Application never gets into ADC_IRQHandler
Hi!
I'm working with nrf51dk with s110 Soft Device. I need to read ADC every 2ms. In order to achieve that, i made timer with interrupt after 2ms. here is my code of initialising and starting timer, and timer interrupt handler:
    #define ADC_SAMPLING_INTERVAL                APP_TIMER_TICKS(2, APP_TIMER_PRESCALER)
    app_timer_id_t m_adc_sampling_timer_id;
    static void timers_init(void)
    	err_code = app_timer_create(&m_adc_sampling_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    adc_sampling_timeout_handler);
    static void application_timers_start(void)
    		err_code = app_timer_start(m_adc_sampling_timer_id, ADC_SAMPLING_INTERVAL, NULL);
    static void adc_sampling_timeout_handler(void * p_context)
    		uint32_t p_is_running = 0;
    	sd_clock_hfclk_request();
    	while(! p_is_running)  							//wait for the hfclk to be available
        	        	sd_clock_hfclk_is_running((&p_is_running));
    	NRF_ADC->TASKS_START = 1;
    	nrf_gpio_pin_toggle(LED_2);
as You see, i toggle led2 at the end, to make sure that application gets to this point, and it does, so i assume that adc->start instruction is executed. but application never gets into ADC_IRQHandler. here is my initialization of ADC:
void adc_init()
	/* Enable interrupt on ADC sample ready event*/
	NRF_ADC->INTENSET = ADC_INTENSET_END_Msk;
	sd_nvic_SetPriority(ADC_IRQn, NRF_APP_PRIORITY_LOW);
	sd_nvic_EnableIRQ(ADC_IRQn);
	NRF_ADC->CONFIG	= (ADC_CONFIG_EXTREFSEL_None << ADC_CONFIG_EXTREFSEL_Pos)
										| (ADC_CONFIG_PSEL_AnalogInput0 << ADC_CONFIG_PSEL_Pos)
										| (ADC_CONFIG_REFSEL_VBG << ADC_CONFIG_REFSEL_Pos)
										| (ADC_CONFIG_INPSEL_AnalogInputOneThirdPrescaling << ADC_CONFIG_INPSEL_Pos)
										| (ADC_CONFIG_RES_10bit << ADC_CONFIG_RES_Pos);
	/* Enable ADC*/
	NRF_ADC->ENABLE = ADC_ENABLE_ENABLE_Enabled;
I looked at a lot of examples with adc and i still cant figure out what is wrong with my code. I would apreciate any advice on what could be wrong.
best regards, Ina
