I am running central_uart example on thingy91:nrf52840 it is paired up with Thingy52 running peripheral_uart example.
everything seems to run fine i send and receive msg every 5 sec.
my problem is that the ble_data_received is toggling with triggered when buffer is full (40 bytes) and end of msg that is normaly 15-20 bytes.
how can i controll this? is there any time settings or end of msg character i can use
Rune
* Copyright (c) 2018 Nordic Semiconductor ASA
*modifyed by rv
/** @file
* @brief Nordic UART Service Client sample
#include <errno.h>
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/sys/byteorder.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <bluetooth/services/nus.h>
#include <bluetooth/services/nus_client.h>
#include <bluetooth/gatt_dm.h>
#include <bluetooth/scan.h>
#include <zephyr/settings/settings.h>
#include <zephyr/drivers/uart.h>
#define LOG_MODULE_NAME central_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME);
/* UART payload buffer element size. */
#define UART_BUF_SIZE 40
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define NUS_WRITE_TIMEOUT K_MSEC(150)
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_RX_TIMEOUT 500
static const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart1));
static struct k_work_delayable uart_work;
K_SEM_DEFINE(nus_write_sem, 0, 1);
struct uart_data_t {
void *fifo_reserved;
uint8_t data[UART_BUF_SIZE];
uint16_t len;
struct uart_data_t *uart_rx_buf;
uint8_t uart_tx_buf[UART_BUF_SIZE];
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static struct bt_conn *default_conn;
static struct bt_nus_client nus_client;
bool btcon=false;
static void ble_data_sent(struct bt_nus_client *nus, uint8_t err,
const uint8_t *const data, uint16_t len)
ARG_UNUSED(nus);
struct uart_data_t *buf;
// Retrieve buffer context.
buf = CONTAINER_OF(data, struct uart_data_t, data);
k_free(buf);
k_sem_give(&nus_write_sem);
if (err) {
LOG_WRN("ATT error code: 0x%02X", err);
static uint8_t ble_data_received(struct bt_nus_client *nus,
const uint8_t *data, uint16_t len)
ARG_UNUSED(nus);
int err;
LOG_INF("BLE data received! %d,:%s",len,data);
for (uint16_t x=0;x<len;x++){
if ( data[x]=='\n' || x==len-1 ){
uart_tx_buf[x]=data[x];
uart_tx_buf[x+1]='\0';
err = uart_tx(uart,uart_tx_buf, x+1, SYS_FOREVER_MS);
if (err) {
LOG_INF("Error Sending data over UART");
}else{
LOG_INF("Sending data over UART to nrf91! %d,%s",x,uart_tx_buf);
return BT_GATT_ITER_CONTINUE;
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
ARG_UNUSED(dev);
int err;
switch (evt->type) {
case UART_RX_RDY:
uart_rx_buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
uart_rx_buf->len=evt->data.rx.len;
if (evt->data.rx.buf[uart_rx_buf->len - 1] == '\n') { // removed or '\r'
k_fifo_put(&fifo_uart_rx_data, uart_rx_buf);
uart_rx_disable(uart);
case UART_RX_DISABLED:
LOG_DBG("UART_RX_DISABLED");
uart_rx_enable(uart, uart_rx_buf->data, sizeof(uart_rx_buf->data),
UART_RX_TIMEOUT);
static int uart_init(void)
int err;
struct uart_data_t *rx;
if (!device_is_ready(uart)) {
LOG_ERR("UART device not ready");
return -ENODEV;
rx = k_malloc(sizeof(*rx));
if (rx) {
rx->len = 0;
} else {
return -ENOMEM;
err = uart_callback_set(uart, uart_cb, NULL);
if (err) {
return err;
return uart_rx_enable(uart, rx->data, sizeof(rx->data),
UART_RX_TIMEOUT);
static void discovery_complete(struct bt_gatt_dm *dm,
void *context)
struct bt_nus_client *nus = context;
LOG_INF("Service discovery completed");
bt_gatt_dm_data_print(dm);
bt_nus_handles_assign(dm, nus);
bt_nus_subscribe_receive(nus);
bt_gatt_dm_data_release(dm);
static void discovery_service_not_found(struct bt_conn *conn,
void *context)
LOG_INF("Service not found");
static void discovery_error(struct bt_conn *conn,
int err,
void *context)
LOG_WRN("Error while discovering GATT database: (%d)", err);
struct bt_gatt_dm_cb discovery_cb = {
.completed = discovery_complete,
.service_not_found = discovery_service_not_found,
.error_found = discovery_error,
static void gatt_discover(struct bt_conn *conn)
int err;
if (conn != default_conn) {
return;
err = bt_gatt_dm_start(conn,
BT_UUID_NUS_SERVICE,
&discovery_cb,
&nus_client);
if (err) {
LOG_ERR("could not start the discovery procedure, error "
"code: %d", err);
static void exchange_func(struct bt_conn *conn, uint8_t err, struct bt_gatt_exchange_params *params)
if (!err) {
LOG_INF("MTU exchange done");
} else {
LOG_WRN("MTU exchange failed (err %" PRIu8 ")", err);
static void connected(struct bt_conn *conn, uint8_t conn_err)
int err;
if (conn_err) {
LOG_INF("Failed to connect to %s (%d)", log_strdup(addr),
conn_err);
if (default_conn == conn) {
bt_conn_unref(default_conn);
default_conn = NULL;
err = bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
if (err) {
LOG_ERR("Scanning failed to start (err %d)",
err);
return;
LOG_INF("Connected: %s", log_strdup(addr));
static struct bt_gatt_exchange_params exchange_params;
exchange_params.func = exchange_func;
err = bt_gatt_exchange_mtu(conn, &exchange_params);
if (err) {
LOG_WRN("MTU exchange failed (err %d)", err);
err = bt_conn_set_security(conn, BT_SECURITY_L2);
if (err) {
LOG_WRN("Failed to set security: %d", err);
gatt_discover(conn);
err = bt_scan_stop();
if ((!err) && (err != -EALREADY)) {
LOG_ERR("Stop LE scan failed (err %d)", err);
int err;
LOG_INF("Disconnected: %s (reason %u)", log_strdup(addr),
reason);
btcon=false;
if (default_conn != conn) {
return;
if (err) {
err);
static void security_changed(struct bt_conn *conn, bt_security_t level,
enum bt_security_err err)
if (!err) {
LOG_INF("Security changed: %s level %u", log_strdup(addr),
level);
} else {
LOG_WRN("Security failed: %s level %u err %d", log_strdup(addr),
level, err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
.connected = connected,
.disconnected = disconnected,
.security_changed = security_changed
static void scan_filter_match(struct bt_scan_device_info *device_info,
struct bt_scan_filter_match *filter_match,
bool connectable)
bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
LOG_INF("Filters matched. Address: %s connectable: %d",
log_strdup(addr), connectable);
btcon=true;
static void scan_connecting_error(struct bt_scan_device_info *device_info)
LOG_WRN("Connecting failed");
static void scan_connecting(struct bt_scan_device_info *device_info,
default_conn = bt_conn_ref(conn);
static int nus_client_init(void)
int err;
struct bt_nus_client_init_param init = {
.cb = {
.received = ble_data_received,
.sent = ble_data_sent,
err = bt_nus_client_init(&nus_client, &init);
if (err) {
LOG_ERR("NUS Client initialization failed (err %d)", err);
return err;
LOG_INF("NUS Client module initialized");
return err;
BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL,
scan_connecting_error, scan_connecting);
static int scan_init(void)
int err;
struct bt_scan_init_param scan_init = {
.connect_if_match = 1,
bt_scan_init(&scan_init);
bt_scan_cb_register(&scan_cb);
//static uint8_t cname[] = "CriticAlert";
err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_NUS_SERVICE);
//err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_NAME,*cname);
if (err) {
LOG_ERR("Scanning filters cannot be set (err %d)", err);
return err;
err = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
//err = bt_scan_filter_enable(BT_SCAN_NAME_FILTER, false);
if (err) {
LOG_ERR("Filters cannot be turned on (err %d)", err);
return err;
LOG_INF("Scan module initialized");
return err;
static void auth_cancel(struct bt_conn *conn)
LOG_INF("Pairing cancelled: %s", log_strdup(addr));
static void pairing_complete(struct bt_conn *conn, bool bonded)
LOG_INF("Pairing completed: %s, bonded: %d", log_strdup(addr),
bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
LOG_WRN("Pairing failed conn: %s, reason %d", log_strdup(addr),
reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
.pairing_complete = pairing_complete,
.pairing_failed = pairing_failed
void main(void)
int err;
err = bt_conn_auth_cb_register(&conn_auth_callbacks);
if (err) {
LOG_ERR("Failed to register authorization callbacks.");
return;
err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
if (err) {
printk("Failed to register authorization info callbacks.\n");
return;
err = bt_enable(NULL);
if (err) {
LOG_ERR("Bluetooth init failed (err %d)", err);
return;
LOG_INF("Bluetooth initialized");
if (IS_ENABLED(CONFIG_SETTINGS)) {
settings_load();
int (*module_init[])(void) = {uart_init, scan_init, nus_client_init};
for (size_t i = 0; i < ARRAY_SIZE(module_init); i++) {
err = (*module_init[i])();
if (err) {
return;
printk("Starting Bluetooth Central UART example\n");
if (err) {
LOG_ERR("Scanning failed to start (err %d)", err);
return;
LOG_INF("Scanning successfully started");
for (;;) {
/* Wait indefinitely for data to be sent over Bluetooth */
struct uart_data_t *nusbuf = k_fifo_get(&fifo_uart_rx_data,
K_FOREVER);
err = bt_nus_client_send(&nus_client, nusbuf->data, nusbuf->len);
if (err) {
LOG_WRN("Failed to send data over BLE connection"
"(err %d)", err);
LOG_INF("Sent data over BLE from nrf52: %d:%s", nusbuf->len,nusbuf->data);
err = k_sem_take(&nus_write_sem, NUS_WRITE_TIMEOUT);
if (err) {
LOG_WRN("NUS send timeout");
k_msleep(5);
