BLE DFU Error
I am developing a project for nRF52833 using nRF5 SDK. In this project I am trying to update firmware via BLE DFU. I got some of the project codes from the ble_app_buttonless_dfu example. I used the S140 in the project and I aim the device to work both as BLE Central and Peripheral.
For BLE DFU, I am using the BLE application in nRF Connect for Desktop, with nRF52 DK is connected to the PC. I am trying to update the nRF52833 through this device. First I connect to the device, then I become a pair with bonding. After this step, I upload the .zip file I prepared from the "Start Secure DFU" button, but I get an error in the nRF Connect application.
Error Text: DFU failed with error: Unable to find characteristic 8EC90001F3154F609FB8838830DAEA50 for service FE59 on device E8:C9:A3:16:0E:81.0.
What can i do to fix this problem?
Below are RTT logs and nRF Connect logs.
10:02:48.630	Scan started
10:03:01.470	Connecting to device
10:03:01.644	Connected to device E8:C9:A3:16:0E:81: interval: 7.5ms, timeout: 4000ms, latency: 0
10:03:01.694	ATT MTU updated for device E8:C9:A3:16:0E:81, new value is 247
10:03:01.701	Data length updated for device E8:C9:A3:16:0E:81, new value is 251
10:03:01.937	Attribute value read, handle: 0x03, value (0x): 57-69-70-65-6C-6F-74-5F-44-46-55-5F-44-45-56
10:03:06.691	Connection parameters updated for device E8:C9:A3:16:0E:81: interval 100ms, timeout 4000ms, latency: 0
10:03:21.593	Security updated, mode:1, level:2
10:03:21.899	Storing bond info for device E8:C9:A3:16:0E:81
10:03:29.270	Disconnected from device E8:C9:A3:16:0E:81
10:03:29.271	Performing DFU with file: D:\SDK\nRF5\DeviceDownload\nRF5_SDK_17.1.0_ddde560\examples\ble_central\ble_project\pca10100\s140\armgcc\Other_Files\FW.zip
10:03:32.293	Attribute value changed, handle: 0x11, value (0x): 02-00
10:03:32.492	Attribute value changed, handle: 0x10, value (0x): 01
10:03:32.494	Attribute value changed, handle: 0x10, value (0x): 20-01-01
10:03:38.580	DFU failed with error: Unable to find characteristic 8EC90001F3154F609FB8838830DAEA50 for service FE59 on device E8:C9:A3:16:0E:81.0.
00> <info> app_timer: RTC: initialized.
00>
00> <info> app: Initializing nrf_fstorage_sd implementation...
00>
00> <info> app: Setting vector table to bootloader: 0x00072000
00>
00> <info> app: Setting vector table to main app: 0x00027000
00>
00> <info> app: ATT MTU exchange completed.
00>
00> <info> app: Ble NUS max data length set to 0xF4(244)
00>
00> <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 1, procedure: Bonding
00>
00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Bonding data, action: Update
00>
00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update
00>
00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
00>
00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Central address resolution, action: Update
00>
00>
00> <info> app: Writing peer data to the bootloader...
00>
00> <info> app: Device is preparing to enter bootloader mode.
00>
00> <info> app: Disconne<info> app_timer: RTC: initialized.
00>
00>
00>
00>
00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
00>
00> <info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Service changed pending flag, action: Update
00>
00> <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 1, procedure: Encryption
00>
00>
