alignment issue. Nevertheless: Do you know, what the alignment requirements are for the tfm_secure partition? I would have guessed, that it will need its own 32KiB sector also, but that does not seem to be, what the partition manager puts out.
    as far as I could see this was closed.
    Alternatively, we considered reserving the required amount in the `pm_static`, but I was unsure about what that amount should be (hence my question here: MCUBoot Swap using move, how to calculate size?). Now I start to understand, that the block size is 4kB and to be used in that calculation whereas the sectors/partitions are 32KiB to be used for partitioning. Is this correct?
    Thanks. Maybe I should have searched a bit more before asking though ;)
    Infocenter is now up and running again.
    I do not know.
    I will try to create a sample to move TF-M partitions to test this tomorrow or Monday.
    I reached out to the guy who closed it and it seems like it was closed due to it being 1 year since it was created.
    If you comment the issue it will show that users are interested in this feature, which may speed up its progress.
    I agree yes.
    Sigurd Hellesvik
  • I will try to create a sample to move TF-M partitions to test this tomorrow or Monday.
    Thanks
    And thanks for the quick and detailed answer.
