hello Nordic
i want to use nrf21540 dk to run a simple Bluetooth / beacon example with the ncs (v 1.9.2) i do not see some rise in dbm power with the nrf connect android application (also rtt seems to be locked so logging is an issue as well, not sure what that problem is)
(my end goal is to test tx boost capabilities when connected to our own pcb based on nrf52840 soc, i had some problem with that on this thread:
devzone.nordicsemi.com/.../how-to-configure-and-work-with-nrf21540-with-a-pcb)
i tried to follow the code in the ncs and could not find the connection between the mpsl_fem module and the ncs/zephyr ble api
though in the example build i do see the CONFIG_MPSL=y which is not clear to me what dependency put it to 'y' and how it is used cause in the above thead putting it to 'y' cause a fail cause of semaphore is not released
any ideas, and also is it possible to work with ncs/zephyr BLE stack / api with the nrf21540 EK as a tx booster for other pcb
best regards
Ziv
