Battery advice and discussion, Li-SOCl2
Hello Nordic and Community!
We are considering to use Li-SOCl2 batteries for our nRF9160 device. These have a good voltage and extremely low self-discharge, which makes them a great alternative to Li-Po (when non-rechargeable is viable).
The downside, as I have understood, is that they are not as good with peak currents. Our product is a "pure nRF9160"-device, with only GNSS+LTE-M. No external sensors or actuators.
We are considering using 2xAA batteries from Saft. These have 250mA pulse capacity. The "extreme peak" in nRF9160 data sheet is 435uA . So, with two in parallel we should be good. But I'm worried it might not be enough when batteries are more than 50% drained. Sudden peaks might kill the device, effectively decreasing the life time by a lot. Alternatives to work around this is to use big capacitors with the batteries, or maybe use 3xAA. We do not want to use LSH-batteries as they only come in bigger packages.
My question is, should I be worried about peaks or am I "well inside" the worry-area with 2xAA? Does anyone have any experience with Li-SOCl2 with the nRF9160 to share? Do I need batteries with caps, like in the picture?
Thank you all for all and any help!
Torje
