Encoding JSON array of an array of floats
I'm developing Software for the nRF52840. I'm using NCS version 2.2.0 and Zephyr OS build v3.2.99-ncs1.
I try to encode a JSON message that will be send via MQTT.
I managed to encode, objects, strings and other primitives,
But now I'm blocked trying to encode a double array of floats.
The JSON message I'm trying to encode would be like this:
{"observations":[[3.0, 0.20],[5.0, 0.30],[4.5, 0.25]]}
I have tried to follow the JSON_OBJ_DESCR_ARRAY_ARRAY example, like in line 390 in "zephyr/data/json.h" but I think the example shown is for an array of an array of objects (not floats), and I could not manage to get the desired result, although I have tried with several options.
Could you please give me some advice? An example of JSON_OBJ_DESCR_ARRAY_ARRAY, for floats would be appreciated.
Thanks and regards,
Jordi.
  • Hi Jordi,
    The JSON library is likely using a zephyr library.
    In that case I think you will get better help on the Zephyr Discord.
    But if you upload some test code here, I can have a look at it and see if I can help.
    (Insert->File) or (Insert->Code)
    Sigurd Hellesvik
  • Hi Sigurd,
    It's OK, I finally make it.
    As JSON_TOK_FLOAT, can accept any formatted string, I first encode the double array of floats and then I lie the json_obj_token.start to point to that "fake" string.
    I insert a code example here:
    #include <stdlib.h>
    #include <kernel.h>
    #include <data/json.h>
    static float vector[3][2] = {
    	{2.34, 0.64},
    	{3.41, 0.67},
    	{2.56, 0.59}
    struct json_data{
    	struct json_obj_token vector;
    	char arr_arr_floats[100];
    static struct json_obj_descr parent_descr[] = {
    	JSON_OBJ_DESCR_PRIM(struct json_data, vector, JSON_TOK_FLOAT)
    size_t encode_aray_array_float(float** data, size_t M, size_t N, char* buf_ini)
    	char* buf = buf_ini;
    	*buf++ = '[';
    	for(int i = 0; i < M; i++){
    		*buf++ = '[';
    		for(int j = 0; j < N; j++){
    			gcvt(data[i][j], 6, buf);
    			while(*buf != '\0') buf++;
    			if(j < N - 1){
    				*buf++ = ',';
    		*buf++ = ']';
    		if(i < M - 1){
    			*buf++ = ',';
    	*buf++ = ']';
    	*buf = '\0';
    	return (buf - buf_ini);
    int main()
    	struct json_data data;
    	/** Prepare JSON data */
    	data.vector.length = encode_aray_array_float((float**)vector, 3, 2, data.arr_arr_floats);
    	data.vector.start = data.arr_arr_floats;
    	/** Encode the json obj */
    	char json[200];
    	int err = json_obj_encode_buf(parent_descr, ARRAY_SIZE(parent_descr), &data, json, sizeof(json));
    	printk("err = %d\n", err);
    	printk("%s\n", json);
    	while(1){
    		k_msleep(1000);
    I wonder if there is a more elegant way to do it.
    I close the case, many thanks for your attention.
    Jordi.
  • Hi Jordi,
    Good to hear that you found JSON_TOK_FLOAT!
    I do not know if it runs faster, but it ups readability to use "sprintf":
    #include <zephyr/kernel.h>
    #include <stdio.h>
        {2.34, 0.64},
        {3.41, 0.67},
        {2.56, 0.59}
    void encode_aray_array_float(int M, int N, float data[M][N], char* buf_ini){
        sprintf(buf_ini, ""); // Initialize buf_init to be empty
        for(int m=0; m<M; m++){
            for(int n=0; n<N; n++){
                if(n==N-1){
                    sprintf(buf_ini, "%s [%.2lf];", buf_ini, data[m][n]);
                else {
                    sprintf(buf_ini, "%s [%.2lf],", buf_ini, data[m][n]);
    void main(void)
        char test_string[200];
        encode_aray_array_float(3, 2, vector, test_string);
        printk("%s\n", test_string);
    and prj.conf:
    # To make sprintf work with floats
    CONFIG_NEWLIB_LIBC=y
    # To make printk work with floats
    CONFIG_CBPRINTF_FP_SUPPORT=y
    Sigurd Hellesvik
