Necessity of conversion time for sequential channel sampling
Hi everyone,
I have a quick question regarding the dynamics of the t_conv for when having multple channels of the SAADC. In brief, I have 2 channels set up to sample at #SAMPLES, which varies from 200-800 depending on application. I have the system set up in scan mode right now, where I will trigger a sample and ask it to sample from both channels. From the documentation, the timing should be:
Total time < Sum(CH[x].tACQ+tCONV), x=0..enabled channels
In this sampling mode, does the SAADC readout the first channel measurement WHILE the other channel is acquiring data, such that I can have it simply switch channels without adding additional pauses (1 - 2 - 1 - 2 - 1 - 2 ...), or do I need to allocate specific reading time (~2us/channel) as this readout process only happens after the sampling process itself? (1 - 2 - pause for conversion - 1 - 2 - pause ...)
Thank you very much for your help!
