Partition Manager not using flash efficiently
Dear Nordic Team
When I run the command `west build -t partition_manager_report` from inside our build folder I get :
  flash_primary (0x100000 - 1024kB):
| 0x0: mcuboot (0xc000 - 48kB)                     |
| 0xc000: EMPTY_0 (0x4000 - 16kB)                  |
+---0x10000: mcuboot_primary (0x70000 - 448kB)-----+
+---0x10000: tfm_secure (0xc200 - 48kB)------------+
| 0x10000: mcuboot_pad (0x200 - 512B)              |
+---0x10200: mcuboot_primary_app (0x6fe00 - 447kB)-+
| 0x10200: tfm (0xc000 - 48kB)                     |
+---0x1c200: tfm_nonsecure (0x63e00 - 399kB)-------+
| 0x1c200: app (0x63e00 - 399kB)                   |
| 0x80000: mcuboot_secondary (0x70000 - 448kB)     |
| 0xf0000: EMPTY_1 (0x8000 - 32kB)                 |
+---0xf8000: nonsecure_storage (0x6000 - 24kB)-----+
| 0xf8000: nvs_storage (0x6000 - 24kB)             |
+---0xfe000: tfm_storage (0x2000 - 8kB)------------+
| 0xfe000: tfm_its (0x2000 - 8kB)                  |
This seems like an inefficient use of flash and flash is quite valuable to us. We have to make use of every kB we can.
It seems like a waste in the following respects:
1. Why is there an EMPTY_0 partition? Potential gain 16kB
2. Why is there an EMPTY_1 partition? Potential gain 32kB
3. Why does mcuboot take 48kB, it only needs 33996B in our build? Potential gain at least ~12kB
My main question is, how can the flash layout be optimized (by Hand)? If it cannot, how can partition manager be disable, so that the partitions from the device-tree are used instead?
My assumption is, that to optimize the flash layout one has to move to a static partition setup as described here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/scripts/partition_manager/partition_manager.html#static-configuration
So I copied the `build/paritions.yml` file to the `pm_static.yml` and started hand-optimizing. This is quite difficult, but I managed to achieve the following temporary result:
| 0x0: mcuboot (0x9000 - 36kB)                    |
+---0x9000: mcuboot_primary (0x77000 - 476kB)-----+
+---0x9000: tfm_secure (0x13200 - 76kB)-----------+
| 0x9000: mcuboot_pad (0x200 - 512B)              |
+---0x9200: mcuboot_primary_app (0x76e00 - 475kB)-+
| 0x9200: tfm (0x13200 - 76kB)                    |
+---0x1c200: tfm_nonsecure (0x63e00 - 399kB)------+
| 0x1c400: app (0x63c00 - 399kB)                  |
| 0x80000: EMPTY_1 (0x1000 - 4kB)                 |
| 0x81000: mcuboot_secondary (0x77000 - 476kB)    |
+---0xf8000: nonsecure_storage (0x6000 - 24kB)----+
+---0xfe000: tfm_storage (0x2000 - 8kB)-----------+
I managed to reduce the empty partitions and move the free space into the mcuboot_primary and secondary partitions respectively. To achieve this, I had to increase the tfm-partitions, instead the goal is to increase the app partitions. Trying to reduce the tfm partition size again to the original 48kB and moving the free space into the app partition I run into a linker issue.
That leaves me with the following secondary questions:
1. Is this approach to optimize the flash-layout correct?
2. Is there a reason, that the tfm partition is expected to be located at a certain address?
3. What is the mcubootpad partition for?
4. Why do some of the partitions use the keyword "align" in the pm_static.yml? The documentation reads "Ensure the alignment of the start or the end of the partition by specifying a dict with a start or end key respectively, where the value is the number of bytes to align to. If necessary, empty partitions are inserted in front of or behind the partition to ensure that the alignment is correct...." In our case it is "align: -start: 0x8000", does this mean, that the start of those partitions needs to be a multiple of 0x8000 for maximum space efficiency (or the partition manager will insert empty partitions)? What are the alignment requirements?
5. We are using mcuboot for firmware upgrades as described here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/mcuboot/design.html#swap-without-using-scratch. As described there, the primary partition needs to be bigger by a certain amount than the secondary partition. Can this be baked into the flash layout, such that an offending (too big) image is not only discovered when trying to switch to it after reboot when upgrading, but earlier? Ideally the secondary slot has exactly the size, such that it fits into the primary slot with enough padding for the move algorithm as described in the link.
